1 of 14
Wyze Battery Cam Pro
2.5K Outdoor Cam with Spotlight
No power outlet or electrician needed. Turn this wireless cam into a solar security cam by adding a Wyze Solar Panel.
Color
Pack
Accessory
SALE
$99.98 $179.96SAVE 44%
NEW Bird Detection
Great news for Wyze Battery Cam Pro owners. Bird Detection is now available with Wyze Security Plans. Test it with a Cam Plus trial.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
  • 2.5K HDR Video Resolution
  • Wire-Free, No Hub required
  • Integrated Spotlight & Siren
  • Radar + PIR Motion Detection
  • Removable, Rechargeable Battery Packs
  • IP65 Weatherproof
  • 2.4 & 5Ghz WiFi Support
  • Wireless page.
    Outdoor/Indoor. Wire-Free. No Hub.
    Place it anywhere with hassle free setup.
  • A colorful logo of a person holding a shield.
    2K HDR Video with Color Night Vision
    Capture more details with enhanced video.
    Double the sensors for more accurate detections.
  • Battery
    Removable Battery Packs
    Swap and recharge to eliminate security downtime.
Color & Materials
  • Color: White
  • Finish: Matte finish
  • Mechanical Structure: PC plastics
  • Camera Lens: Optical glass
  • Camera Weight (lbs): 0.94
  • Dimensions (Inches): 2.5 x 1.8 x 3.5
Additional Details
  • CPU Speed: 500 MHz
  • Memory: 128 MB RAM
  • Mounting Methods: 1/4” - 20 standard
  • Wall mount: Included (short mount)
  • Wall Mount Dimensions: 2 in x 2 in x 2.2 in
    Wall Mount Weight: 1.5 oz (44 g)
Certifications: FCC, IC
Drywall anchors
  • Wall anchors
  • Length: 28.7 mm
  • Width: 5.5 mm
  • Drill bit size: 7/32
Screw Assembly
Philips screws
  • Length: 29.5 +- 1 mm
  • Width: 2.9 mm
  • Drill bit size: 3/64
Power
  • Power Cable Length
  • USB-A to USB-C Cable, 0.5m
  • Power Adapter: 5V, 2A (NOT INCLUDED)
Battery Pack
  • Capacity: 6200mAh
  • Charging Time: Approximately 9 hours
  • Battery Life: Up to 6 Months
  • Technology: Li-Ion
  • Connector: USB-C
  • Image Sensor: CMOS-Starlight Sensor (2560 x 1440)
  • Lens: F1.6
  • Digital Zoom: 8x
  • Field-of-View: 134°(DFOV), 108°(HFOV), 56°(VFOV)
  • Night Vision: 2 IR LEDs (850 nm), 2 White LEDs (5500K, 187 lumens)
Video
  • Daytime: 15 FPS
  • Nighttime: 15 FPS
  • Video Resolution: 2560 x 1440 (2.5K)
  • Video Encoding: H.264
Connectivity & Compatibility
  • Bluetooth: BLE 5.1
  • Wi-Fi: 2.4 GHz and 5 GHz, 802.11a/n/g/b
Audio
  • Microphone: MEMS Digital Mic
  • Two-way Audio
  • Built-in speaker and microphone
  • Noise and echo cancellation
  • 2-way Simultaneous
    Siren, 100 dB SPL @ 0.1m
Weather & Temperature
  • Weather Resistance: Indoor and Outdoor (IP65)
  • Operating Temp: -20°C to +50°C (-4°F to +122°F), Humidity < 90%
  • Storage Temp: -40°C to +50°C (-40°F to +122°F), Humidity < 90%
Storage
  • Local Storage: Supports up to 256 GB microSD cards
  • Cloud Storage: Record to the cloud with Cam Plus
  • x1 - Wyze Battery Cam Pro
  • x1 - Wall Mount
  • x1 - USB-C Cable
  • x1 - Battery Pack
  • x3 - Screw Assembly
  • x1 - Quick Start Guide
Note: Power Adapter is not included
No, you can set up your camera directly on your 2.4 Ghz or 5 GHz home Wi-Fi network and start using your camera in minutes.
No, it’s not compatible with Wyze Base Station.
With normal use, a battery pack should last up to 6 months before recharging. Alternatively, you can purchase additional battery packs to swap as needed.
You can use the included standard 1/4" - 20 metal wall mount or purchase our Wyze Universal Metal Mount accessory for ceiling mounting. It's not compatible with the magnetic base mount on Wyze Cam Outdoor.
Yes! Continuous or motion-only local recording is available. Keep in mind that these features may greatly shorten battery life.
Learn more on how to use a MicroSD card with your Battery Cam Pro.
The fusion of radar and PIR eliminates false alarms caused by extreme weather conditions like heavy rain, snow, or intense heat. The radar sensor detects the distance of objects in front of the camera, providing precise information about detected motion to reduce unwanted alerts.
It takes approximately 9 hours to fully charge the battery.
Yes, you can use the camera normally while it's charging.
Yes, you can purchase the Wyze Solar Panel with an included USB-C adapter cable. Alternatively, you can purchase a USB-C cable if you bought the original solar panel on or before May 2023.
Yes it is.
Yes it is the same battery pack with 6200 mAh capacity.
Feature Highlight: Local recording (with a MicroSD card) is available for Battery Cam Pro
Weatherproof wire-freedom for all.
No wires. No hubs. It's the ultimate battery operated go-anywhere, see-everything home security camera. Get pro-grade protection precisely where you need it most.
1 of 5
Shop Wyze Battery Cam Pro Accessories
  • Wyze Removable Battery Pack
    Regular price $22.99
    Regular price $22.99 Deal $22.99
    Works with Wyze Battery Cam Pro, Wyze Duo Cam Doorbell and Wyze Palm Lock. Learn More
  • Wyze Battery Charging Dock
    Regular price $23.98
    Regular price $23.98 Deal $23.98
    Charge up to two batteries at once. Learn More
  • Wyze Solar Panel
    Regular price From $5.99
    Regular price $28.98 Deal From $5.99
    12W Solar Charger for Outdoor Cams Learn More
    Choose your option
    View Options
  • MicroSD Card
    Regular price From $18.98
    Regular price $18.98 Deal From $18.98
    Choose your option
    View Options
  • Wyze Universal Camera Mount
    Regular price $9.99
    Regular price Deal $9.99
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
Capture more details with 2K HDR & Color Night Vision.
Day or night, every detail matters. Wyze Battery Cam Pro utilizes high dynamic range for balanced images with richer colors.
Integrated light. Intruder flight.
Light up potential intruders with 150 lumens of LED, motion-activated light. You can also manually control the spotlight in the Wyze app for extra security while you’re walking the dog at night.
Radar + PIR = A motion detection superstar.
Double the motion sensors means double the "Gotcha!" Radar and PIR combine for earlier and more precise detections. Set custom detection zones in the Wyze app for location specific notifications.
Get even smarter detections with Cam Plus.
The power to protect.
Wyze Battery Cam Pro has flexible power & mounting options.
A white toothbrush with a red button on the side.
Removable battery packs.
Taking down your camera to charge it is as tedious and wearisome as cleaning an airport urinal. Easily hot-swap battery packs and eliminate security downtime.
Add to Cart
A person is pressing a button on a black box.
Ready power with Wyze Battery Charging Dock.
Charge up to two battery packs at once with Wyze Battery Charging Dock. Sold separately.
Add to Cart
A solar panel is attached to a house.
Turn your cam into a Solar Powered Security Camera in seconds.
Nothing says, "I'd like to keep living on planet Earth" like a solar panel. Convert sun rays into power so you can leave your camera up longer with less frequent charging.
Add to Cart
A white camera with a black background.
Ceiling setup with Wyze Universal Mount.
Need to keep an eye high in the sky? Wyze Universal Mount has a longer stem for a flexible ceiling mount option. Required when mounting Wyze Battery Cam Pro to a ceiling or under an eave.
Add to Cart
Battery Cam Pro can locally record to a microSD card.
Never miss a moment and record motion events locally to a microSD card, no subscription required. Enabling this feature impacts battery life.
A white camera with a blue light on it.
A white and blue box with a 5GHz label on it.
Connecting device
A smartphone screen with a search bar for a device.
No running by the pool!
More Pro features you'll love.
Drip. Splash. Plop. No matter the weather, this camera cannot be stopped.
No more QR code scanning. Setup is quick and easy with BluetoothⓇ.
Talk (or yell) to anyone easily with a built-in microphone and speaker.
Up and monitoring in minutes. Watch how 👇
