STEP 1 OF 4
  • MOST POPULAR
    FRONT PORCH
    2 cameras
    MOST POPULAR
    FRONT PORCH
    2 cameras
    Sold Out
    1x Wyze Cam OG
    1x Wyze Doorbell v2
  • STARTER
    3 cameras
    STARTER
    3 cameras
    $136.90
    Select
    2x Wyze Cam OGs
    1x Wyze Cam OG Telephoto
    3x 32gb MicroSD Card
  • POWER PACK
    4 cameras
    POWER PACK
    4 cameras
    $211.88
    $169.99
    SAVE 19%
    Sold Out
    4x Wyze Cam v4
    4x 128gb MicroSD Cards
STEP 2 OF 3
Choose your add-ons
Let's make sure you have enough equipment to keep your fortress protected! Wyze Home Monitoring currently supports multiple keypads, up to 100 sensors, and 5 cameras.
  • All sensors filters
  • Location
  • Use-case
  • Power Source
  • Location
  • Use-case
  • Power Source
  • Wyze Sense Entry Sensor - 3 Pack
    $41.98
    Detects when things open/close.
    Detects when things open/close. Learn More
  • Wyze Sense Climate Sensor - 3 Pack
    $41.98
    Tracks temperature and humidity.
    Tracks temperature and humidity. Learn More
  • Wyze Sense Leak Sensor & Probe - 3 Sensors and 1 Probe
    $55.98
    Get notified of leaks.
    Get notified of leaks. Learn More
Sensors
  • Location
  • Use-case
  • Power Source
  • Location
  • Use-case
  • Power Source
  • Wyze Cam v4 - White / 1 Pack
    $35.98 $29.98
    The clearest Wyze Cam ever made.
    The clearest Wyze Cam ever made. Learn More
    Save 16%
  • Wyze Cam Pan v3 - White / 1 Pack
    $39.98
    Award-winning pan and tilt security, now weatherproof.
    Award-winning pan and tilt security, now weatherproof. Learn More
  • Wyze Cam OG - White / 1 Pack
    $29.98
    Back to the basics, with a huge leap forward. Capture the big picture with a 120° field of view and built-in spotlight.
    Back to the basics, with a huge leap forward. Capture the big picture with a 120° field of view and built-in spotlight. Learn More
Cameras
  • Location
  • Use-case
  • Power Source
  • Location
  • Use-case
  • Power Source
  • Wyze MicroSD Card - 32GB microSDHC Card
    $8.99
    Continuous recording and time lapses for Wyze Cams.
  • Wyze Battery Cam Solar Panel - Solar Panel
    $24.99
    Record for longer. Designed for Wyze Cam Outdoor and Wyze Battery Cam Pro.
    Record for longer. Designed for Wyze Cam Outdoor and Wyze Battery Cam Pro. Learn More
  • Wyze Outdoor Power Adapter - Outdoor Adapter + L-shaped Adapter + USB-C Adapter
    $19.99
    Ready for rain, snow, or shine. IP67 weather resistant so you can safely use your Wyze Camera outdoors.
    Ready for rain, snow, or shine. IP67 weather resistant so you can safely use your Wyze Camera outdoors. Learn More
Accessories
Step 3 of 4
Choose a plan
Choose our you-don't-have-to-worry-about-it-for-a-year annual plan, or go monthly. Both are great for any budget and give you 24/7 professional peace of mind, with bonus services included!
Did you know Wyze Home Monitoring can save you up to 20% on your home insurance? Learn More.
  • No long-term contract
  • Free Wyze Sense Hub with Annual Plan
  • Try worry-free for 30 days
  • Annual License Save 16% $99.99/yr
    Get 50% off select sensors & Wyze Sense Hub free
  • Monthly License $9.99/mo
    Get 25% off select sensors
Wyze Sense Hub
Wyze Sense Hub
Wyze Sense Hub (Required)
$45.98 Free
The brains behind the brawn. It connects each of the monitoring components and sends alerts.
STEP 4 OF 4
FREE SERVICES
FREE
Upgrade one of your Wyze Cams with premium features. FREE as long as you keep your Home Monitoring Service.
Learn More
FREE
Add a suite of smart weather-based features to Wyze Sprinkler Controller. FREE as long as you keep your Home Monitoring Service.
Learn More
SUBTOTAL
