Skip to content
Window Security Kit
Window Security Kit
The clearest Wyze Cam ever made.
What's in this bundle
Wyze Cam v4 (Color)
$49.96
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Upgrade your exterior security. Mount your Cam v4 on a glass surface, and enjoy 2.5K HD, glare-free protection. See what happened from start to finish.
  • 2.5K QHD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
  • Motion-Activated Spotlight
    Automatically trigger the LED light and voice prompt for extra security.
  • Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
  • Colors: White, Grey, and Black
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
  • Dimensions: 2in x 2in x 2 3/8in
  • Weight: 0.49 lb (222 g)
  • Mounting: Stand, wall mount, ceiling mount, or magnetic wall mount (adhesive)
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Cable: 6-Foot Flat micro USB to USB-A
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision/Color Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Learn more
Wyze Window Mount
  • Dimensions: 90 mm x 63.8 mm x 11.45 mm
  • Weight: 1 ounce
  • Warranty: 1 year
  • In the box: Wyze Cam v3 Window Mount
32GB Storage Card
  • Class 10 and UHS-1 (U1)
  • Read Speed: 31MB/s8
  • Write Speed: 12MB/s9
  • Media Storage (32GB): ~2,880 minutes (48 hours) of HD video(2), ~10,080 minutes (168 hours) of SD video(3), and ~4,200 16MP photos(4)
Learn more
Cam v4:
  • 1x Wyze Cam v4
  • 1x Quick Start Guide
  • 1x Wall Mount Plate
  • 1x Wall Mount Plate Tape
  • 1x Screw Kit
  • 1x Indoor USB Power Adapter
  • 1x 6-Foot Flat micro USB to USB-A cable
Window Mount:
  • 1x Window Mount
Wyze MicroSD Card:
  • 1x 32GB MicroSDHC Memory Card
The best just got
Wyze Cam v4 with WDR
No WDR
Security Camera Starter Kit Basic SVB-CPAN3-C4WH - Wyze Labs, Inc.
Record continuously.
See what happened from start to finish with local recording. Built-in microSD card slot allows for continuous event capture and 24/7 monitoring.
Mount your cam on a glass surface with this accessory and enjoy a clear view free of glare or reflection.
Even more features to love.
