1 of 3
Wyze Chime Controller
Works only with Wyze Video Doorbell v2, Wyze Battery Video Doorbell, and Duo Cam Doorbell.
$17.98
Low stock: 77 left
Use a 5-digit ZIP code.
Free Shipping & 30-day hassle-free returns.
Standalone chime controller unit. Only compatible with Wyze Video Doorbell v2, Wyze Battery Video Doorbell, and Duo Cam Doorbell.
  • Works with Wyze Doorbell v2
  • Works with Wyze Duo Cam Doorbell
  • Works with Wyze Battery Video Doorbell
  • Compatible with Mechanical Chimes
Dimension
  • 47mm x 32mm x 15mm (controller unit body)
Wire
  • 13cm wire
Power
  • AC16V/AC24V,≥10VA
Compatible Products
  • Wyze Video Doorbell V2
  • Wyze Duo Cam Doorbell
  • Wyze Battery Video Doorbell
Work Temp
  • -20ºC - 50ºC
Storage Temp
  • -40ºC - 80ºC
  • 1x Chime controller unit
Wyze Chime Controller is a wired unit that works directly with your existing mechanical chime and is compatible with Wyze Doorbell v2, Wyze Battery Video Doorbell, and Duo Cam Doorbell.
No. This is not a chime device and does not have the ability to audibly notify you when someone pressed the doorbell button. You will need an existing mechanical chime for this controller to work.
Wyze Chime Controller is compatible with nearly every mechanical chime out there, even broken one. Double-check if your existing chime is compatible.
For complex scenarios, please check our controller installation guide prior to purchase.
No, you must have a Wyze Doorbell v2, Wyze Battery Video Doorbell, or Wyze Duo Cam Doorbell.
A black and blue doorbell with a camera attached.
Compatible with Battery Video Doorbell, Doorbell v2 and Duo Cam Doorbell
We all expect our chimes to ring when our doorbell cameras are pressed. With our chime controller unit, you can make new video doorbell technology work with your existing mechanical chime setup.
Works with your in-house chime
Ding dong. Hear alerts exactly where you want in your home with your Wyze cams.
*Note: Wyze Chime Controller works with most mechanical and digital chimes. Not compatible with Wyze Chime plug-in unit.
1 of 4
  • ✅ Compatible WOOHOO!
    Product: Wyze Battery Video Doorbell
    FOV: 150° x 150°
    Resolution: 1536 x 1536
    Chime: Wyze Chime Controller and Wyze Wi-Fi Chime
    Installation: Screw mounting
    Local Storage: Supports up to 256 GB microSD card
    Mounting Location: Requires existing wiring
    Power: Rechargeable 6400 mAH battery or 5V/2A DC/12-24V, 50/60HZ AC Wired
  • A black camera with a blue circle in the center.
    Product: Wyze Doorbell v2
    FOV: 135 x 103°
    Resolution: 2K
    Chime: Wyze Chime Controller (for existing mechnical chimes)
    Power: Wired (AC 16-24 V) only
  • A black and blue circle with a camera on it.
    Product: Wyze Duo Cam Doorbell
    FOV: Top: 132x100°/Bottom: 121x60°
    Resolution: Top: 2K/Bottom: 1080p
    Installation: 3M adhesive or screw mounting
    Mounting Location: Anywhere
    Power: Wyze Removable Battery Pack or Wired (AC 16-24 V)
  • A white and blue device with a blue circle in the center.
    ❌ Not compatible
    Product: Wyze Video Doorbell Pro
    Works with original Wyze Chime.
  • Wyze Cam
    ❌ Not compatible
    Product: Wyze Doorbell (v1)
1 of 5
FREE shipping on orders $0+
