1 of 11
Bulb Cam + Free 32GB microSD
2K Camera Built into a Smart Bulb
What's in this bundle
$53.98 $58.97
Use a 5-digit ZIP code.
Protect your home day and night with Wyze Bulb Cam, the 2-in-1 outdoor security camera and smart LED light bulb. Unlock continuous, local recording and time lapses for your Bulb Cam with the included 32GB MicroSD card — never miss a moment, whether it’s big or small!
  • A black image of a bulb with a camera.
    A Light Bulb + Security Camera
    An all-in-one outdoor security solution.
  • A colorful logo for a Wyze Bulb Cam.
    2K Color Night Vision with 160° FOV
    See more of everything day or night with a wide field of view.
  • A black image of a Wyze Bulb Cam.
    Enhanced Group Lighting
    Pair up to 5 Wyze Accessory Bulbs. Customize the brightness and schedules.
  • Wyze Bulb Cam Shopify 13
    Adjusts to Fit Most Light Fixtures
    Manually extend, rotate and tilt the camera to find just the right angle.
Wyze Bulb Cam Tech Specs
Materials & Colors
  • Model: WYZECBC
  • Body: Plastic
  • Lens: Glass and Plastic
  • Bulb Base: Metal
  • Certifications: FCC, IC, UL, IP65
  • Telescoping Length: 1.18 in (3 cm)
Power
  • 120V AC Input
  • Standard E26 Socket Only
  • 15 watts
Video
  • Resolution: 2K (2304 x 1296)
  • Field of View: 160° : 166° diagonal, 144° horizontal, 82.5° vertical
  • Frame Rate: Daytime: 20 FPS, Nighttime: 15 FPS
  • Functionality: Color Night Vision / IR Night Vision, Digital Zoom
Audio
  • Microphone: Built-in, digital
  • Siren: 95 dB at 4 in
  • 2-Way Audio
Lighting
  • Brightness: up to 800 lm
  • Color Temperature: 3000K
  • Controls: Manual, Motion-Activated Light, Ambient Light, Schedule, Wyze Automations
  • IR Lights: 4x 850nm
Storage and Alerts
  • Alerts: Push notifications, Motion Warning
  • Cloud Storage: stored in the AWS cloud (Wyze Service subscription required)
  • Local Storage:
  • Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
  • Supports up to 256 GB microSD cards in exFAT format
Connectivity and Compatibility
  • OS Requirements: Android 7.0+ or iOS 14.0+
  • Wi-Fi: IEEE 802.11 b/g/n 2.4 GHz, Wi-Fi 6
  • Bluetooth®: Bluetooth® Low Energy (BLE), Bluetooth® 4.2
  • Linking: Up to 5 Wyze Accessory Bulbs
Weather and Temperature
  • Weather Resistance:
  • Camera portion: IP65
  • Bulb portion: UL Damp
  • Operating Temperature: -4°F - 122°F (-20°C - 50°C)
  • Storage Temperature: -40°F - 176°F (-40°C - 80°C)
Warranty
  • 1-year product warranty
Wyze MicroSD Card
Wyze Bulb Cam + Wyze 32gb MicroSD Card
Bulb Cam
  • 1x Wyze Bulb Cam
  • 1x “Do Not Turn OFF” Sticker
  • 1x Quick Start Guide
  • 32GB1 MicroSDHC Memory Card x1 - for Wyze 32GB microSDHC Memory Card
1 1GB = 1,000,000,000 bytes. Actual user storage may be less.
2, 3, 4, 5, 6, 7 Based on internal testing. Actual performance may vary depending on host device.
8, 9 Based on internal testing. Performance may be lower depending upon host device, interface, usage conditions and other factors.
Wide 160° View Sees More Space
A person riding a skateboard in a driveway.
A hand holding a Wyze Bulb Cam.
Manually extend, pan, and tilt the camera to find just the right angle.
A Wyze Bulb Cam is mounted on a wall, providing security and illumination.
Dimmable 800 Lumen LED Bulb
Traditional lightbulbs look boring. We built this bulb to look modern and classy (just like you). Customize the brightness on these long-lasting LED bulbs to achieve the perfect lighting.
Works with Wyze Accessory Bulb
Meet the sidekick that's full of bright ideas. It's 800 lumens, dimmable, and works exclusively with Wyze Bulb Cam.
Two green lights on a building.
Enhanced Group Light Control
Auto-connect up to 5 Accessory Bulbs for full coverage smart lighting. Customize brightness and set schedules. Motion-activated lights? Yeah, they can do that too!
A person is holding a Wyze Bulb Cam in their hand.
24/7 Local Recording with MicroSD Card*
Record 24/7 locally with the included 32 GB microSD card (supports up to 256 GB). Add AI alerts and cloud backup with Cam Plus.
  • Wyze Bulb Cam Shopify 07: A Wyze outdoor camera is being used for dinner.
    Two-Way Audio
    Speak to people and pets from anywhere right from your smartphone.
  • A person holding a smartphone with a camera app open.
    Detection Features
  • A person is adjusting a Wyze Bulb Cam.
    AI Notifications and Descriptive Alerts
  • A person is standing in front of a garage with a car inside.
    Lighting Effects + Siren
    Flashing lights and a built-in siren will scare people away faster than a multi-level marketing invite.
Installation as easy as...
Brilliant setups
A Wyze Bulb Cam is shown in an outdoor fixture that is split between the morning, evening, and night.
A smartphone displaying a garage camera app.
A smartphone screen displays a Wyze Bulb Cam.
A Wyze Bulb Cam is displayed on a table.
Unlock amazing camera features
Record continuously with the included 32 GB microSD card. Add AI alerts and cloud backup with Cam Plus.
A person is inserting an SD card into a device.
Local recording
Record around the clock locally with the included 32 GB microSD card.* Set it up in the Wyze app, then review playback in the app or directly from the card. Add AI alerts and cloud backup with Cam Plus.
  • A Wyze Bulb Cam is shown in a dimly lit room.
    Accessory Bulb
    Auto-connect and synchronize the lighting of up to 5 Wyze Accessory Bulbs (sold separately) for full coverage smart lighting.
  • A hand is holding a Wyze Bulb Cam.
    SD Card
