1 of 15
Wyze Duo Cam Battery Doorbell
Battery 2K Doorbell with Dual Cameras
Color
Style
Add ons
SALE
$138.98 $142.97SAVE 2%
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Wyze Duo Cam Doorbell is our most advanced battery-powered video doorbell yet. Dual camera views for people and packages, 2K video and local storage, two-way audio, real-time AI detections and alerts, and motion-activated voice deterrence. Includes Wyze Wi-Fi Chime and Wyze Removable Battery Pack. You can enable 24/7 local recording when you add a MicroSD card (sold separately) and set up the doorbell with hardwired power.
Two Cameras. Two Views.
2K Color Night Vision
Wi-Fi Chime Included
Battery-powered or Hardwired
    One camera sees people, and another focuses on the doorstep for clearer package detection.
    2K HD Resolution + Color Night Vision
    Our award-winning starlight sensor amplifies low light for color images even at night.
  • A black and white image of a bell.
    Receive notifications anywhere in your home. Compatible with all Wyze Cams and doorbells.
  • Battery
    Eliminate downtime with a removeable and rechargeable battery that lasts up to 6 months.
Wyze Duo Cam Doorbell Specs
Color & Materials
  • Colors: Black/Silver
  • Materials: Plastic body, resin lens
Dimensions
  • 5.90in x 1.88in x 1.18in (150mm x 48mm x 30mm)
Weight
  • 0.92 lbs (416 g)
Video
Video Resolution
  • Front: 2K (2048 x 1536)
  • Bottom: 1920 x 1080
  • Frame Rate: Daytime: 20 FPS / Nighttime: 15 FPS
  • Digital Zoom: 8x
Camera FOV
  • Front camera - Horizontal: 132°,Vertical:100°
  • Bottom camera - Horizontal: 121°,Vertical: 60°
Audio
  • Siren: 90 dB
  • Audio: Two-Way Talk, simultaneous
  • Mic Sensitivity: -42 ± 3 dB
  • Motion Warning: “Hi, you’re currently being recorded.”
Additional Specs
Lighting
  • IR light: 6x 850 nm
Power
  • Port: Micro USB
  • Power: Battery or AC (10-24V AC, 60 HZ)
Storage
  • Local Storage: Supports up to 256 GB microSD in exFAT format
  • Cloud Storage: Stored in the AWS Cloud
  • Battery Capacity: 22.94 Wh, 6200 mAh
  • Battery Type: Lithium-ion
  • Output Voltage: 3.6 V
  • Input Voltage: 5 V DC
  • Charging Port: USB-C
  • Compatibility: Wyze Battery Cam Pro, Wyze Battery Charging Dock, Wyze Duo Cam Doorbell
Connectivity & Compatibility
  • Wi-Fi: IEEE 802.11 a/b/g/n 2.4 GHz & 5 GHz Wi-Fi
  • Bluetooth® 5.0
Weather & Temperature
  • Operating Temperature: -4°F-122°F (-20°C-50°C)
  • Storage Temperature: -40°F-158°F (-40°C-70°C)
  • Weather Resistance: Indoor and Outdoor (IP65)
Certifications
  • FCC, IC, UL, IP65
Warranty
  • 1-year
  • 1x Wyze Duo Cam Doorbell
  • 1x Wyze Wi-Fi Chime
  • 1x Back Plate
  • 1x Corner Kit
  • 1x USB-C Charging Cable
  • 3x Wire Nuts
  • 1x Jump Wire
  • 2x Extension Wires
  • 3x Long Screws
  • 3x Short Screws
  • 3x Expansion Tubes
  • 1x Adhesive Tape
  • 1x Doorbell Detaching Pin
  • 1x Removable Battery Pack
  • 1x Quick Start Guide
It takes ~30 seconds to use the included 3M adhesive to mount the doorbell. Using the included screws to mount it on a door frame takes <1 minute.
No technician is required for installation, even if you choose to use the included hardwired option for your existing doorbell wiring.
Yes, with a microSD card and AC power.
You can enable 24/7 local recording on your Wyze Duo Cam Doorbell as long as you have a microSD card installed, and your doorbell is hardwired. No subscription required! Learn more.
Anywhere near your front door is a great choice since no wires are needed when you go fully wire-free. Make sure the height you choose is comfortable for visitors to press the button on your new doorbell.
Yes, Wyze Duo Cam Doorbell is powered by a removable battery pack. The battery life is 3-6 months with normal use.
Yes, the Wyze Duo Cam Doorbell can be used with Cam Plus, Cam Unlimited, or Cam Unlimited Pro subscriptions. For more information about what these subscriptions unlock, check it out here.
Yes, compatible wiring will allow the doorbell to charge while it’s mounted. Having constant external power will also allow your doorbell to record an additional 3-6 seconds of pre-roll video before an event, allowing you to get the whole picture.
Yes, one Wyze Wi-Fi Chime is included.
Yes, Wyze Duo Cam Doorbell is is IP65-rated for outdoor installation. This means that it is "dust-tight" and protected against water sprays from any angle.
You can adjust the chime sound or volume in the Wyze app.
Two Cameras. Two Views. Double the Porch Protection.
Some is good. More is better. And Wyze Duo Cam Doorbell with TWO cameras and full porch coverage is the punch that'll send porch pirates packing!
Color Night Vision
2K Video Resolution with Color Night Vision
Capture all porch arrivals and departures in greater detail. Our award-winning starlight sensor amplifies low light for vivid color images even at night.
A black and white image of a doorbell camera.
Ding dong from anywhere. Hear alerts exactly where you want in your home. Built-in Wi-Fi enables you to trigger audio alerts with all Wyze Cams and Doorbells.
If you are interested in using Duo Cam Doorbell with your existing mechanical or digital chime, check out Wyze Chime Controller for compatibility.
Take your doorbell to the next level with Cam Unlimited.
A Doorbell Cam Built for AI ✨
A black and blue doorbell camera with a picture of a man on the screen.
Person Detection + Facial Recognition 🧑
One camera sees people to clearly capture every visitor. Get next-level notifications with Facial Recognition so you know when it's your best friend or if it's mom.
Learn more
Package Detection 📦
Another camera looks directly down at your doorstep. And we will tell you the moment your latest package of [REDACTED] arrives, but we can't remove the shame of your subscription.
Learn more
Pet Detection 🐶
Unless your pet is a llama, you know they won’t always show up on your doorbell cam. Now you can spot the furball when they make their way to your front porch. See everything from your door to doormat to doggo.
Learn more
Vehicle Detection 🚗
Utilize the top cam to record each vehicle that stops at your residence. You can monitor a delivery driver from the moment they park in front of your house to when they drop off the package.
Learn more
A person is holding a Wyze Duo Cam Doorbell.
Easy 1-Minute Install
Mount it in two shakes of a dog's tail with the included adhesive strips. No wires or screws. I'm paw-sitively certain you'll have it up in no time. You can also wire it if you really want to.
A sign on a door that says "Please leave the package by the door!
Two-Way Audio
Act like a celestial messenger who knows neither time nor space and answer your door from anywhere. Somehow "Please leave my curly fries right there" feels more dignified when replying via the Wyze app.
A Wyze Duo Cam Doorbell is shown on a white wall.
IP65 Weather Resistant
It's rated to withstand all the elements. Even the element of surprise. In fact, it's basically impossible to sneak up on this thing. Did we mention it has TWO cameras?
A person holding a Wyze Duo Cam Doorbell.
Local Recording with microSD
See what happened start to finish with local recording. MicroSD card sold separately.
⚠️ To enable 24/7 local recording you must add a microSD card and hardwire the doorbell cam.
  • 5.5 GHz WiFi
    Dual-Band Wi-Fi
    Connects to 2.4 GHz or 5 GHz Wi-Fi networks.
  • A person in motion.
    Motion & Sound Notifications
    Get instant notifications sent to your phone for any visitor or package delivery.
  • A black and white image of a 30 degree angle.
    30° Corner Kit Included
    An angled mounting wedge is included with every doorbell to help you achieve the perfect view.
  • Show me the front door.
    Alexa, Google Assistant, IFTTT Support
    Works with your favorite smart assistant. Use Wyze Automations for more control.
1 of 4
Compare Doorbells
Compare Doorbells
Wyze Video Doorbell Pro
from $99.98 $173.98
Resolution
1563 x 1563 (HD+)
Front: 2048 x 1536 (2K) / Bottom: 1920 x 1080
1440 x 1440
2048 x 1536 (2K)
Field-of-View
H: 150°, V: 150°
Front H: 132°, V: 100° / Bottom H: 121°, V: 60°
H: 150°, V: 150°
H: 135°, V: 103°
Chime
Existing + Auxiliary
Existing
Auxiliary
Existing
Power Option
Battery + Wired
Battery + Wired
Battery + Wired
Wired Only
3P Integration
Amazon Alexa, Google Home
Storage
Local & Cloud
Local & Cloud
Cloud Only
Local & Cloud
View
View
View
View
