1 of 12
Wyze Cam Floodlight Pro
2.5K Cam with 3000-Lumen Light
Highly Recommended
By Trusted Reviewers
Color
Add ons
$124.98 $185.96
Low stock: 77 left
Use a 5-digit ZIP code.
180 Degree Ultra-Wide
2.5K HD Video
Color Night Vision
Super-Bright 3000 Lumen LEDs
AI-Powered
Motion Tracking
Wyze Cam Floodlight Pro combines a 180° wide-angle lens and 2.5K QHD video so you can see your yard end-to-end in more detail than ever. It relies on evolutionary onboard AI computer vision to detect motion and turns on the adjustable 3,000 lumen LED lights only from objects you select, like people and vehicles. In other words, we created a high-powered security camera with bright lights that thinks and responds like a personal home security guard—no donuts required. 2.4 & 5Ghz WiFi support.
    180° Ultra-Wide Field of View
    Full coverage. No blind spots.
    2.5K QHD Resolution & Color Night Vision
    Capture more details.
    AI-Powered Light Control
    More accurate than PIR.
  • A black image of a product that is used for lighting.
    Dimmable & adjustable.
Wyze Cam Floodlight Pro Specs
Color & Materials
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
Dimensions
  • 10.2 in x 9.1 in x 7.8 in (25.91 cm x 23.11 cm x 19.81 cm)
Weight
  • 2.9 lbs (1.32 kg)
Lighting
  • 3 dimmable light panels with 3000 total lumens of brightness and 5000k color temperature
Power Supply
  • Hardwired 110 - 120V AC
Image Quality
  • 2.5K QHD (2560*1440) with Color Night Vision
Field-of-View
  • 180° Diagonal, 170° Horizontal, 95° Vertical
Frame Rate
  • Daytime: 20 FPS
  • Nighttime: 15 FPS
Storage
  • Up to 256 GB microSD card (Format: exFAT, FAT32)
Audio Siren
  • 105dB (measured at 4 in/10 cm distance)
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4 GHz & 5 GHz dual-band
Weather & Temperature
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
Warranty
  • 1-Year
  • Wyze Cam Floodlight Pro
  • Bracket Screws
  • Mounting Bracket
  • Ground Wire Screw
  • Floodlight Screw
  • Rubber Stopper
  • Wire Nuts
  • Hook
  • Screwdriver
With a 180-degree view, you can set up Wyze Cam Floodlight Pro on a wall or under an eave and get full coverage of the entire front side. That essentially means you can eliminate blind spots.
Traditional motion sensors will sense any movement with heat as motion. Most time we only care about meaningful motions, such as humans or vehicles, not raindrops or falling leaves. Onboard AI motion sensing is more state-of-the-art technology to detect motions. It naturally works well with other AI features to reduce false alarms.
BLE means a fast and easy initial device setup, powered by Bluetooth®. That will save you the hustle of climbing up the ladder and scanning the QR code.
Wyze Cam Floodlight Pro can detect motion up to 30 feet away. Refine the range further with customized detection zones for motion-activated light and event recording.
No, the color temperature is not customizable.
Yes, the floodlight LED is dimmable. The maximum brightness is 3000 lumens.
The image resolution is 2560 x 1440.
Yes, it should connect to a junction box.
Yes, both 2.4 GHz and 5 GHz are supported. Users can select one to connect to meet their needs.
No, Wyze Cam Floodlight Pro requires hard-wired power.
Yes, Wyze Cam Floodlight Pro is IP65-rated.
Yes, Wyze Cam Floodlight Pro has a microSD card slot that allows you to record 24/7 and store videos locally. The microSD card slot supports up to 256GB, formatted as exFAT or FAT32.
Note: A MicroSD card is not included. To purchase one, consider checking out Wyze's MicroSD cards.
When motion is detected during the scheduled time of the day, the floodlight turns on for a customized period of time and turns off. The motion type and schedule are customizable. Users can enable/disable this motion-activated light in the Floodlight Setting in the Wyze app. Note that the motion-activated light is enabled by default with a schedule from sunset to sunrise. Detection zones can be customized in the Wyze app as well.
Ambient light mode keeps the Wyze Cam Floodlight Pro's LEDs illuminated softly between motion detections during the scheduled time of day. Users can enable this in settings within the Wyze app, and then customize the brightness and schedule for this mode—the default is 10% brightness from sunset to sunrise.
Motion Warning is a security feature to warn and deter intruders. With this feature enabled, when a Person is detected, the camera speaker will play a voice clip every 10 seconds, announcing that the intruder is currently being recorded.
No, you cannot.
Wyze Cam Floodlight Pro does not offer the ability to add/power additional cameras. Its increased 180° field-of-view and 2.5K resolution offers more coverage in greater detail. Gone are the days of needing to check multiple live streams or getting duplicate notifications from the same motion. If you need an additional port, to power a second camera, please consider checking out our Wyze Cam Floodlight.
See it all in frame with the widest view in the game.
A pro floodlight category-leading 180° field-of-view means you can protect your property from end-to-end with fewer blind spots.
Capture more details with 2.5K QHD resolution + Color Night Vision.
See images and video in greater detail with Quad High Definition clarity. Day or night you get video so crisp it makes bacon jealous. Mmm, bacon.
A patio with a fire pit and a wooden deck. A backyard at night with a fire pit and a patio set.
Day
Night
More accurate motion-activated lights powered by vision AI.
Goodbye, clumsy PIR technology. Onboard AI computer vision detects motion and turns on the lights only for objects you select, like people and vehicles. Plus, get notifications sent to your phone.
A light is shining on a door.
Beams ultra-brightly to banish bad guys.
Adjustable and dimmable LEDs blast up to 3000 lumens of guiding or "get lost" security light. Three independently articulating panels let you customize light coverage to meet your needs.
Brighter in more ways than one.
Wyze Cam Floodlight Pro packs a few all-new tricks up its sleeve.
A comparison of two lighting options, one being motion-activated brightness.
Ambient Light Mode.
When enabled, it provides constant ambient lighting and automatically switches to increased brightness when motion is detected. It's like a reverse night light for crooks and creepers.
A person is being recorded.
Motion-Activated Voice Deterrence.
From in-laws to outlaws, the voice prompt that plays only when a person is detected and the built-in 105 dB siren are sure to deter all kinds of unwanted visitors.
A white camera with a blue background.
Stay connected with dual-band Wi-Fi.
Connecting your floodlight is easy and faster than ever with dual-band Wi-Fi that supports both 2.4 and 5 GHz networks.​
A bright light is shining on the side of a house.
A bright light on the side of a house.
A light on the side of a house.
A bright light on a house.
A smartphone displaying a live feed of a driveway.
A smartphone screen with a message about pairing with a device.
A smartphone with a message on the screen.
More Floodlight Pro greatness
Wyze Cam Floodlight Pro knows when the sun is down and when it’s up. Just hook it up and never think about your light switch again.
Did you know the river otter is the most weatherproof animal? And did you know Wyze Cam Floodlight Pro is also a beast at repelling the elements? Plus, it is equally as cute in its own three-headed way.
Capture and view up to 30 days with a 256GB microSD card (sold separately).
No more QR code scanning. Setup is quick and easy with BluetoothⓇ.
Surprisingly super simple self-installation. Seriously.
Easy installation. Replace your existing floodlight in under 20 minutes with our easy DIY installation guide. Check out the video below to see for yourself.
A white camera with a floodlight plugged into it.
Add a floodlight plug-in mount if you prefer a power outlet.
Skip the electrician appointment! By following some simple instructions, you can now totally DIY install a floodlight camera. No need for a junction box or pesky power lines. Learn more.
Perfect for those with a handy outdoor outlet open and renters.
Shop now
Compare Floodlights
Compare Floodlights
Wyze Cam Floodlight Pro is a 2.5K QHD camera with a 180 wide-angle lens and 3000-lumen light.
from $124.98 $149.98
Wyze Cam Floodlight v1 - A powerful outdoor security solution with a built-in floodlight for increased visibility and.
from $79.99 $93.99
Camera Resolution
2.5K
2K
1080p
Field-of-View
180°
160°
130°
Lumens
3000 lm
2800 lm
2600 lm
Floodlight Heads
Color Temperature
5000K
5000K
5000K
Wi-Fi Connectivity
2.4/5 GHz Dual-Band
2.4 GHz
2.4 GHz
Vision AI Light Control
With Cam Plus Subscription
Motion Detection
Vision AI
PIR
PIR
Sirens
105dB
105dB
105dB
Ambient Light Mode
Motion Warning
Device Setup Mode
Bluetooth®
Wi-Fi
QR Code
IR Lights
12 x 850nm
6 x 850nm
4 x 850nm, 4 x 940 nm
MicroSD Card Compatibility
Up to 256 GB
Up to 256 GB
Up to 256 GB
Power Supply
Hardwired 110-120V
Hardwired 110-120V
Hardwired 110-120V
Smart Integrations
Amazon Alexa, Google Assistant, IFTTT
Certifications
FCC, UL, CE, IC, IP65
View
View
View
Support Articles
Before you begin setup, make sure you have completed the installation steps for your Wyze Cam Floodlight Pro.
👉 Depending on the location of your junction box, a ladder may be required.
To set up your Wyze Cam Floodlight Pro:
  1. After completing the installation process in the Wyze app, tap Begin Setup. Floodlight not installed? Follow the steps listed in our Wyze Cam Floodlight Pro Installation Guide before beginning setup.
  2. Make sure that the status light under the camera changes from solid red to either flashing purple or solid blue. This may take up to 2 minutes. If the light does not turn on or update, press and hold the setup button on the back of the camera for 10 seconds to reboot.
  3. Check the box next to Light turned to flashing purple or solid blue then tap Next.
  4. Wait for a voice prompt. You should hear “ready to connect”. If there is no voice prompt within 2 minutes, press and hold the setup button on the back of the camera for 10 seconds until the status light turns red to reboot.
  5. Check the box next to It said, “Ready to connect.” then tap Next.
  6. If BluetoothⓇ hasn’t already been enabled, you’ll be prompted to allow BluetoothⓇ access. Tap OK. If BluetoothⓇ has already been enabled, it will skip to the next step. Setting up multiple floodlights at once? Select the last 4 digits of the floodlights’ MAC addresses. The MAC address can be found on the side of the floodlight’s base.
  7. Select your 2.4 GHz or 5 GHz Wi-Fi network and enter your network password. Tap Next. Tap the icon in the password field to display the password to ensure it was entered correctly.If your floodlight location is far from your router or there are multiple walls between them, we recommend selecting your 2.4 GHz Wi-Fi network.
  8. Name your Wyze Cam Floodlight Pro using the text field, or by choosing a suggestion. Tap Finish when done.
  9. You are all set! Your floodlight is set up and ready to go. Tap Done.
  10. You may have a prompt for a free trial of Cam Plus. Tap Continue.
  11. Set up some automations on the Things to Try* page, or tap Skip.
  12. If you want to share your device, tap Share Device. If not, tap Maybe Later.
This guide is a short user manual with the basics about Wyze Cam Floodlight Pro, including:
  • What is included in the box.
  • How to set up the floodlight.
  • Where to install the floodlight.
  • How to do a ceiling/overhang mount.
  • How to do a wall mount.
  • How to understand the status lights.
The Sharing feature lets other people access and use your Wyze Cam Floodlight Pro. Have a family member or other close friend who wants to check on the floodlight? You can share it with them right from the Wyze app.
Important: Only share your Wyze devices with people you know and trust.
To share your Wyze Cam Floodlight Pro:
  1. In the Wyze app, tap on your Wyze Cam Floodlight Pro.
  2. Tap the settings gear to open your device settings.
  3. Tap Sharing, then Share with a new user.
  4. Enter the email address of the person you want to share your floodlight with. Or, select someone from your Recent Shares list.
  5. Tap Share.
What can a shared user do?
Shared users will be able to:
  • View the live stream and Event videos.
  • Record the live stream.
  • Turn notifications on/off.
  • Create Automations.
  • Use 2-way audio.
  • Turn the siren on/off.
  • Use the manual Take Photo and Record buttons.
  • Turn the floodlight on/off.
  • Turn Night Vision on/off.
  • View the Device Info.
  • Remove the device from their Wyze app.
Shared users will not be able to:
  • Share a device shared with them.
  • Rename a device shared with them.
  • View microSD card footage.
Keep in mind:
  • You can share your Wyze Cams with up to 250 users.
  • There is no limit to the number of Wyze devices you can share.
  • The sharing feature is set per device. To share multiple devices, you'll have to invite users to each manually.
FREE shipping on orders $0+
