Visión nocturna en color HD de 1080p
Seguridad interior/exterior IP65
Foco empotrado con sirena integrada
Grabación 24/7 en tarjeta microSD Wyze
La tarjeta microSD se vende por separado. Añade alertas de IA y copias de seguridad en la nube con Cam Plus.
Nota: Puede haber ligeras diferencias de apariencia según el modelo de cámara que reciba. La funcionalidad del producto es idéntica.
El último número de modelo 2025 en la caja es WYZECGSD. El número de modelo anterior era WYZECGS.
Great question. As of 2025, there has been a few tweaks. Learn more in the Tech Specs or check out this support article.
There are two key differences: The telephoto camera has a 3x telephoto lens, while the standard OG camera has an integrated spotlight. Both are great cameras with all of the features you know and love. Use Wyze Cam OG to monitor your home with a wide angle lens. Use Wyze Cam OG Telephoto to clearly monitor points-of-interest that are further away.
Yes, both cameras can be used as standalone cams. But we like using them both together - you get the OG’s integrated spotlight, Wyze Cam OG Telephoto’s closer details, and the ability to view the livestream of both cameras at the same time.
No, Wyze Cam OG is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam OG is IP65-rated and can be used both indoors and outdoors.
You can stack 2 total cameras together, in any combo! That could be a Wyze Cam OG and a Wyze Cam OG Telephoto, or two Wyze Cam OG cams, or two Wyze Cam OG Telephoto cams.
No, Wyze Cam OG only supports 2.4 GHz networks.
Yes, Wyze Cam OG is compatible with Wyze Web View.
Yes, the telephoto cam can be used as a standalone camera, without a Wyze Cam OG. But we like using them both together - you get the OG’s integrated spotlight, Telephoto’s 3x closer details, and the ability to view the livestream of both cameras at the same time.
No, Wyze Cam OG Telephoto only supports 2.4 GHz networks.
Yes, Wyze Cam OG Telephoto is compatible with Wyze Web View.
Only Wyze Cam OG and Wyze Cam OG Telephoto have Picture-in-Picture functionality.
Yes. You can use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto 3x cameras at the same time. It is not limited to only Wyze Cam OG + Wyze Cam OG Telephoto viewing.
No, only Wyze Cam OG has a spotlight.
The Wyze Stack Kit includes a USB Cable Splitter, a Power Brick, and Stack Mount that allows you to power and stack-ably mount two Wyze Cam OGs or Wyze Cam OG Telephoto Cameras on top of each other.
Yes. Both cameras take all Wyze microSD cards up to and including 256GB microSD cards.
Independientemente asombroso.
Ya sea boca abajo o boca arriba, cada cámara funciona por sí sola para cubrir todos los ángulos de cualquier espacio.
Protege cada espacio, interior y exterior.
Tú: «Parece que va a llover. ¿Necesitas una chaqueta?». Wyze Cam OG: «Eso es de novatos, tío». La resistencia a la intemperie IP65 significa que puede soportar las condiciones meteorológicas más adversas.
Foco incorporado y mini-sirena.
Luces. Cámara. ¡DESCONTROLADO! Disuade a posibles malhechores con un foco de 40 lúmenes y una sirena de 90 decibeles que activa el usuario.
Notificaciones de movimiento 3 veces más rápidas.
Si estar demasiado lejos de un baño nos ha enseñado algo, es que cada segundo cuenta. Un chipset mejorado y un software renovado envían notificaciones 3 veces más rápido que otras cámaras Wyze.
Audio bidireccional mejorado.
¿Qué fue eso? ¿Que si se escucha mejor? Sí, te oímos alto y claro. Un micrófono mejorado y un altavoz renovado ofrecen una mayor claridad.
Cargue videos HD en vivo más rápido que nunca.
Conéctate y transmite video en vivo un 50 % más rápido que con otras cámaras Wyze. Hay quienes dicen que la tranquilidad tampoco se había cargado tan rápido.
Genial desde el primer momento. Aún mejor con Cam Plus.
Galletas Y salsa de carne. Arcoíris Y unicornios. Jay-Z Y Beyoncé. Almacenamiento local Y opciones de seguridad más inteligentes. 👇
Admite todas las tarjetas microSD Wyze, hasta 256 GB inclusive.
Una experiencia de aplicación completamente nueva.
A diferencia de un ladrillo Lego perdido a la 1 am, hemos colocado todas las herramientas útiles exactamente donde las querrías, desde los controles del foco y la sirena hasta la nueva revisión simplificada de eventos.
Disfrute de una nueva sección de Eventos recientes fácil de explorar para navegar rápidamente por las imágenes.
Dile a Wyze Cam OG exactamente dónde quieres que observe. Recibe notificaciones solo cuando detecte algo dentro de tu zona personalizada.
Recibe una alerta en el momento en que Wyze Cam detecte que se activa una alarma de humo o de monóxido de carbono, para que, aunque no estés en casa, sepas si está sonando una alarma.
¡Elige la Wyze Cam OG que mejor se adapte a ti!
Cámara Wyze OG
- Campo de visión de 120°
- Foco integrado con visión nocturna en color
- Resistente a la intemperie IP65
- Audio bidireccional
- Compatible con el kit de apilamiento Wyze Cam OG
Wyze Cam OG Teleobjetivo
Aprende más- Cámara teleobjetivo 3x (campo de visión de 27°)
- Visión nocturna en color
- Compatible con el kit apilable Wyze Cam OG
