Wyze Labs, Inc.
Window Bird Cam
$69.98
Loved by Bird Watchers
Window Bird Cam camera and clear feeder with a cardinal perched on the right
Window Bird Cam
$69.98
30-day returns
Includes cam & feeder
Use a 5-digit ZIP code.
Free shipping 30-day returns
Window Bird Cam features and tech specs
Features
  • Up-Close 1080p HD Bird View
  • Easy Window Mount
  • Free Bird Alert Notifications
  • 24/7 Local RecordingRequires a microSD card, sold separately.
Tech specs
Design & installation
Model & colors
  • Camera: transparent body
  • Feeder: transparent body with dark green seed tray
Dimensions & weight
  • Item: 9.02 × 8.43 × 5.51 in; 1.12 lbs
  • Package: 9.25 × 9.02 × 5.39 in; 1.98 lbs
Placement & weather resistance
  • Camera: indoor only, mounted on the inside of window glass
  • Feeder: outdoors, mounted on the outside of window glass
  • Weather resistance: indoor
Camera & recording
Video & optics
  • 1080p (1920 × 1080), up to 30 fps
  • Aperture: F1.6; near-focus: 4-8 in (10-20 cm)
  • Field of view: 147° diagonal, 124° horizontal, 66.8° vertical
Audio & night vision
  • No audio or siren
  • No night vision / IR; optimized for daylight and dawn/dusk bird activity
Local storage
Supports up to a 512 GB microSD card in exFAT or FAT32
Power & connectivity
Power & cable
  • Power input: 5V DC, 1A
  • USB-A to USB-C, 9.8 ft (3 m) wired cable
Connectivity & compatibility
  • Wi-Fi: 802.11 b/g/n, 2.4 GHz, Wi-Fi 4/5/6
  • Android 9.0+; iOS 16.0+
  • Integrations: IFTTT
Temperature
  • Operating: 14°F to 113°F (−10°C to 45°C)
  • Storage: −40°F to 158°F (−40°C to 70°C)
What’s in the box
  • Window Bird Cam x1
  • Window Bird Feeder x1
  • Twist-Lock Suction Cups x4
  • Camera Positioning Template x1
  • Mounting Stickers x2
  • 10ft USB-A to USB-C cable x1
  • Indoor Power Adapter x1
  • Cable Clips x4
  • Quick Start Guide x1
Never Wonder “What Bird Was That?”
Meet the birds at your window with species identification and alerts from Bird Watch.
Meet Bird Watch
Species ID, 60-day cloud storage, and Bird Wiki—all in one upgrade.
Never miss a visit
  1. Know when a bird stops by.
Includes 3 months of Bird Watch free ($6.99/mo after).
  • Identify visitors + learn bird facts
  • Get bird alerts without cooldowns
  • Replay full visits with 60-day history
  • Follow bird activity + monthly Highlights
Free vs. Bird Watch
Every Bird Cam includes 3 months of Bird Watch. Here’s what you can do with and without a plan.
Bird Cam features with and without Bird Watch
Feature Free With Bird Watch
Live view Included Included
Local microSD recording Included Included
Bird detection Included Included
Species identificationNot included Included
Bird facts & WikiNot included Included
Monthly Bird HighlightsLimited Included
Bird Log & NumbersLimited Bird Log Included
Bird alertsWith 5 Min. cooldownNo cooldown
Event playbackAlert thumbnailFull-length visit video
Cloud historyNot included60 days
Bird Watch accessNot includedFirst 3 months free
Local recording requires a microSD card (sold separately).
Free bird alerts. Forever.
A red male Northern Cardinal faces the camera at a Wyze feeder.
Bird Detected Porch Feeder at 9:41 AM
Get notified when a bird stops by, then open the Wyze app to watch live.
Install in minutes. No tools required.
  1. Place the camera inside, facing out.
  2. Press the feeder to the outside glass. Twist to lock.
  3. Fill the tray with seed or nectar.
Up-close focus. Every feather, front and center.
Tuned for 4–8 inch macro focus in crisp HD, your feathered guests fill the frame while the backyard softly blurs.
Replay every visit. Local or cloud.
A hand inserts a microSD card into Window Bird Cam beside a phone showing the recording timeline.
On microSD
Record 24/7 continuously on a microSD card up to 512 GB (sold separately).
With Bird Watch
Rewatch, save, and share full-length cloud clips from the past 60 days.
Watch hummingbirds hover.
Fill the built-in side pod with nectar to invite hummingbirds right to your glass, and catch every wingbeat in smooth 30 fps video. The highest frame rate of any Wyze Cam.
A blue bird feeds from a clear tray held to the window by suction cups.
Low profile. High traffic.
Keep your view open with a clear, low profile mount. Four heavy-duty twist-lock suction cups grip securely through rain, wind, and snow.
The optional perch extending from the Window Bird Cam feeder.
More room to perch.
The optional perch extends their landing space in front of the lens, so you can watch birds between bites. Sold separately.
Window Bird Cam and a phone showing its hummingbird live view
Live view in seconds.
Birds don't wait around. While other cams buffer, you're already watching live. Open the Wyze app to watch visitors at your window, wherever you are.
A bird visits the USB-C powered window camera
USB-C cable plugged into the back of the camera
USB-C powered
Always on. Never charge it.
Plugs in by the window, so there’s no solar panel to adjust or battery to bring inside for charging.
Watch together. For free.
The Wyze app’s device-sharing screen surrounded by friends and family.
Share live feeder access with as many friends, kids, and grandparents as you want in the Wyze app—no extra guest fees.
See what’s in the box.
A quick look at your Window Bird Cam before it arrives.
Questions? Start here.
Find your answer. Get back to the birds.
Will this work on my window?
Choose a clear, screen-free pane where you can reach the feeder for refills. Make sure the included 3 m (9.8 ft) cable can reach an indoor outlet. Pair the camera in the Wyze app first. Hold it at the spot you have in mind and check the live view before securing the feeder to the glass.
Does the camera go inside or outside?
The camera mounts inside your window, while the feeder mounts outside, directly opposite it. This keeps the camera indoors while birds feed outside.
What Wi-Fi network does Bird Cam need?
Bird Cam connects to a 2.4 GHz Wi-Fi network. Choose a window with a reliable signal from your router.
Do I have to remove the feeder to refill it?
Leave the feeder mounted and slide out the seed tray for a rinse or refill. Drainage holes in the tray let rainwater out. The separate side pod holds nectar for hummingbirds.
Is the feeder easy to clean?
Yes. The seed tray slides out without tools for easy cleaning, so you can leave the feeder mounted to the window. The nectar pod is removable, too. Clean both regularly and let the seed tray dry before refilling.
Will I get another alert if a second bird lands right away?
With Bird Watch, back-to-back visits can each trigger a species alert. Tap the notification to open the live view. With the camera alone, alerts tell you a bird was detected, with a cooldown between notifications.
Can I watch without receiving a stream of alerts?
Yes. Open the camera in the Wyze app and turn off its alerts under Settings → Notifications. You can still open the live view whenever you like. For a temporary break from all Wyze notifications, tap the bell on the Home tab and choose a snooze duration.
How can I check which species landed?
With Bird Watch, see the species name in your bird notifications, browse identified visits in Recent Sightings, or check Species Sightings in Bird Numbers. Open a recorded visit and tap the book icon to explore Bird Wiki, compare adult male, adult female, and juvenile images, and learn more about your visitor.
Can I watch nocturnal birds at night?
The camera has no infrared night vision. It is designed for daylight and dawn/dusk bird activity.
Do I need a memory card to replay a visit?
Bird Watch saves full visit videos in the cloud for up to 60 days, even with the card slot empty. Open the visit in Recent Sightings to replay it. Download a favorite to your phone before the 60 days are up to keep your own copy.
Can I see what happened between bird visits?
Yes. Insert a microSD card up to 512 GB (sold separately). In the camera’s microSD card settings, turn on recording and choose Continuous for around-the-clock footage or Events Only for motion. Local recording works with or without Bird Watch.
How do I tell which birds keep coming back?
Bird Numbers shows visits and species by day, week or month. Several visits can come from the same species. To see those clips together, filter Recent Sightings by species. Monthly Highlights gives you a recap to save or share.
Can my family watch from their own phones?
Yes. In the Wyze app, go to Account → Sharing → Share With New User. Enter the email they use for Wyze, select your Bird Cam and send the invitation. Once they accept, they can open your feeder from Home in their own account.
What if I only want to send one bird video?
Open the visit in Bird Watch and tap Share to send that clip. The recipient gets the visit you chose. Watching your live feeder takes a separate camera-sharing invitation.
Does Bird Cam record birdsong?
No. Window Bird Cam captures video without audio and has no microphone, speaker, or siren.
Will I be charged when my three included months end?
Every Window Bird Cam includes three months of Bird Watch, whether or not you already have a Wyze plan. There’s no automatic charge when those three months end. If you choose to continue with a paid membership, Bird Watch is $6.99/month per camera. You can keep watching live, share the feeder, get basic bird alerts and record locally with a microSD card.
Do I need the optional perch?
Birds can feed from the included seed tray without it. The optional perch, sold separately, adds another landing spot and more ways to feed. Its fruit fork, suet ball feeder, and jelly cup let you offer fresh fruit, suet, and jelly for a wider variety of visitors.
Does my Cam Plus plan include Bird Watch?
Bird Watch is a separate subscription made exclusively for Window Bird Cam. It isn’t included with Cam Plus or other Wyze security plans.
Can one Bird Watch subscription cover multiple Bird Cams?
Bird Watch is licensed per camera. Each Window Bird Cam needs its own subscription for species ID, cloud visit videos, and the other Bird Watch features.
FREE shipping on orders $0+
