1 of 10
Wyze Cam v4
Wyze Cam v4
The cam to support American workers 🇺🇸
This item will not be made in America, but your $100 will send us a clear signal that customers are willing to spend $100 and we should indeed move our factories to America. 🇺🇸
$100
Arrives in 2-2000 days!
We’ve received a lot of feedback online to "Just make cameras in America!"
Good news! Now you can pay $100 for a Wyze Cam, just like you would if we made it in America. For every camera we sell, we will find a random American factory worker, assuming we can find some, ask for a DNA test to make sure they are 100% American, and then give them $64.02 which they can spend back into the American economy.
Want regular-priced Wyze Cam v4? You're in luck, you can still get it here.
    2.5K QHD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • A black and white image of a weather icon.
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
    Motion-Activated Spotlight
    Automatically trigger the LED light and voice prompt for extra security.
  • A purple and white shield with a white background.
    Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
Colors & Materials
  • Colors: White and Grey
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
Dimensions & Weight
  • 2in x 2in x 2 3/8in
  • 0.49 lb (222 g)
Mounting
  • Stand, wall mount, ceiling mount,
    or magnetic wall mount (adhesive)
Power
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Outdoor Power Adapter (sold separately)
  • Cable: 6-Foot Flat micro USB to USB-A
Video
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Color Night Vision: Yes
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio
  • Speaker: 99dB, waterproof
  • Simultaneous 2-way Talk: Yes
  • Built-in Siren: Yes
  • Noise & Echo Cancellation: Yes
Connectivity & Compatibility
  • Bluetooth® 5.2
  • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
Storage
  • Local (microSD card required)
  • MicroSD card up to 512 GB
  • Cloud (with subscription plan)
Weather & Temperature
  • IP65 weather resistant
  • Operating temp: -4ºF - 122ºF (-20ºC - 50ºC)
  • Storage temp: -40°F - 158°F (-40°C - 70°C)
Warranty
  • 1-Year
Included in a 1 pack:
  • Wyze Cam v4 x1
  • Quick Start Guide x1
  • Wall Mount Plate x1
  • Wall Mount Plate Tape x1
  • Screw Kit x1
  • Indoor USB Power Adapter x1
  • 6-Foot Flat micro USB to USB-A cable x1
Note: The camera and USB cable will be either white or grey, depending on the colorway chosen.
Yes! And you'll get a white Wyze Cam v4 too.
Wyze Cam v4 is our best camera yet, with super-clear, 2.5K QHD resolution and enhanced Color Night Vision. Our new audio technology now removes harsh and static sounds better than ever before. You can use Wyze Cam v4 indoors and outdoors, and use its built-in spotlight and Motion Warning feature to deter intruders. With Wi-Fi 6 capabilities, you can get better connectivity, and with Smart Focus on the Live stream, you can catch important details in motion while still viewing the bigger picture.
Wyze Cam v4 is a wired camera. It is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam v4 is IP65-rated and can be used both indoors and outdoors.
2.5K QHD (2560x1440).
A young boy flexing his arm in front of a map of the world.
Wyze Cam v4 with WDR
No WDR
Wyze Cam v4 Main 06.
ip65 weather resistance
Place it anywhere.
Enhanced two-way talk
Clearer conversation.
Integrated Spotlight + Siren
More safety at night.
A Wyze Cam v4 microSD card.
Record every second
Record 24/7 locally with a microSD card up to 512 GB (sold separately). Add AI alerts and cloud backup with Cam Plus.
1 of 4
A woman holding a cell phone with a Wyze Cam v4 on a table.
Connect with bluetooth®
Easy to set up.
Screw-free magnetic mount
Easy to mount.
A Wyze Cam v4 is displayed on a wooden table.
Works with smart assistants
AUTO-ZOOM WITH AI
Track with Smart Focus.
A green circle with a Wyze Cam v4 inside.
Even more features to love.
  • A small camera with a blue light on it.
    Wyze Cam v4 NEW
    Colors: White or Grey
    Finish: Textured Matte
    Resolution: 2.5K QHD w/ our best color range (WDR)
    Field of view: 115.9° (D) x 98.5° (H) x 53.1°(V)
    Night vision: B&W + Enhanced Color Night Vision
    Sound: Enhanced Two-Way Talk
    Siren: 99 dB
    Spotlight: ✓
    Notification speed: Advanced
    MicroSD card support: Up to 512GB
    Released: 2024
    Ready to buy?
  • A small camera with a white base.
    Wyze Cam v3 Pro
    Colors: White
    Finish: Matte
    Resolution: 2.5K
    Night vision: B&W + Color Night Vision
    Sound: Two-Way Talk
    Siren: 89 dB
    Spotlight: ✓
    MicroSD card support: Up to 256GB
    Released: 2022
    Learn more
    Wyze Cam v3
    Colors: White, Black, or Limited Edition Blue
    Finish: Matte
    Resolution: 1080p
    Field of view: 121° (D) x 102° (H) x 54°(V)
    Sound: Two-Way Talk
    Siren: 80 dB
    Spotlight: No (spotlight kit sold separately)
    Notification speed: Standard
    Released: 2020
    Learn more
1 of 3
