1 of 7
Wyze Scale S
Wyze Scale S
Super smart. Ridiculously affordable.
Most 5 Star Reviews
Highly Rated Online
Color
$19.98 $29.98
Use a 5-digit ZIP code.
  • Tracks 12 metrics
    Monitor everything from weight, body fat %, to BMI and heart rate.
  • Multiple modes
    Access unique modes such as Pregnancy, Baby, Pet and Athlete
  • Syncs with fitness apps
    Apple Health and Google Fit
  • Huge 3.5" Display
    Easily readable when you need it
Wyze Scale S Specs
Color & Materials
  • Color: Black or White
  • Body: Strong plastic base + anti-slip silicone feet
  • Surface: Tempered glass + stainless steel electrodes
Weight
  • 3.32 lbs (1.66 kg)
Dimensions
  • 278 mm x 278 mm x 26 mm (11 in x 11 in x 1 in)
Power
  • Battery-Powered: 3 x 1.5V AAA Batteries (Pre-Installed)
Measurements
  • Display Units: lb/kg
  • Weight Measurement Range: 11-400 lbs/ 5-180 kg
Available Measurements
  • On Scale: Weight, Body Fat Percentage
  • In-App: Weight, Body Fat Percentage, Lean Body Mass, BMI, Muscle Weight, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage
Weather & Temperature
  • Operating Temperature: 41°F - 104°F (5°C - 40°C)
  • Operating Humidity: 20 - 85% RH
  • Storage Temperature: -4°F - 131°F (-20°C - 55°C)
  • Storage Humidity: 90% RH
Connectivity & Compatibility
  • OS Compatibility: Android 7.0+ and iOS 12.0+
  • Bluetooth Version: BLE 5.0
  • Supported Fitness Apps: Apple Health / Google Health / Health Connect
Language
  • English
Warranty
  • 1-Year
  • Wyze Scale S x1
  • 1.5V AAA Batteries x3
  • Quick Start Guide x1
  1. Scale S has added a baby/pet mode and a smart greeting mode that can say "HELLO" in the scale's LED display.
  2. The heart rate is measured by standing on the scale with bare feet for the original Scale. In Scale S, we change the way to measure the heartbeat by covering the finger on the phone's camera. Both can provide accurate results compared to other oximeters, bands, apple watches, etc.
  3. While the original Scale uses ITO glasses to measure the body resistance, Scale S has four metal electrodes to measure it. Both measurements are accurate. But the ITO covered glass design makes the original Scale looks more premium. (Lead to the price difference)
  4. Scale S offers a similarly slim, lightweight design compared to Wyze Scale. (Also, it leads to the price difference. Help us save shipping costs to lower the listed price.)
14-100 years old. Anyone can use Wyze Scale S to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 14 and 100 years old. Children under 14 and seniors over 100 will not be able to access the body composition features.
Wyze Scale S has a weight range of 11-400 lbs (5-180 kg).
Check if all of the personal information i.e., Body Type, Year of Birth, Height, Athlete Mode are correct. In the Wyze app, tap on your scale device then Settings > Users > (your Nickname).
When you replace the batteries, the time on the scale will reset. Connect to your scale in the Wyze app to sync up the time.
Yes, but it will only measure your weight. If you step on the scale with socks and/or shoes on, Wyze Scale/Scale S will only be able to measure your weight. To take your other body composition measurements (ex. body fat %, water %) you will need to step on the scale with both feet while barefoot.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale S in every bathroom, and in your home gym, too.
No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements. Place your Wyze Scale S on a hard, flat surface like tile or hardwood flooring before use.
Not wet, but damp is fine. Wet feet may affect accuracy. They also can make the scale slippery and not safe to use. Only step on Wyze Scale S with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Consult your physician first. By default, Wyze Scale S sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate.
Set the scale to Pregnancy/Weight-Only Mode to only measure your weight. Unlike other smart scales, Wyze Scale S has a unique feature that lets you disable the BIA measurement entirely to only measure weight.
Samsung health integration is on our roadmap. Samsung has closed their website for partnership registration since Sep 2020, but we are on their waitlist to get in. Once they have re-opened the gate, we will enter.
Home-use smart scales are designed for reference. Wyze Scale S uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available.
While a good estimate, the data calculated by your Wyze Scale S may vary from those given by professional-grade medical instruments or methods.
Tap on the surface of the scale to activate it, find the UNIT/RESET button on the back of the scale. Press and hold the button for 3 seconds. The LED display will show “CLr” when the scale is reset.
On the back of Wyze Scale S, locate the bumpy area over the battery compartment. With two thumbs, press downward on the center of the compartment cover, away from the UNIT/RESET button.
Based on Wyze’s reliability tests Bluetooth range, Scale S can maintain a steady BLE connection with the app in a range of 32 ft/ 10 m without the impact of physical obstacles or the other wireless devices.
Ultra-Precise Measurements
Industry-leading accelerometers, G-sensors, and an advanced bioelectric impedance chip all contribute to making highly accurate smart measurements with Wyze Scale S.
A white Wyze scale with a close up of the buttons.
A woman holding a white and black scale.
12 Unique Insights into Your Health
Health is measured by more than just weight. That's why Wyze Scale S also measures muscle mass, body fat, and even bone mass to give you a more complete picture of your health.
A collection of icons representing various health metrics, including body mass index, lean body mass.
A collection of icons representing various health metrics, including weight, lean body mass, metabol, and heart rate.
Huge, Bright, LED Display.
Easily readable when you need it, completely invisible when you don't. Wyze Scale S sets the bar high with a luxurious, digital LED display.
A digital scale displaying the number 1368.
Man holding a large dog while standing on a black Wyze Scale S.
A woman standing on a Wyze Scale while checking her stats on the Wyze app on her phone.
A green heart with a blue square in the middle.
A green and white logo for a fitness app.
Man looking at his phone with exercise equipment in the background.
A man holding a smartphone in front of a bicycle.
More features to love.
Track the weight of your fur baby or tiny human over time in the Wyze app. No math required
Watch your data trends anywhere and anytime. Achieve your goals and see yourself succeed.
Our body scale connects with popular fitness apps so you can track your progress where you track everything else.
With up to 18 months of battery life, you'll be able to see your New's Year's resolution through to completion and kick-start another one without worrying about changing batteries.
Wyze Scale S vs. a Regular Scale
Regular Scale
Wyze Scale S: A digital scale with a green background and the Wyze logo.
Wyze Scale S
from $19.98 $29.98
Measurements
Measures weight only
Tracks 12 metrics including body fat, muscle mass, BMI and heart rate
Health Insights
No insight into body composition
Measures body fat, muscle mass, BMI, visceral fat and more
Progress Tracking
No data history or trend tracking
Automatically syncs with the Wyze app to monitor long-term progress
User Profiles
No multi-user support
Supports multiple user profiles with automatic user recognition
Overall Value
Displays only your weight
Provides a more complete picture of your health and fitness
Compare Scales
Compare Scales
A smart scale that measures body composition with 13 body composition metrics.
Wyze Scale Ultra BodyScan
from $95.98 $119.98
Wyze Scale Ultra measures 13 body composition metrics and displays your weight, BMI, and body fat percentage.
Wyze Scale Ultra
from $41.98 $49.98
Wyze Scale X is a Bluetooth smart scale that measures 13 body composition metrics and allows up to 8 users.
Wyze Scale X
from $32.98 $38.98
Wyze Scale S
from $19.98 $29.98
BodyScan Handle For Professional Results
# of Electrodes for More Accuracy
TFT Screen
Customizable Display
Wi-Fi Connection
Heart Rate
In App
In App
In App
In App
Trend View
On Screen/In App
On Screen/In App
In App
In App
Weight Range
11-400 lbs
11-400 lbs
11-400 lbs
11-400 lbs
Battery Life (Up To)
8 Months
9 Months
22 Months
18 Months
ITO Conductive Glass
Power Source
4 AAA Batteries
4 AAA Batteries
4 AAA Batteries
3 AAA Batteries
Automatic Bluetooth Connection
Baby/Pet/Luggage Mode
Color
Black/White
Black/White
Black/White
Black/White
Dimensions
15.43 x 13.39 x 2.13 in
11.8 in x 11.8 in x 1.18 in
Only Weight Mode
Athlete Mode
Apple Health / Fitbit / Health Connect
Weight
5.95 lb
3.96 lb
3.96 lb
3.32 lb
View
View
View
View
Support Articles
Before starting, place your Wyze Scale S on a hard, flat surface and enable BluetoothⓇ on your phone.
To set up your Wyze Scale S:
  3. Tap Lifestyle > Wyze Scale Series > Wyze Scale S. Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.
  5. Add your details (Year of Birth, Height, etc.). You must be between 14 and 100 years old to see Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. Step on the scale with bare feet. Your weight will display, then your body fat percentage.
  8. You're all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
Download the Quick Start Guide for Wyze Scale S in this article.
Below is the Quick Start Guide for Wyze Scale S, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Scale S including:
  • What's in the box for Wyze Scale S.
  • How to set up Wyze Scale S.
  • Notes on how to use and where to place your Wyze Scale S.
  • How to read the LED display.
FREE shipping on orders $0+
