1 of 5
Wyze Battery Charging Dock
Charge up to two batteries at once.
Top Accessory
Commonly Bundled Item
⚠️ Battery packs not included with charging dock.
$23.98
Double the fun! Charge two batteries simultaneously with the Dual Battery Charging Dock.
  • Made for Battery Cam Pro Batteries
  • Dual Charging Capability
  • Compact & Convenient
  • Always Have a Battery Ready
Wyze Battery Charging Dock Details
Model Number
  • WYZEDBCD
Color
  • White
Weight
  • 2.75 oz (78 g)
Dimensions
  • Charging Dock: 2.6in x 2in x 1in (58mm x  52mm x 26mm);
  • Power Adapter: 42mm x 40mm x 23mm
Power
USB Cable
  • USB-A to USB-C
Power Cable Length
  • 6 ft (1.8 m)
Fully Charging Time
  • Approximately 8.5h at 25°C/77℉
Power Adapter Input
  • AC100-240V, 50/60Hz
Power Adapter Output
  • DC5V, 2A
Operating Temperature
  • +50℉ to +104℉ (+10°C to +40°C); Humidity < 90%
· Wyze Battery Charging Dock x1
· Adapter Cable x1
· Power Adapter x1
Note: Battery pack not included
The two charging indicator lights on the battery will both turn on once it is fully charged.
Yes, it can.
It takes approximately 8 hours and 30 minutes to fully charge a single battery pack.
A person is pressing a button on a black box.
Charge up to two batteries simultaneously to keep an always-ready power supply that eliminates security downtime.
A person is holding a white device that is plugged into a laptop.
Compact and Convenient
It's designed to be compact with a sleek, white finish to blend in to any space.
1 of 4
Take your Wyze Battery Cam Pro system to the next level
  • Wyze Removable Battery Pack
    Regular price $22.99
    Regular price $22.99 Deal $22.99
    Works with Wyze Battery Cam Pro, Wyze Duo Cam Doorbell and Wyze Palm Lock. Learn More
  • Wyze Solar Panel
    Regular price From $5.99
    Regular price $28.98 Deal From $5.99
    12W Solar Charger for Outdoor Cams Learn More
    Choose your option
    View Options
  • Wyze Universal Camera Mount
    Regular price $9.99
    Regular price Deal $9.99
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
  • MicroSD Card
    Regular price From $18.98
    Regular price $18.98 Deal From $18.98
    Choose your option
Designed for Wyze Battery Cam Pro
