NOTICE: Wyze Wits is ending as of 4/30/2026. That doesn't mean it won't come back! No further points will be earned starting 4/30/2026. You can still use your earned points for a time. Participants must use their points by 9/16/2026. After that date, all points will be forfeited. If you were all in on Wyze Wits, thank you. We will keep trying to think up awesome programs for our users, such as the Wyzies (check that out here).
  • Sign up for a magical experience.
    Sign Up
    Create a Wyze account or log in, then tap the Rewards bubble to activate your rewards. It’s free, fast, and unlocks your magical journey.
  • A green cart with a blue background that says Place Order.
    Earn Wyze Wits Points
    Earn 5 points for every $1 you spend on Wyze.com or in the Wyze App Shop. You’ll also get points for things like following us on social or subscribing to the newsletter.
  • Wyze Scale S: 3000 Points
    Redeem Rewards
    Redeem your points for discounts, free shipping, and free Wyze gear — from Wyze microSD cards to Wyze Cordless Vacuums, and more.
  • Archmage is a game or product that features a character wearing a hooded robe, possibly a wizard or a mage.
    Level Up!
    Unlock lifetime VIP tiers — Apprentice, Spellcaster, Archmage, and Etherlord — and get bonus multipliers, early access, and exclusive perks as you level up.
1 of 4
The Wyze Wits Tiers.
Wyze Wits has four lifetime VIP tiers—Apprentice (0+), Spellcaster (2,000+), Archmage (10,000+), and Etherlord (50,000+)—based on your total points earned over time. As you climb, you earn points faster and unlock bigger perks like early access, exclusive rewards, and special benefits at checkout.
  • A blue and green star wand with the word apprentice written in white.
    100 Points.
    Your journey begins. Earn points on 5 purchase and action, and unlock your first rewards.
  • Spellcaster is a product that allows users to cast spells.
    2,000 Points.
    Level up your earning with +15% faster points and get occasional early access to drops and special promos (coming soon).
    10,000 Points.
    Serious wizardry. Earn points +35% faster, enjoy priority perks and more frequent early access (coming soon).
  • EtherLord is a product that is displayed on a blue background with a green globe.
    50,000 Points.
    Top of the tower. Earn points 50% faster, get first-in-line access to launches (coming soon) and a Founder-signed wand.
1 of 4
How to Redeem your Wits.
Turn your Wits into gear in a few taps. Pick a reward, apply it at checkout, and you’re done.
  • A screen showing a program to earn points.
    Open the floating Wyze Wits widget.
    Tap the glowing purple "Rewards" widget on the bottom-right of the Wyze.com homepage. Sign in if needed.
  • Free wyze smart scale s.
     Go to How to spend points → pick a reward → Redeem.
    Choose the item or perk you want and redeem it. Your redeemed reward is saved to View your rewards inside the widget.
  • A card with a 32GB microSD card.
    Go to View your rewards → select the reward → Checkout.
    Tap your saved reward and hit Checkout. The reward applies to your order automatically (you can also copy the code from the widget if shown).
1 of 3
FAQs
What is Wyze Wits?
Wyze Wits is our rewards program. Earn points for purchases and select actions, then redeem those points for free products, discounts, and other perks.
How do I join?
Create or sign in to your Wyze account and tap Join Wyze Wits in the floating widget on Wyze.com.
Where do I check my points?
Open the floating Wyze Wits widget (bottom-right on Wyze.com) or go to www.wyze.com/pages/rewards. You’ll see your balance, available rewards, and tier.
When do points show up?
Points for orders post after your payment is captured. If an order is refunded or canceled, related points are removed.
How do I spend points?
Open the widget → How to spend points → pick a reward → Redeem. Your redeemed reward appears under View your rewards. Tap it and Checkout to apply it.
Can I stack rewards?
No—one reward per order. Save others for next time.
Do points expire?
Yes. Points expire 12 months after they’re earned if not used. The widget shows your expiring points if applicable.
Do tiers expire?
No. VIP tiers are lifetime. Once you reach a tier, you keep it.
Learn more
What are the tiers?
Four lifetime tiers: Apprentice (0+), Spellcaster (2,000+), Archmage (5,000+), Etherlord (25,000+) points. (Requirements may change; see wyze.com/pages/rewards for the latest.)
What do tiers do?
Higher tiers earn points faster and unlock priority perks and early access benefits. Your tier is shown at the top of the widget.
Do I earn points on subscriptions?
Not yet— but we are working on it!
Can I earn points in the app and on the website?
Yes. Your points and rewards are shared across Wyze.com and the Wyze app (same account).
Can I use a coupon and a points reward?
Some promotions can’t be combined. If a combination isn’t allowed, the cart will show which option is eligible.
What if I redeemed the wrong reward?
Open View your rewards. If the reward is still unused, you may be able to cancel it to return points to your balance (availability varies). Otherwise, contact Support.
Do free-product rewards include shipping?
If you redeemed Free Shipping, it will apply. Otherwise, standard shipping may apply at checkout (subject to carrier/service selection).
I returned an item—what happens to my points?
Points from the returned order are removed. If those points were already redeemed, the associated reward may be canceled.
Can I transfer or merge points between accounts?
No. Points and tiers aren’t transferable and can’t be merged across accounts.
I don’t see the widget—what should I do?
Make sure you’re signed in, refresh the page, and temporarily disable content blockers. You can also access Wyze Wits via Account in the app.
Will there be more ways to earn?
Yes. We periodically add limited-time and new earn actions. Check the widget’s How to earn points often.
What if my points look wrong?
Give it a few minutes after payment capture. Still off? Contact Support with your order number and a screenshot of your widget balance.
Can my account be flagged for abuse?
Yes. Fraudulent or automated activity, resale intent, or violation of program rules may result in point reversal, reward cancellation, or account closure per our Terms.
Where can I read all the rules?
See the full Wyze Wits Terms & Conditions
Terms and conditions apply, click here for more details.
