1 of 8
Wyze Lock Bolt
Wyze Lock Bolt
Bluetooth-Connected Smart Lock.
Top Rated
Trusted by Customers
Style
$74.98 $79.98
Use a 5-digit ZIP code.
Ultra-Fast
Fingerprint Sensor
Control Anywhere
with Wi-Fi
Tired of fumbling with your keys? Unlock your door in less than a second with the touch of a finger or a tap in the app. Wyze Lock Bolt is a Bluetooth smart lock that replaces your deadbolt, giving you a luxurious backlit keypad with an ultra-fast fingerprint reader. Did we mention that it auto-locks if you forget?
  • A black background with a white fingerprint icon.
    Ultra-Fast Fingerprint Sensor
  • A black background with a white lock icon.
    Backlit Keypad with Anti-Peep
    View Lock and Unlock History in the Wyze App
  • A black and white image of a hammer and wrench.
    Replaces Existing Deadbolt
Wyze Lock Bolt Product Specs
  • Color options: Matte Black and Satin Nickel
  • Weight:  2.75 lbs
  • Power Source: 4x AA Batteries (included)
  • Battery Life: 10-12 months
  • Communication: Bluetooth 5.0
  • Range: 16 ft
  • Weather Resistance: IPX5
Operating Temperature
  • Keypad: -13°F to 122°F
  • Indoor Assembly: 32°F to 122°F
Storage Temperature
  • -22°F to 158°F
Door Compatibility
  • Thru hole diameter on door: 2-1/8”
  • Backset: 2-3/8” or 2-3/4”
  • Door thickness: 1-3/8” or 1-3/4”
  • Deadbolt diameter: 1”
  • For more details check our Measuring Template
  • Interior Lock Component
  • Exterior Keypad Component
  • Mounting Plate
  • Mounting Parts
  • AA Batteries
  • Measuring Template
  • Quick Start Guide
Wyze Lock Bolt by itself is a Bluetooth-only device. This gives users the same app convenience of setting up their lock once and never having to use keys or memorize codes again.
If your phone’s Bluetooth goes out you won’t be able to lock, unlock, or change access settings in the app, but you won’t be locked out. Wyze Lock Bolt remembers the fingerprints and access codes already set up. And as an emergency, you can always generate a One-Time Code from the app.
Wyze Lock Bolt will let you know when the batteries are running low. The low-battery indicator on the keypad will flash red. However, if you forget to replace them there is a USB-C port on the bottom of the keypad that can give you a brief, instant charge so you can enter your code and get in.
When you enter the app and you are within Bluetooth range, Wyze Lock Bolt will update your history log to show past events that occurred since your last connection. You can see who locked or unlocked your Wyze Lock Bolt, when they did so, and which method they used (app, fingerprint, code). You can also see records of the door jamming and 5 consecutive failed access attempts.
Every 4 hours, Wyze Lock Bolt generates a couple of randomized access codes that can each be used once. You don’t need WiFi or Bluetooth to generate the code. Simply go to the app > Wyze Lock Bolt > Settings > One-Time Code, and enter the 8 digit code on the keypad.
Wyze Lock Bolt can detect the position of the motor to know if a deadbolt is jammed or not.
All you need to do is press and hold the Pairing button on the lock for 3 seconds. With Bluetooth enabled, your phone should then detect and connect to your Wyze Lock Bolt if you are within 16 feet of range.
Share through the Wyze app to make sure everyone can get in. You can share Wyze Lock Bolt with up to 50 people and revoke access at any time.
Wyze Lock Bolt has a built-in alarm that will alert you if your door is jammed or if there are more than 5 consecutive attempts to unlock the device. It also has an auto-lock function that will automatically lock the door after a selected amount of time. Lastly, you can fine-tune your users’ access by access type (fingerprint, code, app) and schedule (hours, dates)!
Keyless entry. A fingerprint away.
Gone are the days of fumbling for keys. Enter your home quickly and securely with just a tap on the ultra-fast fingerprint sensor.
A person's finger near a fingerprint reader.
Luxurious backlit keypad.
Wyze Lock Bolt's exterior is crafted from solid metal for maximum security. Each button on the keypad is backlit for easy viewing at night.
A black lock bolt installed on a white door.
  • PCMAG.COM Logo
    "Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
A black lock bolt with a blue background and the words "anti peep technology" written on it.
Featuring anti-peep technology.
With anti-peep technology. you don't have to worry if someone watches you enter your code.
Simply add extra digits before or after your code and Wyze Lock Bolt will still unlock.
Designed to blend in beautifully.
  • A suitcase is sitting on the floor next to a door.
    Crafted to compliment your interior design.
  • A lock bolt on the exterior of a door.
    Luxurious metal design to match any exterior.
Auto-locks if you forget.
Never worry again about having left your door unlocked. We included an auto-lock timer to take the stress away. Simply set how long you want to delay auto-locking in the Wyze app, and after that time has passed, Wyze Lock Bolt will lock the door for you.
A black and grey keypad with water droplets on it.
Fully pick-proof and weatherproof.
Wyze Lock Bolt is completely pick-proof by removing the need for keys. It’s also built tough enough to withstand the elements with IPX5 weatherproofing.
A black and grey lock bolt charging device.
Up to 12 months of battery life.
Wyze Lock Bolt's 4 AA batteries last up to a year and are easily replaceable. If the battery life is low, the indicator will flash red reminding you to replace them.
If the batteries die while you're away, the USB-C port allows for an instant, brief charge for you to enter your access code for entry.
One-touch to lock.
Locking the door behind you is easier than ever. Just press the lock button on the keypad. If you're within Bluetooth range, you can also lock via the Wyze app.
A smartphone screen displaying a list of locked doors and their corresponding codes.
A smartphone screen with a fingerprint scanner.
A phone screen displaying a one time code.
Access duration screen on a smartphone.
The Wyze app is your command center.
*Bluetooth connection required for app features.
See who stopped by in the Wyze app. You can even view how it was unlocked, the exact time, and if there were any failed passcode attempts.
Create and store up to 20 access codes for family and guests, without manually programming each one into the lock. You can also store up to 50 total fingerprints for frequent users.
If your guest cannot unlock the door for any reason, you can remotely generate an emergency access code for them in the Wyze app even without a Bluetooth connection.
This single-use code grants access to your lock and expires within 4 hours. You can generate up to 16 codes every 4 hours.
Worried about giving out access codes to your home? Use auto-expiring codes so you never have to worry about temporary guests entering without permission. Set the day/time the code expires and never think about it again.
Top-notch security features, standard.
  • A cloud icon with a blue background and a blue line through it.
    No Cloud Connection
    Wyze Lock Bolt requires local Bluetooth connection to update any settings. Beyond that, the lock works on its own.
  • A blue and white icon of a lock with a keyhole.
    Hardware Encryption
    Built into Wyze Lock Bolt. Encrypted so no one (including Wyze) can figure out your code and fingerprint data.
  • A lock icon on a cell phone.
    Two-Factor Authentication
    Used within the Wyze app, so only those authorized are able to use Wyze Lock Bolt.
1 of 3
  • A black and silver keypad with a button on the bottom.
    Wyze Lock Bolt
    Built for Convenience: Quickly unlock the door with your fingerprint
    • Fingerprint unlock
    • Local app access only
    • No Wyze automations or Alexa/Google support
    • Replaces existing deadbolt
    • Basic Auto-Lock
    • No Auto-Unlock
    • Keypad built-in
  • A white device with a button on it.
    Wyze Lock
    Built for Smart Homes: Monitor and access your door from anywhere
    • No fingerprint unlock
    • Access the app from anywhere
    • Wyze automations & Alexa/Google support
    • Attaches to existing deadbolt
    • Advanced door position Auto-Lock
    • Auto-Unlock
    • Optional keypad sold separately
    Shop Wyze Lock
Replaces your existing deadbolt. Installs in just 20 minutes.
Wyze Lock Bolt is compatible with almost all exterior doors and replaces your existing deadbolt lock in about 20 minutes. Feel free to watch our installation video below to see how easy the process is.
It's even better when paired with Video Doorbell Pro.
Support Articles
To set up your Wyze Lock Bolt:
  1. Make sure you are connected to data or Wi-Fi (this is only for the initial pairing with the Wyze app).
  2. Enable BluetoothⓇ on your mobile device. If you’re on an iOS device, check that your Location Permissions are also enabled.If you’re on a device using Android 12+, check that your Nearby permissions are also enabled. Make sure that you are in BluetoothⓇ range for connection (16 feet or less).
  3. In the Wyze app, tap Home, then tap the plus sign + on the top right.
  4. On the Add menu, tap Device > Home > Wyze Lock Bolt.
  5. If you’ve already installed your Wyze Lock Bolt on your door, tap Skip Installation Guide. If not, tap Begin Installation.
  6. Press and hold the pairing button under the batteries (the round dent with “P” on it). Once you release the pairing button, you should hear 3 beeps and the keypad should flash white.
  7. Wait for the Wyze app to search for and connect to your Wyze Lock Bolt.
  8. Name your Wyze Lock Bolt. Then you’re all set!
  9. The app will then prompt you to create a 4-8 digit code to enter on the keypad when unlocking the door. This code is saved to the Wyze Lock Bolt and will not be visible in the Wyze app after setup. You can reset the code in the Wyze app if you forget your code. To unlock the door after setup, you will need to enter the code then press the button with the unlock icon.
  10. If you wish to set up a fingerprint to use to unlock the Wyze Lock Bolt, you’ll want to press I Consent on the Permission Request pop-up. If you do not want this feature, you can select Maybe later.
  11. On the Fingerprint Setup page of the setup, select Next. You can also select Show Me How for more instructions.
  12. After two beeps, place your finger on the fingerprint scanner then lift your finger off the fingerprint scanner. If there is no beep, check that the Wyze Lock Bolt has new batteries and that they are installed correctly.
  13. Rotate your finger slightly, then place your finger on the fingerprint scanner again. Repeat this process until the scanning process is complete (8/8 scans). The fingerprint scan process will time out after 40 seconds. You’ll want to complete all 8 scans within these 40 seconds.
  14. Press Done.
Download the Quick Start Guide for Wyze Lock Bolt in this article.
Below is the Quick Start Guide for Wyze Lock Bolt, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Lock Bolt including:
  • What's in the box for Wyze Lock Bolt.
  • The components of Wyze Lock Bolt.
  • How to set up your Wyze Lock Bolt.
  • How to install your Wyze Lock Bolt.
  • How to read the status lights for Wyze Lock Bolt.
  • Troubleshooting your Wyze Lock Bolt.
Installing your Wyze Lock Bolt should take a cool 20 minutes; you remove your existing lock, put your new lock in place, then set it up in the Wyze app. Follow along in the video below:
FREE shipping on orders $0+
