1 of 7
(Refurbished) Wyze Wi-Fi 6 Mesh Router
Whole‑Home Wi‑Fi 6 Mesh System
$29.99 $99.99
Use a 5-digit ZIP code.
12-month extended warranty
Get a 12-month extended warranty when you buy refurbished products on wyze.com. Also get special bundles, unique promos, + rewards with each order
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
Wyze Mesh Router makes every room the fastest room in your house. Internet speeds up to 1 Gbps with the latest Wi-Fi 6 technology, with 50+ devices and 1500 square feet per router for customizable coverage that puts dead spots in their graves. Simple setup, wired backhaul, top-of-the-line components, and parental controls. Wyze Mesh Router is truly built for today's modern smart home.
  • Wi Fi 6 logo.
    Wi-Fi 6/ Dual-Band
  • A black background with a white speedometer icon.
    Gigabit Internet Speeds
  • Three devices connected together.
    50+ Connected Devices per Router
  • A black house icon.
    1500 Square Feet of Coverage per Router
Wyze Mesh Router Details
Color: White
Finish: Matte
Wi-Fi Bandwidth: AX3000
Coverage: Up to 1500 sq. ft. each
Devices Supported: 50+ each
Technology: Wi-Fi 6 (802.11ax); Wi-Fi 5 (802.11ac); Wi-Fi 4 (802.11n); 802.11a; 802.11g; 802.11b; 802.15.4
CPU: ARM Cortex A53 Dual-Core 1 GHz
Flash: 128 MB SPI NAND Flash
RAM: DDR3L 512 MB
Radio Configuration (per mesh node): 2.4 GHz (ax 2x2) + 5 GHz (ax 2x2)
Antennas (per mesh node): 4
Frequency: 2.4 GHz, 5 GHz
Channel Width: 20 MHz, 40 MHz, 80 MHz, 160 MHz
Wi-Fi Data Rate: 802.11ax (2.4 GHz): 288 Mbps x 2 = 576 Mbps 802.11ax (5 GHz): 1200 Mbps x 2 = 2400 Mbps
Hardware Accelerator: Dedicated Wi-Fi Accelerator; Dedicated Routing Performance Accelerator
Ports: 1 x 1 Gbps WAN; 1 x 1 Gbps LAN; 1 x DC; 1 x Reset Button
Provisioning Technology: Bluetooth® Low Energy 5.1
Wireless Security: WPA3-PSK (Personal Mode); WPA2-PSK (AES); WPA-PSK (AES)
Power: DC 12V 1A
Temperature Rating: 32°F ~ 104°F (0°C ~ 40°C)
Humidity: Up to 90% RH, Non-condensing
Certifications: FCC, IC
Operation Modes: Router Mode; Bridge Mode (Auto ISP Router Passthrough); Auto WAN/LAN Port Sensing
1-Pack
  • Wyze Mesh Router x1
  • 3' Category 6 Ethernet Cable x1
  • Power Adapter x1
  • Quick Start Guide x1
Pictured: Wyze Mesh Router 1-Pack.
2-Pack
  • Wyze Mesh Router x2
  • Power Adapter x2
Coverage area, bandwidth, internet speed supported, and number of devices supported are the main differences between the two. Check out the table above for more details.
You’ll need:
1) Active Internet service from your local ISP.
2) An existing modem.
3) A smartphone with active mobile data service for setup.
The best place to put the router is in a central location, away from large appliances, and with good “line of sight” visibility to the main areas of your home.
In theory, you can add as many Mesh Routers to your network as you'd like. But we recommend no more than 10 mesh routers on the same network.
It depends on how much area you need to cover! But here’s a tip: One Wyze Mesh Router System (2-Pack) can cover up to 3,000 square feet while a Wyze Mesh Router Pro System (2-Pack) can cover up to 4,000 square feet.
No, you cannot mix and match different mesh routers on the same network. For optimal coverage, capacity, and performance, choose only one type to install.
Yes, though we recommend you replace your old router with a new Wyze Mesh Router. In some cases, your ISP may provide an all-in-one router and modem combo that cannot be replaced.
No, because Wi-Fi 6 is backwards compatible to older Wi-Fi standards. This means your older devices will still work.
Yes, thanks to Wyze Intelligent Mesh, the mesh router automatically optimizes the backhaul path regardless of if it's a wired or Wi-Fi connection.
Yes, Wi-Fi 6 (IEEE802.11ax) works with legacy standards as follows:
• IEEE802.11b — Wi-Fi 1 (2.4 GHz)
• IEEE802.11a — Wi-Fi 2 (5 GHz)
• IEEE802.11g — Wi-Fi 3 (2.4 GHz)
• IEEE802.11n — Wi-Fi 4 (2.4 GHz & 5 GHz)
• IEEE802.11ac — Wi-Fi 5 (5 GHz)
Most internet problems are router problems.
That's why we made Wyze Mesh Router
Everywhere coverage. Everywhere speed.
A diagram showing how Wyze Mesh Routers cover a whole home with wall-to-wall coverage.
A white Wyze Mesh Router sitting on a shelf.
Fast doesn't mean what you think it means.
Internet speed is more than just "How fast?" In today's smart homes, "How many?" is just as important. Each Wyze Mesh Router can keep 50+ devices at top speed, all at once, with no waiting in line.
Is your router built to manage today's smart home?
Yesterday's routers can only handle so many devices at once. The rest wait their turn. Wyze Wi-Fi 6 Mesh Router is built for today's smart home and can support multiple devices, all at once.
  • A logo for PCMAG.
    Prioritizes important devices.
    "If one person in your home is streaming a movie and another is checking social media on a phone, Wi-Fi 6 allows a router to assign channels to each device based on when it needs it most."
  • A white background with no visible text or objects.
    Improved battery life.
    "Wi-Fi 6 allows devices to plan out communications with a router, that means less drain on batteries and improved battery life in turn."
1 of 2
Wyze Mesh Routers can cover homes of all shapes and sizes.
A comparison chart showing the number of routers needed for different amounts of square feet and devices.
A white Wyze Mesh Router with two ethernet ports.
Wired or Wireless Expansion.
Each Wyze Mesh Router includes two Ethernet ports and supports wired backhaul.
The additional ports can expand wired connections to any room of your home, for even faster internet speeds.
A Wyze Mesh Router is displayed on a nightstand with a list of its internal components.
The best components for the best router.
Optimized antenna. Stronger power amplifier. A bigger processor with more memory. And mountains of testing and data to confirm its speed, range, and stability.
Plus no trade-offs between great features and a sleek look.
Wyze Wi-Fi 6 Mesh Router is better because it's built better. A first class product, made of first class parts, with a first class look.
A smartphone screen displaying a network statistics dashboard.
A smartphone screen displaying a network overview with details about the router, connected devices, and internet speed test.
A smartphone screen displaying a list of connected devices.
A phone screen with a guest network option.
Complete network control in the Wyze app
Get daily status reports, right in the Wyze app. And quickly assess the health of your network, including the status of each router and the status/identity of each connected device.
Know exactly which devices are connected to your network and how they're connected. Group them, name them, and manage their access.
Easily create, manage, and share a guest network.
Take back your internet.
You're not beholden to that crappy internet company router, and you're likely paying five to ten times what it's worth.
A Wyze Mesh Router Pro on a desk beside a laptop.
Want to go Pro?
More devices. More coverage. More speed. And access to the new, uncongested 6 GHz band.
Wyze Mesh Router Pro is Wi-Fi and its Wi-Finest.
Learn More
Wondering which mesh router is best for you?
Here's a quick rundown.
A comparison chart showing the differences between two routers, including their size, speed, and features.
Wi-Fi setup has never been so easy.
Watch the video to learn, step by step, how to set up your router. Or let the Wyze app walk you through the plug-and-play process.
FREE shipping on orders $0+
