1 of 16
Wyze Scale Ultra BodyScan Plus
Professional-grade precision, right at home.
Color
$149.99
Use a 5-digit ZIP code.
We put a vibrant 4.3-inch TFT color screen right on the handle of our best scale, putting the data you need right in front of you. Weight, body fat, muscle mass, trends, all of it at eye level the second you step on. No phone. No bending down. No squinting.
  • Professional-Grade Precision at Home
    Built-in handle and electrodes to measure your arms, legs, and torso individually.
  • Huge On-Handle, Full Color, Customizable Display
    Cutting-edge screen displays your health data in vivid color, no app needed.
  • 50+ Essential Body Composition Metrics
    Measure your weight, body fat percentage, heart rate, BMI,  and so much more.
  • Detailed Advanced Reports
    Get a detailed breakdown of your body composition, and track progress trends over time.
Wyze Scale Ultra BodyScan Plus Specs
Color & Materials
  • Color: Black or White
  • Materials: Plastic, Silicone, ITO-Coated Glass, Stainless Steel Handle Electrodes
  • Weight: 5.95 lb / 2.7 kg
  • Dimensions: 11.81 × 11.81 × 2.01 in / 300 mm × 300 mm × 51 mm
Power
  • Battery-Powered: 4 × 1.5V AAA Batteries (Included)
Display
  • 4.3-Inch Full-Color TFT Display in the Handle
  • Customizable Measurement Display
  • Display Units: lb/kg
Weight Range
  • 11–400 lbs / 5–180 kg
Available Measurements
  • Displayed on Handle: Key metrics including Weight, Body Fat Percentage, BMI, Muscle Mass, Bone Mass, Protein, and Body Water Percentage, plus Progress Trends
  • Displayed In-App: Weight, BMI, Body Fat Percentage, Muscle Mass, Muscle Mass Percentage, Body Water Percentage, Physical Age, Protein, Lean Body Mass, Bone Mass, Visceral Fat, Basal Metabolic Rate, Subcutaneous Fat, Fat Mass, Skeletal Muscle Mass, Segmental Muscle & Body Fat Analysis, and more.
Measurement Technology
  • Dual-Frequency BIA with 8 Electrodes
  • Segmental Analysis for Arms, Legs, and Torso
Weather
  • Operating Temperature: 41°F–104°F (5°C–40°C)
  • Operating Humidity: 20–85% RH
  • Storage Temperature: −4°F–131°F (−20°C–55°C)
  • Storage Humidity: ≤90% RH
Connectivity & Compatibility
  • Connectivity: Wi-Fi and Bluetooth® 5.0
  • Phone Compatibility: Android 10.0+, iOS 16.0+
  • Supported Fitness Apps: Apple Health, Google Health, Health Connect
Warranty
  • 1-Year Limited Warranty
  • Wyze Scale Ultra Bodyscan Plus x 1
  • 1.5V AAA Batteries x 4
  • Quick Start Guide x 1
No, connecting to the scale is optional. Your measurements will display on the handle screen, even without Wi-Fi or Bluetooth.
The headline difference is the screen. Wyze Scale BodyScan Plus adds a vibrant, customizable 4.3-inch full-color TFT handle display that puts your complete body composition data at eye level the moment you step on — no need to open the app, bend down, or squint at a tiny LED. Wyze Scale BodyScan, by contrast, shows only 7 key metrics on a smaller monochrome LED and delivers the full breakdown through the Wyze app. Both scales use the same dual-frequency eight-electrode body impedance analysis (BIA) with a handle for segmental body composition analysis, and both measure the same 50+ body composition metrics, so the underlying accuracy is identical. BodyScan Plus also adds Wi-Fi connectivity for automatic syncing without your phone.
Two big differences. First, the screen: BodyScan Plus has a vibrant 4.3-inch color TFT display on the handle that shows your full body composition data, on-scale trends, and segmental breakdown the moment you step on — no phone required. Wyze Scale X has no on-scale display and routes everything through the Wyze app. Second, the precision: BodyScan Plus uses dual-frequency eight-electrode BIA with a handle that measures body impedance in your arms, legs, and torso individually, delivering results that are more accurate and personalized than the 4-electrode foot-only measurement on Wyze Scale X. BodyScan Plus also adds Wi-Fi connectivity and includes 50+ body composition metrics with segmental muscle and fat data. If you want a premium, glance-and-go experience instead of opening the app every time, BodyScan Plus is the upgrade.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale BodyScan Plus in every bathroom, and in your home gym, too.
Anyone can use Wyze Scale BodyScan Plus to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access body composition features. For users between 10-17, body composition data is only for reference.
Wyze Scale BodyScan Plus has a weight range of 11-400 lbs (5-180 kg).
Yes, but it will only measure your weight. To take your full body composition measurements (ex. Body Fat %, Water %, Lean Body Mass) you will need to hold the handle and step on the scale with both feet while barefoot.
No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Only step on Wyze Scale BodyScan Plus with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Yes, the Wyze app provides a quick and convenient way to measure your heart rate from anywhere in under 10 seconds.
Consult your physician first. By default, Wyze Scale BodyScan Plus sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy / Weight-Only Mode to only measure your weight.
Home-use smart scales are designed for reference. Wyze Scale BodyScan Plus uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available.
While a good estimate, the data calculated by your Wyze Scale BodyScan Plus may vary from those given by professional-grade medical instruments or methods.
Lift up the handle, then set the scale down. Tap to activate the scale, then press and hold the UNIT button on the bottom of the handle, right below the screen. The TFT display will show "Clear" when the scale is reset.
On the back of Wyze Scale BodyScan Plus's handle, locate the arrow over the battery compartment. With two thumbs, slide away towards the side away from the dotted arrow.
Scale Ultra Bodyscan Plus leveled up with more precision at your fingertips.
BodyScan precision in your hands.
Receive deeper insights into your health with an extendable handle and 8 smart electrodes across both hands and feet. These work together to measure your arms, legs, and torso individually.
4.3 inches of full-color data with BodyScan precision technology.
A best-in-class full-color customizable screen presents robust health data in vivid color without opening the app. Customize to view what’s most important to you.
Super duper detailed report.
View segmental data for your arms, legs, and torso all in one easy-to-read report.
Track 50+ Essential Health Metrics
Keep track of important health metrics like weight, body fat, muscle mass and more. We haven't figured out how to measure the joy you'll feel when you achieve your dream bod, but we're working on it.
Wi-Fi and Bluetooth Connection
When connected to Wi-Fi your data automatically syncs, so your phone doesn't have to loiter around while you're on the scale.
Baby, Pet & Luggage Mode
We get it. Math is hard. Weigh your baby, pet, luggage, or your kid’s absurdly heavy backpack with smart baby/pet mode and let us do the calculations for you.
Two Colorways to Fit Any Room
Wyze Scale Ultra BodyScan comes in two color options to match whatever vibe you've got going on in your porcelain palace.
Unlimited Sharing & Smart User Recognition
Share it with the whole family. Wyze Scale Ultra BodyScan automatically recognizes and syncs data for up to 8 unique users. Take one-off measurements for an unlimited number of guests. Stay motivated by sharing data and trends with an unlimited number of people.
Works with the brands you love.
No need to ditch your existing fitness tracker. Wyze Scale Ultra BodyScan connects seamlessly to your health apps for smooth syncing and complete control over your wellness journey.
    Anti-Slip Floor Contacts
    Sturdy construction and grippy silicone floor contacts enable safe and accurate measurements, every time.
    ITO Coated Glass
    Step anywhere on the scale. An ITO conductive glass gives highly accurate body composition measurements.
    Long-Lasting Battery Life
    They say nothing lasts forever. Except maybe the embarrassment you feel when the server tells you to have a nice meal, and you say, "You too!" Like, why would you say that? Anyways, enjoy up to 8 months of battery life with this scale.
    Compare Scales
    Compare Scales
    Scale BodyScan
    Scale BodyScan
    Scale Ultra
    Scale Ultra
    Price
    $149.98
    $119.98
    $84.98
    $84.98
    $49.98
    Screen on Handle
    # of Electrodes for More Accuracy
    TFT Screen
    Wi-Fi Connection
    Heart Rate
    In App
    In App
    In App
    In App
    Trend View
    On Screen/In App
    On Screen/In App
    In App
    In App
    Weight Range
    11–400 lb
    11-400 lbs
    11-400 lbs
    11-400 lbs
    Battery Life (Up To)
    9 Months
    8 Months
    18 Months
    22 Months
    ITO Conductive Glass
    Power Source
    4 AAA Batteries
    4 AAA Batteries
    4 AAA Batteries
    4 AAA Batteries
    Automatic Bluetooth Connection
    Bluetooth 5.0
    Baby/Pet/Luggage Mode
    Color
    Black/White
    Black/White
    Black/White
    Black/White
    Dimensions
    11.81 x 11.81 x 1.50 in
    11.8 in x 11.8 in x 1.18 in
    Only Weight Mode
    Athlete Mode
    Apple Health / Google Health / Health Connect
    Weight
    5.95 lb
    5.95 lb
    3.32 lb
    3.96 lb
    FREE shipping on orders $0+
