Skip to content
1 of 13
Outdoor Security Pro
What's in this bundle
$389.92
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Get powerful protection for your entire yard with the Outdoor Security Plus – Wireless kit. This bundle includes THREE Wyze Solar Cam Pan units and a Wyze Cam Floodlight v2, giving you wide-angle monitoring, bright motion-activated lighting, and uninterrupted solar-powered coverage.
Wyze Solar Cam Pan (x3) delivers smooth 360° pan and 180° tilt movement with solar charging for year-round, battery-free operation. Perfect for monitoring large outdoor spaces, tracking motion, and keeping watch from any angle—without running a single cable.
Wyze Cam Floodlight Pro lights up dark areas with powerful LED illumination while capturing clear, detailed video. Advanced motion detection and wide-area coverage help deter intruders and keep your property fully visible at night.
Together, these devices create a flexible, wireless outdoor security system that provides full visibility, strong deterrence, and reliable power anywhere you need it.
Wait & Save - Overstock Savings
Wyze Cam + The Sun. Love at first light.
Let the sun do the work. ☀️ An integrated high-efficiency ETFE solar panel delivers continuous power to the battery with one hour of sunlight per day.
360° pan/tilt coverage with AI-powered person tracking.
Edge AI detects and locks on to people, following them wherever they go. Secure an entire space with pan and tilt coverage. Control remotely via the Wyze app to see exactly what you want.
Flexible solar panel mounting.
Connect the solar panel on top of the camera for a tidy install. Or place it separately where the sunlight’s strongest for maximum charging power. The choice is yours.
Cloudy days? No sweat.
Does the sun like to hideout for a while where you live? No worries. The built-in 6400mAh lithium-ion battery provides up to 6-months of standalone power.
2K HD Resolution with WDR
Crystal-clear video recording with a wide field-of-view captures every detail, day or night. Wide Dynamic Range (WDR) evens out the brightest highlights and the darkest shadows so nothing gets lost.
Motion-activated spotlight & siren.
Deter intruders or light your way home with a motion-activated spotlight. Activate the loud 105dB siren for extra security.
See it all in frame with the widest view in the game.
A pro floodlight category-leading 180° field-of-view means you can protect your property from end-to-end with fewer blind spots.
Capture more details with 2.5K QHD resolution + Color Night Vision.
See images and video in greater detail with Quad High Definition clarity. Day or night you get video so crisp it makes bacon jealous. Mmm, bacon.
Day
Night
More accurate motion-activated lights powered by vision AI.
Goodbye, clumsy PIR technology. Onboard AI computer vision detects motion and turns on the lights only from objects you select, like people and vehicles. Plus, get notifications sent to your phone. No subscription required.
Beams ultra-brightly to banish bad guys.
Adjustable and dimmable LEDs blast up to 3000 lumens of guiding or "get lost" security light. Three independently articulating panels let you customize light coverage to meet your needs.
