1 of 7
Wyze Cam Vase
Wyze Cam Vase
Discreet. Sleek. Gorgeous.
Top Accessory
Commonly Bundled Item
Style
$58.98 $64.97
Low stock: 62 left
Use a 5-digit ZIP code.
Works with multiple Wyze Cams
Discreet Home Security
Modern Style & Functionality
Quality Material & Design
Combines stunning home decor with practical home security. Pop in your Wyze Cam (v4, v3, or v3 Pro) and effortlessly keep an eye on what matters most without having the camera stick out like a sore thumb.
Who knew security could look this good? With the Wyze Vase, your home stays safe and sophisticated.
    Compatible with Cam v3/v3 Pro/Cam v4.
  • A black background with a white icon.
    Consider this your cam's ninja outfit. The fake grass top seamlessly blends it into any room.
  • A black background with a white logo.
    You don't have to give up stylish home decor when you want home security.
    Made of 100% high quality ceramic. Small plug for cable organization.
Wyze Cam Vase Specs
Color
  • Black
  • Speckled
Material
  • Cement-composite
Dimensions:
  • 3.35in x 3.35in x 4.13in
Weight:
  • 1.08 lbs / 0.49 kg
Compatible With
  • Wyze Cam v4/v3/v3 Pro
Wyze Cam Vase (camera not included)
  • 1x Wyze Cam Vase (Speckled or Black)
  • 1x Faux grass top
Wyze Cam Vase + Cam v4 Bundle
  • 1x Wyze Cam Vase (Speckled color)
  • 1x Wyze Cam v4 (Black)
No, the Cam vase won’t impact your camera’s connection. Its open design and cement material don’t block Wi-Fi signals, so you’ll get the same performance as a standalone Wyze Cam.
No. The Cam vase is precision-designed to fit Wyze Cam v3, Wyze Cam v3 Pro, and Wyze Cam v4 perfectly, ensuring zero visual obstruction and crystal-clear footage.
Yes! The Cam vase designed the hidden wire:
  • A discreet bottom cable hole
  • Elevated 4 silicone feet (creates space to route cords behind)
  • Clean no-visible-wires setup
Not recommended. The Cam vase is compact with a bottom vent (for camera airflow).
Tip: Use faux plants for a lush look!
Cement-composite – Durable yet blends with home décor.
Wyze Cam v3, Wyze Cam v4 models.
The Cam vase is sold separately, but you can grab our Wyze Cam v4 + Vase Bundle! Or pair it with your existing Wyze Cam v3/v4.
It’s tool-free! Just slide your Wyze Cam into the vase’s opening—the snug fit holds it securely. No screws or adhesives needed.
It’s lighter than it looks! (~1.2 lbs / 0.5 kg)—easy to move, but sturdy enough to stay put.
Dress up your Wyze Cam (v3/v3 Pro/v4) as sleek, minimalist décor.
You don't have to pick between security and sophisticated decor.
A WyzeCam is mounted on a wall next to a vase with grass in it.
A small black box with a camera on it.
Unstoppable flair meets reliable security
Whether you're catching cookie thieves or making sure the house is secure, the Wyze Cam Vase does it all discreetly and stylishly.
A black device with a cord plugged into it.
Designed to keep the cables hidden
We thought about the cable management. Run the power to your camera without a tangled mess.
Wyze Cam v4 is a smart camera that offers motion-activated color night vision, two-way talk, and weatherproofing.
Works with your faves
Compatible with Wyze Cam v3, v3 Pro, and v4 devices for seamless functionality.
Grab the bundle.
Style meets substance
Made of high quality ceramic, and it comes with a fancy hair piece lovely faux grass top.
A black square vase with a plant in it.
Support Articles
No, Wyze Cam Vase is not waterproof or weatherproof.
Wyze Cam Vase is for indoor-use only, and should not be exposed to the elements.
To clean the vase: Wipe with a dry cloth.
Wyze Cam Vase is made of a painted cement composite, which naturally hides minor dust and dirt. To clean it, wipe the surface with a dry cloth, no additional cleaners needed.
To clean the included plants: Wipe with a soft, damp cloth, then aid dry.
The included plastic plants can be cleaned with a cloth dampened with fresh water. Let them air dry before reinserting them into the vase.
No, you cannot use real, live plants in Wyze Cam Vase. *sad face*
We know, you want to flex your green thumb and make the most of this tiny vase. But it truly is a small house for your camera, and is does not protect the camera from water or provide any drainage.
We recommend using the included plastic plants, or swapping out with your own artificial plants.
FREE shipping on orders $0+
