1 of 16
Wyze Lever Lock
Wyze Lever Lock
“To me, this is got to be one of the top of the line fingerprint reading locks out there.”Anonymous
800+ Lockbolt v2 reviews4.5out of 5stars
Color
13M+ Households Trust
$99.98
Use a 5-digit ZIP code.
  • AI-Powered
    Fingerprint Unlock
  • Auto-Lock &
    Tamper Alarms
  • Control Anywhere
    with Wi-Fi
  • Backlit Keypad with
    Anti-Peep
  • Voice Assistance Compatible
  • Open your lock with a key
Colors & Materials
  • Model: WLCKL1
  • Finish: Matte
  • Color: Black
  • Frame Material: Aluminum Alloy & Steel
  • Handle Material: Metal+Plastic front plate
  • Panel Material: Plastic
Dimensions
  • External Assembly: 5.9*2.8*1 inch
  • Internal Assembly: 6.5*2.8*1.3 inch
  • Handle: 5.2*1.7*1 inch
Weight
  • 4lbs
Power
  • Power Source: 8 AA batteries
  • Battery Life: Up to 12 months with normal use (10-20 lock/unlock per day)
  • Emergency Power: USB-C port (USB-C cable not included)
Weather & Operating Temps
  • Weather Resistance: IP54
Operating Temperature
  • Exterior assembly: -4°F-122°F (-20°C-50°C)
  • Interior assembly: 32°F-122°F (0°C-50°C)
  • Storage Temperature: -22°F-158°F (-30°C-70°C)
Connectivity & Compatibility
  • Communication Method: Bluetooth® 5.3, 2.4 GHz Wi-Fi, Wi-Fi 6
  • Compatibility: Wyze app 3.7+, Android 10.0+ or iOS 16.0+
Door Compatibility
Replaces an existing standard lever handle or doorknob on compatible single-bore doors.
Certifications
Certifications: FCC ID+IC, TSCA+CA65, ANSI-BHMA, ROHS, REACH, SVHC, PFAS, IEC62133
Warranty
1-Year
  • Exterior Assembly x1
  • Mounting Plate with Silicone Pad x1
  • Interior Assembly x1
  • Interior Panel Screw x3
  • Lock Hole Adapter Wood Screw x4
  • Mounting Screw x6 (3 long and 3 short)
  • AA Battery x8
  • Interior Handle Screw x1
  • Exterior Handle Screw x1
  • Keys x2
  • Silicone Plug x1
  • Latch x1
  • Dust Box x1
  • Strike Plate x1
  • Drilling Template x1
  • Quick Start Guide x 1
What is the Wyze Lever Lock? It's a smart lever-handle lock with grip-to-unlock fingerprint, a hidden touch keypad, built-in Wi-Fi, and app control. It replaces a standard lever handle on single-bore doors — the doors a traditional smart deadbolt can't fit — at an MSRP of $99.98.
How do I unlock the door? Five ways: fingerprint (grip the handle), passcode on the keypad, the Wyze app, Mechanical Keys and Wyze Doorbell/Alexa/Google Home integration .
How is it different from a smart deadbolt? It's a lever, so it installs on single-bore doors that don't have a deadbolt — garage connection doors, side and back doors, balcony/patio doors, and interior doors like a home office, bedroom, or study. One lock covers both exterior and interior scenarios, at home or for a small business.
How do I know if my door is compatible? Most single-bore US doors without a deadbolt are compatible. If your door has a deadbolt, it may not be compatible
How many fingerprints and passcodes can it store? Up to 50 fingerprints and 50 passcodes — enough for every family member, roommate, or small-business staff member to have their own credential.
How accurate is the fingerprint reader? It uses the same proven biometric engine as Wyze Lock Bolt v2, with a false-acceptance rate under 0.001% and false-rejection rate under 2%. It learns and adapts with every use for faster recognition over time.
Can I share access with family or guests? Yes. You can share this lock to other Wyze users and let them enroll their fingerprints or codes. And you could also create guest profile that allow them to use their fingers or codes, with or without a schedule!
Can I give one-time access to a visitor or service provider? Yes. Generate a single-use passcode for a cleaner, contractor, or delivery that expires automatically after it's used — remote, temporary access with no lasting security risk.
Does it need a separate hub or bridge? No. Wi-Fi is built in, so you get remote lock/unlock, user management, real-time notifications, and event history straight from the app — no extra hub and no monthly fee.
What connectivity does it use? Built-in Wi-Fi 6 (2.4 GHz)
Which voice assistants are supported? Amazon Alexa and Google Home.
Does it work with Wyze doorbells? Yes — it lives in the same Wyze app alongside your Wyze Doorbell for a single, unified experience. You could use your Wyze doorbell to simply lock/unlock directly from the live view.
How long does the battery last? Up to 12 months of typical use on 8 AA batteries. This is tested based on 20 unlock/lock events per day.
What happens if the battery dies — there's no key? You'll get a low-battery notification (around 20%) well in advance. If power runs low, Super Battery Save Mode extends runtime, and there's a USB-C emergency power port on the unit — plug in any power bank to unlock instantly. (The USB-C port is for emergency power only, not for recharging the batteries.)
Will it lose settings when I change batteries? No. Your fingerprints, passcodes, and settings are retained when you swap batteries.
Is it built for outdoor and high-traffic doors? Yes. It's certified to ANSI/BHMA Grade 3 for residential durability and security and rated IP54 against dust and water spray, so it holds up on exposed side, back, garage, and patio doors — not just sheltered interiors.
Does it lock automatically? Yes. Auto-Lock re-secures the door automatically after a set delay.
How does it protect my passcode? Anti-peep codes let you pad your real PIN with random digits so onlookers can't read it, and anti-cracking lockout temporarily disables the keypad after repeated failed attempts.
What warranty does it include? A 1-year limited warranty, backed by Wyze customer support.
it feels so good to
Never Wonder.
Don't take our word for it
13,000,000+
Households trust
Reviews from Lock Bolt v2 customers
Lock Bolt v2
     The smart lock for the doors you actually use
    Most smart locks are built for deadbolts, leaving side doors wondering why front doors get all the nice things. Wyze Lever Lock is for the doors that do the real work.
    Grab the handle. You're in.
    Turn the handle and fingerprint scan at the same time. You won't even break stride. Unlocks in half a second and gets faster over time with fingerprint learning.
    A door with a green light around it.
    Built-in WiFi
    No hub. No subscriptions.
    Wi-Fi 6 is built right into the lock. No hubs, no fees, and no subscriptions.
    A Wyze battery pack with 12 months of battery life.
    12 months
    of battery life,
    maybe way more.
    8 AA batteries included. In testing, they lasted 11.6 months with 20 unlocks a day. But seriously, who's leaving the house 20 times a day? Your mom told us she'd be happy if you left just once.
    Easy install
    Made for simpletons. Phillips screwdriver and an app that walks you through a few simple steps if you need it.
    A person holding a smartphone and a keypad.
    4 ways to unlock fingerprint, app, code, or key.
    Unlike your parents, we’ll admit we have a favorite. It’s fingerprint. Not even close. Second is the app. You can unlock from anywhere in the world. Paris. Tokyo. The couch. Wherever. Third is a code. Great for visitors who haven’t reached the “save your fingerprint in my door” stage of the relationship. Last is the key. A reliable backup. An absolute snooze of a first choice. We didn’t put a fingerprint reader in a door handle so you could stand around conducting an archaeological dig through your purse every day. But it’s there when you need it.
    A person is pointing at a door lock that has a camera on it.
    Guest access and
    one-time codes
    Set up to 50 passcodes with your friends! Yeah right, you don't have 50 friends! But you do know 50 people, even if some of those people are plumbers. Each code can be set to work all the time, on schedules, or one time use.
    A smartphone app that allows for automatic locking of a garage door.
    Auto-Lock
    Are you someone who likes locked doors but doesn't like locking doors? Auto-lock when the door shuts, 10 minutes later, or at the same time every night. You make the rules.
    A hand holding a lever lock 24.
    Premium feel
    Made with premium metal components, both exterior and interior assemblies offer a refined feel with exceptional attention to detail.
    A person is holding a keypad to a door.
    Serious security features
    Anti-peep technology let's you add any digits before or after the code. Finally, a use for the upside-down calculator numbers you still have memorized.
    A black and white image of a door lock with a keypad and a button.
    Left and right orientation
    Your door has preferences. We respect them.
    A black and silver lock on a door.
    Backup entry
    Includes two physical keys and a USB-C emergency power port. Dead batteries? Plug in a computer charger and unlock. Your fake rock can stay in the garden.
    A lock with a green checkmark on it.
    Check before you buy. Please.
    Designed for doors without a deadbolt. If your door has a deadbolt (or a hole for one) this likely won't work. The deadbolt must sit below the lever or at least 5 5/16 inches above it. Otherwise, the deadbolt’s keyhole and the lock’s USB-C port will be blocked.
    Good questions
    Asked and answered
