Skip to content
1 of 8
Wyze Cam v3
Wyze Cam v3
1080p Weatherproof Camera with Audio
1080p HD
Capture it all in HD
IP65 Weather Resistant
New and Improved
Check out the newer model:
  • 2.5K QHD w/Color Night Vision.
  • Built-in spotlight.
  • Indoor/Outdoor friendly.
  • More processing power. It's faster!
  • Enhanced two-way audio.
  • You'll also continue to get the amazing features of Cam v3: Built-in MicroSD slot, control through the same Wyze app, and traditional night vision.
Get Cam v4
Our award-winning wired smart camera is back with illuminating Color Night Vision and new outdoor-friendly IP65 weatherproofing. Keep an eye on what matters most - indoor or out, rain or shine, light or dark.
  • A colorful circle with a white owl in the middle.
    1080p Color Night Vision
    See more clearly at night in full color.
  • Weather icon with sun and clouds.
    Indoor/Outdoor
    Capture moments indoors and outdoors with IP65 weather resistance.
  • A drawing of a wand with a star on it.
    Fully upgraded
    More processing power. More mounting options. More frames per second.
  • Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v3 Specs
Color & Materials
  • Color: White
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • View angle: 121° diagonal
  • Lens FOV: 180° vertical range
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue
Dimensions & Weight
  • 52 mm (L) x 51 mm (W) x 58.5 mm (D)
  • <98.8g
Power
  • Power Adapter: Indoor 5v/1A
  • Outdoor Power Adapter (sold separately)
  • Cable: 6 Feet Flat USB Cable
Wyze Cam v3 Specs
Color & Materials
  • Color: White
Dimensions & Weight
  • <98.8g
Power
Storage
  • Local Storage (microSD card required)
  • Cloud (with subscription plan)
Weather & Temperature
  • Operating temp: -5°F - 113°F (-20°C - 45°C)
  • IP65 Weather Resistant
  • Made for Indoor/Outdoor
Certifications
  • FCC, IC, UL, and IP65 Certified
Languages
  • English
Warranty
  • 1-Year
A box of a camera with a white cord and a white plug.
Cam v3 - 1 Pack
  • Wyze Cam v3 x1
  • Quick Start Guide x1
  • Wall Mount Plate x1
  • Wall Mount Plate Tape x1
  • Screw Kit x1
  • Indoor USB Power Adapter x1
  • 6 Feet Outdoor Rated USB Cable x1
Cam v3 - 2 Pack
  • Wyze Cam v3 x2
  • Wall Mount Plate x2
  • Wall Mount Plate Tape x2
  • Screw Kit x2
  • Indoor USB Power Adapter x2
  • 6 Feet Outdoor Rated USB Cable x2
Bold design with the outdoors in mind.
It’s time to take Wyze Cam outside. All-new IP65 weather & dust resistance truly lets you see everything around your home, inside and out
A white camera mounted on a wall.
Indoor/Outdoor Home Security.
IP65 weather & dust resistance truly lets you see everything around your home, inside and out.
A person is walking past a garage with a motion detection alert from the Wyze app on the screen.
Person Detection and more with Cam Plus.
• Person Detection
• Unlimited Cloud Storage
• Vehicle, pet, and package detection
* with Cam Plus subscription
Learn More
Choose from an amazing line-up of accessories.
A white camera with a light on it.
Spotlight Kit
Light your way for extra security in darker areas. See color images in the Wyze app regardless of ambient lighting conditions.
Shop Spotlight Kit
A black lamp with a white bulb.
Wyze Lamp Socket
Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3.
They also work together make your existing outdoor lighting, smart. So you can turn the light on and off from your phone.
Shop Wyze Lamp Socket
Easily mountable. Anywhere.
With an included magnetic mounting kit, screw kit, and built-in adjustable table stand, Wyze Cam v3 is mountable anywhere you need it.
Wyze BaseCam motion detection app on a smartphone.
Motion detection in a smartphone app.
A video of a sunset on a beach.
Even more features to love.
Capture and view up to 28 days with a 128GB microSD card (sold separately).
Receive an alert the moment Wyze Cam hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
1 of 4
Popular Wyze Cam Accessories
  • MicroSD Cards
    Regular price From $18.98
    Regular price $18.98 Deal From $18.98
    Choose your option
    View Options
  • Wyze Cam v3 Spotlight Kit
    Regular price $7.98
    Regular price $16.98 Deal $7.98
    Bring light to the extra dark. For Wyze Cam v3. Learn More
  • Wyze Window Mount
    Regular price From $9.99
    Regular price Deal From $9.99
    Mount for Wyze Cam Outdoor Learn More
    Choose your option
    View Options
  • Wyze Outdoor Power Adapter
    Regular price Deal From $18.98
    Ready for rain, snow, or shine. IP67 weather resistant so you can safely use your Wyze Camera outdoors. Learn More
    Choose your option
    View Options
* Wyze Cam v3 is wired allowing for continuous recording
**Requires Wyze Outdoor Power Adapter (sold separately) for outdoor use.
**Requires microSD card (sold separately)
