1 of 6
Wyze Garage Door Controller
Control and view your garage door remotely.
Style
$18.99
Item is no longer available.
The world's first AI vision-sensing, smart garage door controller. Remotely control your garage and see what's going on in 1080p HD clarity with the award-winning, color night vision of Wyze Cam v3.
*In order to comply with UL325 labeling requirements, this controller-only pack is intended to be used as a replacement part with the Wyze Cam v3 you previously received when you purchased the Wyze Cam v3 + Garage Door Controller Bundle. While any Wyze Cam v3 will technically work with the Garage Door Controller Unit, a Wyze Cam v3 purchased separately does not include the required garage door warning labels. **We do not recommend using this product as the sole method for accessing your home.
  • A black remote control with a white icon on it.
    Control your garage door remotely
  • A black camera icon.
    View your garage in 1080p HD
  • Door alert icon.
    Get notified when the door is left open
  • Existing alt: lock bolt icon
    Compatible with most garage openers
  • Indoor/Outdoor Usage: Indoor
  • Brand: WYZE
  • Connectivity Technology: Wired
  • Recommended Uses For Product: Indoor
  • Room Type: Garage
  • Power Input: 5V DC, 2A
  • Wi-Fi: 802.11/b/g/n, 2.4GHz
  • Check compatibility here
The Wyze Garage Door Controller meets UL325 standard and passes all UL325 test, it is ETL-listed. Other certifications include: FCC, California65, TSCA.
Cam v3 & Garage Door Controller Bundle
  • Wyze Garage Door Controller x1
  • Wyze Cam v3 x1
  • QR Code Sticker x1
  • Micro USB Cable Splitter x1
  • Warning Placard x1
  • 5V 2A Power Adapter x1
  • 5V 2A Power Cord x1
  • Wyze Cam v3 Parts x1
  • Adhesive Mounting Sticker x1
  • Cable Clips x3
  • Quick Start Guide x1
Garage Door Controller Replacement Part Kit
  • Cable Clips x3
Wyze Cam v3 Garage Door Controller Bundle is the first AI-based garage-controlling camera system on the market. With this product, you can view and control your garage door remotely! The controller is easy to install and connects to your existing garage door opener and the included Wyze Cam v3 via wires. The bundle package includes a Wyze Cam v3, a garage door controller module, and all the necessary parts you will need.
With this product, you can not only control your garage door but also view what is happening in real-time in the garage remotely via the Wyze app. Seeing is believing. This product is an ultimate smart garage control retrofit solution that gives you real peace of mind for access control of your home garage.
No, your garage door controller must be set up with a Wyze Cam v3 to control the garage door. It is an accessory product for Wyze Cam v3.
This product is very easy to install and set up. It will take about 10-20 minutes for installation and setup in most cases.
No, Wyze Garage Door Controller is compatible with most but not all garage door opener models. We highly recommend you use our online compatibility checker before purchasing. www.wyze.com/garage-controller-compatibility
No, Wyze Garage Door Controller is currently only designed to work with Wyze Cam v3. We may support more camera models in the future but won't promise it at this time.
Your Wyze Cam v3 Garage Door Controller can only control one garage opener motor. If you have multiple doors, you will need multiple controllers and cameras.
No, Wyze Garage Door Controller is designed for indoor-use only.
Yes, you will be notified when your garage door is opened and closed. You can also be notified when the door is left open for your chosen amount of time. You can always turn the notifications off in Settings if you would prefer not to have them.
Yes, all garage door movement will generate a notification and be recorded. This includes methods for controlling your garage door other than the Wyze app.
Your Wyze Cam v3 uses the QR code sticker and AI technology to detect the open/closed status of your garage door. This allows us to provide features like garage door notifications, door event history, scheduling, etc.
Wyze Garage Door Controller Replacement Part Kit includes everything from the Wyze Cam v3 Garage Door Controller Bundle except the Wyze Cam v3.
In order to comply with UL325 labeling requirements, we can’t claim that the controller-only pack can work with any Wyze Cam v3 because we don’t have the required garage door warning message printed on the existing Wyze Cam v3 packages. For legal reasons, this is us telling you this product is only to be used with a Wyze Cam v3 that came in the original Wyze Garage Door Controller bundle package. These replacement parts are available in case you need to replace pieces of the Wyze Garage Door Controller Bundle that you definitely previously purchased. We’d never tell you to use this with a regular Wyze Cam v3. Those warnings that tell you about the dangers of operating garage doors are a necessity...
Yes, you are still able to use your existing openers, remote, in-car HomeLink button, and keypad.
The Wyze Cam v3 from the garage door controller bundle is slightly different from a standard Wyze Cam v3. The USB cable design now has a signal shielding layer to avoid possible interference with garage door clickers. This garage door controller version of Wyze Cam v3 has a round-shaped USB cable in the back, while the standard Wyze Cam v3 has a flat-shaped USB cable. Other than that, all other parts and specifications are exactly the same. If you use a Wyze Cam v3 with a flat-shaped USB cable, please mount the camera further away from the garage opener antenna to avoid signal interference.
If you do not have a second entryway into your home outside of your garage, we do not recommend Wyze Garage Door Controller.
No. It is not compatible with garage doors made of reflective materials and will not calibrate correctly.
Control and view your garage from anywhere.
Whether you're letting someone in or trying to keep others out, you can remotely view, open, or close your garage door with just a tap in the Wyze app.
A hand holding a phone with a Wyze app open.
A hand holding a phone with the Wyze app open.
Wyze Cam knows if your garage is open. No sensors required.
Other smart controllers require battery-powered sensors or complicated sensor wiring to work. Wyze Garage Door Controller uses AI vision-sensing on the Wyze Cam v3 to know whether your garage door is open or closed. No hassle required.
A green bicycle is parked in a garage.
A green bicycle parked in a garage.
Garage Door Open Notification
Get notified when your garage door is left open.
Forgot to shut the garage door?
We'll notify you if your garage door was left open or if someone is opening or closing it.
Garage Door Events Calendar on phone.
Know when your garage door was opened or closed.
Easily find the exact time of day your garage was opened, left opened, or closed.
Uses your existing garage door equipment. Installs in minutes.
No need to replace your garage door opener, Wyze Garage Door Controller works with your existing equipment and installation is a breeze. Check compatibility here.
A white camera with a black lens.
View. Record. Repeat.
Stream 1080p HD video in full color, even at night, with the included, award-winning, Wyze Cam v3.
Get notified when motion is detected, record 24/7 with local microSD storage, even set off a mini-siren to scare off intruders.
A garage door that is closed.
Scheduling and automation.
Schedule your garage door to close automatically if you accidentally left it open and create automations that make life easier.
A gray Amazon Echo device.
Three white cameras in different positions.
Plug your USB cable into the USB port on your device.
Even more features to love.
Use your voice to open or close your garage door with Alexa or Google Assistant.
Aim the camera to wherever you need it. If you mount the camera upside down, you can easily flip it right side up in the Wyze app.
Installation is easy in the Wyze app. We include simple, step-by-step instructions with illustrations for a painless installation process.
We did our homework...
Here's everything critics disliked about other brands of smart garage door controllers.
  • Competitor Who Shall Not Be Named #1
    ❌ Extra $120 for camera
    ❌ Requires bolting a bracket onto your ceiling
    ❌ Not compatible with Amazon Alexa
    ❌ Battery sensor required
  • Competitor Who Shall Not Be Named #2
    ❌ Unintuitive installation
    ❌ No camera option
    ❌ Extensive wiring required
    ❌ 2-part door sensor
  • Competitor Who Shall Not Be Named #3
    ❌ Expensive
    ❌ No camera option
    ❌ Frustrating setup
    ❌ Pairing issues with door sensors
    ❌ Parts in the box don't match
1 of 3
and we listened.
✅ Award-winning Wyze Cam v3 included
✅ No complicated wiring
✅ No battery powered sensors
✅ No bolting brackets or screws required
✅ Alexa and Google Assistant compatible
FREE shipping on orders $0+
