1 of 7
Wyze Cam Outdoor v2
Wyze Cam Outdoor v2
Wire-Free 1080p Outdoor Cam
Check out the newer model:
  • 2.5K HD w/Color Night Vision.
  • Built-in microSD slot & spotlight.
  • Removable battery.
  • Doesn't need a base station to work.
  • Indoor/Outdoor friendly.
  • More processing power. It's faster!
  • Works with Wyze Solar Panel.
  • You'll also continue to get the amazing features of Wyze Cam Outdoor: 2-way audio and traditional night vision.
Get Battery Cam Pro
Option
IP65 weather rating and wire-free six month battery life, plus a deep love of both journaling and Birkenstocks. Wyze Cam Outdoor v2 is Wyze Cam's sportier, more outdoorsy cousin. Dropped out of high school, but values education, Wyze Cam Outdoor v2 is always ready with color night vision, a new oatmeal recipe, or an unsolicited lecture about saving the planet. This thing couldn't be more granola if it came with a hammock. Prefers hostels to hotels, but will happily keep an eye on your stuff for you from either with its handy Travel Mode.
  • Color night vision icon.
    1080p HD Color Night Vision
  • A black image with no visible details.
    Wider Field of View (130°)
  • A black background with a white PIR motion icon.
    PIR Motion Detection
  • A black and white image of a weather icon.
    IP65 Weatherproof
Camera
• Dimensions: 2.3 inch x 2.3 inch x 2.8 inch (5.842cm x 5.842 cm x 7.112cm)
• Item Weight: 9.8 ounces
• Sensor: 1/2.9’ Starlight CMOS
• Battery: 2x 2,600 mAh/7.4V rechargeable batteries
• Operating Temperature: -4℉ - 122℉
• Charging Temperature: 32℉ - 122℉
• IP Rating: IP65
• Resolution: 1920x1080 (1080p)
• Field of View: 130°
• Night Vision LEDs: 4*850nm LEDs
• Night Vision Distance: Up to 25 feet
• Daytime Video: 20 Frames Per Second
• Nighttime Video: 10 Frames Per Second
• Zoom: 8x digital
• One base station supports up to 4 cameras
• Local Storage: microSD card slot on camera and base station (up to 256GB)
• Mounting: Magnetic, Screw, or 3rd party 1⁄4" — 20 mount
• Certifications: FCC, IC, UL, and IP65 Certified
Base Station:
• Interface Port: Fast ethernet (10/100)
Starter Bundle:
  • Wyze Cam Outdoor v2 x1
  • Base Station x1
  • Base Station Power Adapter x1
  • Base Station Ethernet Cable x1
  • microUSB Cable x1
  • Screw Assembly x1
  • Quick Start Guide x1
Add-on Camera:
  • microUSB Cable x1
  • Screw Assembly x1
Wyze Cam Outdoor v2 includes all the features you love from the previous outdoor cam, with the addition of a Starlight sensor for Color Night Vision, a bigger Field of View of 130º, and an improved PIR lens for fewer false detections.
Wyze Cam Outdoor v2 is equipped with a Starlight sensor that allows the camera to see color in extremely low light conditions.
The base station in the bundle for Wyze Cam Outdoor v2 is the same as the original Wyze Base Station. This means that if you already have a base station, you’re all set!
No, you do not need a subscription to use Wyze Cam Outdoor v2. But with Cam Plus, the camera can record longer videos with no cooldown period, and use state-of-the-art AI features including Person, Pet, Package, and Vehicle Detection.
The battery can last up to 3 to 6 months with normal usage (about 10-20 Events per day). Battery life varies based on settings, usage, and the temperature of the environment.
The cooldown period can be adjusted to 1 minute, 3 minutes, or 5 minutes. With Cam Plus Lite, the Event video length is 12 seconds. With Wyze Cam Plus, you can remove cooldown entirely and record longer Event videos.
The base station helps preserve the camera’s battery life by providing the internet connection to the camera. It also removes any compatibility issues with different router brands.
Wyze Base Station supports up to 4 cameras so you get the best experience, particularly when viewing each live stream at the same time. Bandwidth limitations can cause video data to be lost if more cams are paired. If you need more than 4 outdoor cams, pick up another starter bundle here.
Wyze Base Station requires an ethernet connection on the router during setup. After setup, you can connect to the base station via Wi-Fi in the Wyze app and unplug the ethernet cable. Then, place the base station anywhere you want as long as it has a Wi-Fi signal.
No, not on either Wyze Cam Outdoor. This camera was built for maximum flexibility so that you can put it anywhere you want, even where there is no power outlet. Continuously recording to a microSD card like on Wyze Cam v3 will drastically shorten the battery life. Because of this, we did not build this feature into Wyze Cam Outdoor v2 and recommend a Wyze Cam v3 for that.
However, there is a "Scheduled Recording" feature where you can schedule specific times for the camera to continuously record to its local microSD card or record when motion is detected, though it will reduce battery life.
Yes, the new outdoor camera is compatible with Wyze Solar Panel.
We have added a new feature for Wyze Cam Outdoor because we understand that the risk of theft is higher with products that are mounted outdoors. We built a mechanism that prevents a new account from setting up the camera if it is already paired with a Wyze account unless the original account releases it. In short, if someone steals the camera, the camera will not be able to be used again unless the owner removes the camera from their account.
Starlight. Color Bright.
Unedited footage. Shot on Wyze Cam Outdoor v2.
See in extraordinary detail at night.
A black and white photo of a porch with a chair and a cat sitting on it. A black metal chair with a white cushion on a patio.
Wyze Cam Outdoor v1
Wyze Cam Outdoor v2
IP65 Weatherproof
Bring on the downpours, blizzards, and heatwaves. Wyze Cam Outdoor v2 is built from the ground up to be a workhorse in even the harshest conditions.
  • A dustproof icon on a black background.
    Dust Tight
    Guarded against dust and other particulates
  • A black background with a drop of water on it.
    Waterproof
    Protection against low pressure jets of water
  • A thermometer icon with the temperature set to 48 degrees.
    Extreme Heat/Cold
    Fully functional in climates of -4° up to 122°F
1 of 3
Now with an even wider field of view.
Our new lens maximizes viewing angles while tampering distortion so you can see more of your property without compromising on the details.
A green golf course with a mountain in the background. A green field with a mountain in the background.
Wyze Cam Outdoor v1
Wyze Cam Outdoor v2
A white camera attached to a stone wall.
With up to 6 months of battery life...
Mount wherever you need it, without worrying about running wires or finding outlets. Two integrated rechargeable 2,600 mAh batteries last up to 6 months on a single charge.
A solar panel is attached to a wooden fence post.
...and continuous charging with Wyze Solar Panel.
Every superhero needs a sidekick. Wyze Solar Panel converts sun rays into power so you can leave your camera up longer with less frequent charging. With enough sunlight, you may never need to take it down again.
Get notified when motion is detected...
Wyze Cam Outdoor v2 uses passive infrared sensors (PIR) to sense body heat signatures to reduce false alerts from things like waving branches. When motion is detected, you'll get an alert sent straight your phone, so you never miss a thing.
A man wearing a black shirt and black pants is standing in front of a house.
A man holding a box with a camera on it.
...and respond in real-time with two-way audio.
Ask the delivery person to hide a package behind the bushes, or scare off unwanted guests in your yard using the built-in siren.
Record up to 56 days of video with a 256GB Wyze microSD Card.
Get approximately 56 days of SD video and 16 days of HD video.
A man holding a camera in his hand.
Level up with Cam Plus for $1.66/month
Unlock premium features that make your already great Wyze Cams even better.
• Unlimited Full-Length Video Recording
• Smart AI Person/Pet/Vehicle Detection
You'll even get exclusive subscriber discounts on Wyze products!
Learn more
Travel Mode
Staying at a hotel or backpacking in the Rockies? Travel Mode lets you record motion & time-lapse videos to a microSD card (sold separately), even when you’re not connected to the internet or the base station.
A smartphone screen displaying a side yard camera.
A phone screen displaying a list of event recordings.
Detection Zone: A screen displaying a map with a detection zone.
The Wyze app is your command center.
Drop in anytime, from anywhere to view live video feeds.
Get glanceable insights into what your camera is seeing in the Events tab. See quick labels of who or what caused the Event with Cam Plus.
It's easy to install Wyze Cam Outdoor v2
Nervous about installation? We get it. Just watch our step-by-step installation video below to see how easy the process actually is.
Support Articles
Now that your Wyze Base Station is set up, it's time to add your Wyze Cam Outdoor. It's an easy process, as it relies on Wyze Base Station for network communication.
Fully charge your Wyze Cam Outdoor before setting it up the first time. This can take up to 4 hours. Once fully charged the light will switch from flashing red to solid red.
To set up your Wyze Cam Outdoor:
  3. Tap Cameras > Battery Camera > Wyze Cam Outdoor > Begin setup.
    If you don't have a Wyze Base Station on your account, or your Wyze Base Station already has 4 paired cameras, you'll be directed to set up a Wyze Base Station here.
  4. On the back of your camera, open the charging cover and flip the power switch to On.
    The status light will be solid yellow.
  5. Lift the camera away from its base, or separate the magnetic base from the body.
  6. In the Wyze app, tap Begin Setup. If you have more than one Wyze Base Station, or yours is already full, you'll be prompted to select the one you'd like to pair the camera with.
  7. Press the SYNC button on the bottom of the Wyze Cam Outdoor.
  8. The camera will say "Pairing is in progress. Please wait." The status light will flash yellow and blue.
  9. The camera will automatically finish pairing with Wyze Base Station. The status light will turn solid blue when complete.
  10. When prompted on the next screen, name your Wyze Cam Outdoor. You're all set!
  11. You may have a prompt for a free trial of Cam Plus. Tap Continue.
  12. Set up some automations on the Things to Try* page, or tap Skip.
  13. You’re all set. Enjoy your new Wyze device!
Once your Wyze Cam Outdoor is set up successfully, you can mount it. Continue to the Wyze Cam Outdoor Mounting Guide.
Wyze Base Station is the communication hub for your Wyze Cam Outdoor and it is necessary for it to talk to your network.
New to Wyze? Before starting, download the Wyze app and connect to the Wi-Fi.
To set up your Wyze Base Station:
  1. Connect your mobile device to the same Wi-Fi network your base station will be set up to.
  2. In the Wyze app, tap Home, then tap the plus sign + on the top right.
  3. On the Add menu, tap Device.
  4. Tap Cameras > Battery Camera > Wyze Base Station > Next.
  5. Plug one end of the included power supply cable into the base station, and the other end into a power outlet.
  6. Plug one end of the provided Ethernet cable into the base station, and the other end into the back of your router.
    The status light will flash blue, then turn solid blue when connected to your network.
  7. Check the box next to "The status light is solid blue" and then tap Next.
    Do you see a "Can't find Base Station" error screen? Tap Scan with QR code instead, then Scan QR code.Locate the QR code on the bottom of the base station.On the next screen, use your mobile device's camera to scan the code.
    Tap Go to Wi-Fi selection, then select the network that looks like:
    If the QR code will not scan, you can tap on The QR Code isn't scanning.On this page, you can enter the MAC address that is located on the bottom of the base station's device label to the left of the QR code, labeled MAC: xx:xx:xx:xx:xx:xx.
  8. The setup process will complete automatically.*
  9. When prompted on the next screen, name your Wyze Base Station.
*Your mobile device and the base station must be on the same network to complete setup.
Want to unplug your Wyze Base Station from your router?
Once it's set up, you can use Wyze Base Station on a Wi-Fi connection - no need for a router. To do this:
  1. In the Wyze app, tap on your Wyze Base Station.
  2. Tap on the Settings gear on the top right.
  3. Tap Device Info > Change Connection. You'll see one of the following screens: Select your network. Follow the onscreen steps to connect to your Wi-Fi network.Once connected, unplug the base station from your router.The status light will flash blue, then turn solid once complete. You're all set! Connect via Wi-Fi. Unplug the Base Station from your router.The status light will flash blue, then turn solid once complete. You're all set!
Want to change the Wi-Fi that your Wyze Base Station is connected to?
  3. Tap Device Info > Wi-Fi Network.
  4. Follow the on-screen steps to finish the setup.
Now that your Wyze Base Station is all set up, it's time to add your Wyze Cam Outdoor. Move on to the next article, Wyze Cam Outdoor Setup Guide.
Having issues setting up your Wyze Base Station? Check out our Base Station Setup Troubleshooting.
Mounting the Wyze Cam Outdoor is not required, but it has its perks. When mounted, your camera is more secure, protected from the elements and direct sunlight, and it gives you a better vantage point over large areas.
What’s Needed:
  • 1x Wyze Cam Outdoor
  • 1x 24mm "M3" Screw
  • 1x Screw Anchor (only required with drywall installation)
Required Tools
  • 1x Philips-Head Screwdriver and/or Electric Screwdriver
Mount your Wyze Cam Outdoor
Use the drop-downs below for instructions to mount the Wyze Cam Outdoor to the ceiling or a wall.
Ceiling Mount Instructions
To mount your Wyze Cam Outdoor to a ceiling:
  1. Position your Wyze Cam Outdoor on the ceiling where you want to mount it.
  2. Drill a 3mm hole in that spot, and insert the included Drywall Anchor.
  3. Screw the base of the Wyze Cam Outdoor into the Drywall Anchor using the hole labeled "Ceiling Mount".
  4. Attach the top of Wyze Cam Outdoor to the magnetic base. Proper orientation: SYNC button facing down.
Section Link: Link
Wall Mount Instructions
To mount your Wyze Cam Outdoor to a wall:
  1. Position your Wyze Cam Outdoor on the wall where you want to mount it.
  3. Screw the base of the Wyze Cam Outdoor into the Drywall Anchor using the hole labeled "Wall Mount".
  4. Attach the bottom of Wyze Cam Outdoor to the magnetic base to keep it in the proper orientation. Proper orientation: SYNC button facing down.
Section Link: Link
Additional Notes
To get the most out of your Wyze Cam Outdoor, keep these in mind while positioning your camera.
  • Always mount your Wyze Cam Outdoor right-side pointing up, with the SYNC button pointed down. Person detection may not work as accurately if the sensor is upside down.
  • Avoid direct sunlight: While Wyze Cam Outdoor is designed to weather the elements, it's still a camera. This means that having it facing direct sunlight could lead to the image being washed out, and has potential to shorten the life of the camera's image sensor.
  • Avoid general traffic: If you're using the Wyze Cam Outdoor to alert you when there's activity somewhere, you want to avoid false-positives. While these should be few and far between, angling your Wyze Cam Outdoor to avoid heavy-traffic areas while using any of its recording features will help keep the battery from draining too quickly.
  • Avoid waving branches: While the PIR sensor should help prevent most false-positives, it's still possible for the camera to record passive movement (waving branches, clothesline, etc.) as movement.
  • Avoid placing your camera behind glass, looking out of a window, or installed in a third-party case: Wyze Cam Outdoor uses PIR (temperature changes) to detect motion. Motion detection will not trigger if the camera is behind glass, looking out of a window, or inside a third-party case.
