1 of 10
Wyze Cam OG
Wyze Cam OG
1080p Cam with Spotlight & Night Vision
Fan Favorite
Chosen Again & Again
Color
Pack
Add ons
    $29.98
    Use a 5-digit ZIP code.
    1080p HD
    Color Night Vision
    IP65 Weather Resistant
    Integrated Spotlight & Siren
    The next generation of Wyze Cam has arrived. Now with quicker live-streaming, 3X faster notifications, improved 2-way audio, and a built-in spotlight. Indoor/outdoor*.
    Note: There may be slight differences in appearance depending on which camera model you receive. The product functionality is identical. See the Tech Specs for details.
    • Color night vision camera.
      1080p HD Color Night Vision
    • Weather-resistant camera lens.
      IP65 Indoor/Outdoor Security
    • A bright spotlight on a black background.
      Built-In Spotlight with Integrated Siren
    • A black screen with a message about syncing a microSD card.
      24/7 Recording to Wyze microSD Card
      MicroSD card sold separately. Add AI alerts and cloud backup with Cam Plus.
    Wyze Cam OG Specs
    Color & Materials
    • Color: White or Black
    • Finish: Matte
    • Model: WYZECGSD
    • Image Sensor: CMOS-Starlight Sensor (1920 x 1080)
    • 2 spotlight (5000K, 40 lumens)
    Dimensions
    • 2.05in x 2.05in x 2.05in (52mm x 52mm x 52mm) - 2025 WYZECGSD Model
    • 1.89in x 1.89in x 1.89in - WYZECGS Model
    Weight
    • 4.4oz (125g) - 2025 WYZECGSD Model
    • 4.1 oz (116 g) - WYZECGS Model
    Power
    • Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
    Built-in Spotlight
    • 40 Lumens
    Additional Details
    • Power Cable Length: 6 ft (1.8 m)
    • Ports: 1 micro USB
    • Night Vision: 4 IR LEDs (850nm)
    • Digital Zoom: 8x
    • Field-of-View: 116°(DFOV), 99.7°(HFOV), 53°(VFOV) - 2025 WYZECGSD Model
    • Field-of-View: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV) - WYZECGS Model
    • Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
    • Local Storage: Supports up to 256 GB microSD in exFAT format
    Connectivity & Compatibility
    • 802.11 b/g/n, 2.4 GHz Wi-Fi
    Weather & Temperature
    • Weather Resistance: Indoor & Outdoor (IP65)
    • Operating: -4°F-131°F (-20°C-55°C)
    • Storage: -40°F-158°F (-40°C-70°C)
    Language
    • English
    Warranty
    • 1-Year
    View our cam comparison chart
    The latest 2025 model number is WYZECGSD on the box. The previous model number is WYZECGS.
    Wyze Cam OG (Standard):
    • 1x Wyze Cam OG unit
    • 1x Indoor Power Adapter
    • 1x USB Cable
    • Wall Anchors
    • Wall Plate
    • Mounting Screws
    • 1x Quick Start Guide
    Great question. As of 2025, there has been a few tweaks. Learn more in the Tech Specs or check out this support article.
    There are two key differences: The telephoto camera has a 3x telephoto lens, while the standard OG camera has an integrated spotlight. Both are great cameras with all of the features you know and love. Use Wyze Cam OG to monitor your home with a wide angle lens. Use Wyze Cam OG Telephoto to clearly monitor points-of-interest that are further away.
    Yes, both cameras can be used as standalone cams. But we like using them both together - you get the OG’s integrated spotlight, Wyze Cam OG Telephoto’s closer details, and the ability to view the livestream of both cameras at the same time.
    No, Wyze Cam OG is not wireless or battery powered. It is powered via the included 6 ft USB cable.
    Yes, Wyze Cam OG is IP65-rated and can be used both indoors and outdoors.
    You can stack 2 total cameras together, in any combo! That could be a Wyze Cam OG and a Wyze Cam OG Telephoto, or two Wyze Cam OG cams, or two Wyze Cam OG Telephoto cams.
    No, Wyze Cam OG only supports 2.4 GHz networks.
    Yes, Wyze Cam OG is compatible with Wyze Web View.
    Yes, the telephoto cam can be used as a standalone camera, without a Wyze Cam OG. But we like using them both together - you get the OG’s integrated spotlight, Telephoto’s 3x closer details, and the ability to view the livestream of both cameras at the same time.
    No, Wyze Cam OG Telephoto only supports 2.4 GHz networks.
    Yes, Wyze Cam OG Telephoto is compatible with Wyze Web View.
    Only Wyze Cam OG and Wyze Cam OG Telephoto have Picture-in-Picture functionality.
    Yes. You can use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto 3x cameras at the same time. It is not limited to only Wyze Cam OG + Wyze Cam OG Telephoto viewing.
    No, only Wyze Cam OG has a spotlight.
    The Wyze Stack Kit includes a USB Cable Splitter, a Power Brick, and Stack Mount that allows you to power and stack-ably mount two Wyze Cam OGs or Wyze Cam OG Telephoto Cameras on top of each other.
    Yes. Both cameras take all Wyze microSD cards up to and including 256GB microSD cards.
    Two white cameras on a table.
    Independently amazing.
    Upside down or right side up each camera operates on its own to cover every angle of any space.
    A smartphone with a notification from the Wyze app.
    3x faster motion notifications.
    A speaker with a microphone on a wall.
    Upgraded two-way audio.
    Person holding a smartphone with a live video stream of their dog.
    • A smartphone displaying a local microSD card storage app.
      Supports all Wyze microSD cards, up to and including 256GB.
    • Get smarter security with Cam Plus.
    A smartphone displaying a live view of a room.
    A smartphone displaying a live view of a home.
    An iPhone screen displaying an event review of a baby's sleep.
    Wyze app settings page with various options to customize the app.
    The image displays a smartphone screen with an alarm settings page.
    A smartphone screen with a setting for alarm sounds.
    A brand new app experience.
    Unlike a stray Lego brick at 1 am, we've put all the handy tools exactly where you'd want them–from spotlight and siren controls to the new simplified event review.
    Enjoy a new, easy-to-scan Recent Events section to quickly navigate footage.
    Tell Wyze Cam OG exactly where you want it to watch. Get notifications only for detections within your customized zone.
    • A white Wyze Cam is sitting on a white stand.
      Wyze Cam OG
      • 120° Field of View
      • Built-In Spotlight with Color Night Vision
      • IP65 Weatherproof
      • Two-Way Audio
      • Works with Wyze Cam OG Stack Kit
    • A white Wyze Cam with a blue light on the bottom.
      • 3x Telephoto Camera (27° Field of View)
      • Color Night Vision
      • IP65 Weatherproof
      • Two-Way Audio
      Learn More
