Before you begin setup:
- Download the Wyze app on your smartphone or tablet.
- Connect your device to a 2.4 GHz Wi-Fi network.
- Unpack your Wyze Cam v4 removing all plastic and packing materials.Be sure to remove the plastic film from the lens.
- Plug the camera into power using the included USB cable and power adapter.The camera’s status light will turn solid red when powered. When flashing, it’s ready for setup.
To set up your Wyze Cam v4:
- In the Wyze app, tap Home, then tap the + plus sign on the top right.
- On the Add menu, tap Device.
- Tap Cameras > Wired Camera > Wyze Cam v4.
- With your camera plugged into an outlet, tap Next in the app.
- Behind the camera lens, single-press the SETUP button. It will say “ready to connect”.The camera may say “ready to connect” without pressing the SETUP button. If so, continue with setup. Note: Single-pressing the SETUP button does not factory reset, clear data or unbind your Wyze Cam v4.
- In the app, check the box next to I heard, “Ready to connect”.
- Tap Begin Setup.
- If BluetoothⓇ hasn’t already been enabled, you’ll be prompted to allow BluetoothⓇ access. Tap OK.If BluetoothⓇ has already been enabled, it will skip to the next step.
- Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.Tap the icon in the password field to display the password to ensure it was entered correctly.
- After the camera is set up and connected, it will say "setup completed”.
- Tap Next. You’re set up, it’s time to name your device.
- Name your Wyze Cam v4 using the text field, or by choosing a suggestion.
- Tap Finish when done.
- You may have a prompt for a free trial of Cam Plus. Tap Continue.
- Set up some automations on the Things to Try* page, or tap Skip.
- You’re all set. Enjoy your new Wyze device!
