Skip to content
1 of 7
Wyze Cam OG Stack Kit
The Stack Mount allows you to power and stack-ably mount two Wyze Cam OGs.
$9.99
Wyze Cam OG Stack Kit is for Wyze Cam OG and OG Telephoto. The Wyze Stack Kit includes a USB Cable Splitter, a Power Brick, and Stack Mount that allows you to power and stack-ably mount two Wyze Cam OGs or Wyze Cam OG Telephoto Cameras on top of each other.
Color: White
Finish: Matte
Compatible with Wyze Cam OG and OG Telephoto
Wyze Cam OG Stack Kit:
  • Stack Mount
  • Dual Micro USB Power Cable (6ft)
  • 5v/1.5A Indoor Power Adapter
  • Quick Start Guide
Wyze Cam OG Stack Kit can only be used with Wyze Cam OG and/or Wyze Cam OG Telephoto 3x. It is not compatible with other Wyze Cams.
To stack the cameras:
  1. Remove the standard base from the bottom of the camera you plan to have on top.
  2. Attach the stack mount to the bottom of the camera you plan to have on top.
  3. Remove the stack cover on the top of the camera you’d like to use as the base camera.
  4. Insert the stack mount into the stack shoe of the base camera. (The arrow on the mount should be pointing toward the center of the camera.)
  5. You should hear/feel a click once the stack mount is fully inserted into the stack shoe.
How to use Wyze Cam OG Stack Kit
Watch this short video guide on how to use the Wyze Cam OG Stack Kit with Wyze Cam OG or OG Telephoto.
1 of 4
Products frequently bought with OG Stack Kit
  • MicroSD Cards
    Regular price From $18.98
    Regular price $18.98 Deal From $18.98
    Choose your option
    View Options
  • Wyze Outdoor Power Adapter
    Regular price Deal From $18.98
    Ready for rain, snow, or shine. IP67 weather resistant so you can safely use your Wyze Camera outdoors. Learn More
    Choose your option
    View Options
Stack two OG cams with our Kit and run both off one power source
New and improved camera.
