1 of 18
Wyze Lock Bolt v2
Wyze Lock Bolt v2
Smart Fingerprint Door Lock with Wi-Fi
Most 5 Star Reviews
Highly Rated Online
$79.98
Use a 5-digit ZIP code.
Fingerprint graphic
Ultra-Fast
Fingerprint Sensor
Access History chart
View Lock and Unlock
History in the Wyze App
Keypad layout.
Backlit Keypad with
Anti-Peep
Auto Lock mechanism
Auto-Lock &
Tamper Alarms
  • Fast, secure fingerprint entry
  • AI self-learning fingerprint scanner
  • Wi-Fi control from anywhere
  • Up to 8 months of battery life
  • Durable, anti-glare tempered glass
  • Manual lock and key option
  • Peace of mind with Auto Lock
  • BHMA® Certified Grade 2
  • Data stored locally on device
  • A black background with a single white dot in the center.
    AI-Powered Fingerprint Unlock
    Wi-Fi Control & Unlock History in App
  • A black background with a single white dot.
    Tempered Glass Keypad with Anti-Peep Codes
  • A black background with a single white letter "A" on it.
    Auto-Lock & Tamper Alarms
Wyze Lock Bolt v2 Specs
Colors & Materials
  • Model: WLCKB2
  • Finish: Matte
  • Color: Black
Dimensions
  • External Assembly: 6.2 in x 2.8 in x 0.7 in (156.5 mm x 72 mm x 17.3 mm)
  • Internal Assembly: 7.1 in x 2.9 in x 1.4 in (180 mm x 74.5 mm x 35.7 mm)
Weight
  • 2.15 lbs (975 g) (batteries included)
Doorbell Compatibility
  • Wyze Video Doorbell v2
  • Wyze Video Doorbell Pro
  • Wyze Duo Cam Doorbell
  • Wyze Battery Video Doorbell
Power
  • Power Source: 8 x AA batteries (included)
  • Battery Life: Up to 8 months with normal use (10-20 lock/unlock per day)
  • Emergency Power: USB-C port (USB-C cable not included)
Weather & Operating Temps
  • Weather Resistance: IP53
Operating Temperature
  • Outdoor Keypad: -4°F - 122°F (-20°C - 50°C)
  • Indoor Assembly: 32°F - 122°F (0°C - 50°C)
Storage Temperature
  • Outdoor Keypad: -22°F - 158°F (-30°C - 70°C)
  • Indoor Assembly: -22°F - 158°F (-30°C - 70°C)
Certifications
  • Certifications: FCC, IC, TSCA, CA65, ANSI-BHMA
Connectivity & Compatibility
  • Communication Method: Bluetooth® 5.0, 2.4 GHz Wi-Fi, Wi-Fi 4/5/6
  • Compatibility: Wyze app 3.8+, Android 10.0+ or iOS 16.0+
Door Compatibility
  • Compatible with most standard US doors. Replaces existing single-cylinder deadbolt.
  • See which doors are compatible with Lock Bolt v2 here.
  • Compatible with Wyze Battery Video Doorbell, Wyze Video Doorbell v2, Wyze Video Doorbell Pro, and Wyze Duo Cam Doorbell
  • Find more information about compatible doorbells with Lock Bolt v2 here.
Warranty
  • 1-Year
  • 1x Exterior Assembly
  • 1x Interior Assembly
  • 1x Mounting Plate
  • 1x Wood Screws Kit
  • 1x Interior Panel Screws Kit
  • 1x Mounting Screws Kit
  • 1x Deadbolt
  • 8x AA Batteries
  • 1x Deadbolt Strike Plate
  • 1x Dust Box
  • 1x Mechanical Keys
  • 1x Quick Start Guide
With AI self-learning fingerprint technology and a fingerprint-proof glass touchpad, Wyze Lock Bolt v2’s fingerprint reader is faster and more reliable than the original Wyze Lock Bolt. Wyze Lock Bolt v2 also has Wi-Fi built-in, which provides remote access and notifications from anywhere anytime. Our newest lock works with nearly all of our Wyze Video Doorbells to easily lock and unlock your door from the Live stream with a tap. And with mechanical key support, you’ll now have 5 ways to lock and unlock your door.
Traditional fingerprint locks are "one-and-done”—once registered, they can’t adapt to new data. Changes in the weather, scanning speed, seasonal changes, cold fingertips, or other variances can often cause delays when unlocking. Our AI self-learning fingerprint tech acts like your personal butler: it logs the pressure, angle, and even tiny skin shifts with every unlock, dynamically refining its model. The more you use Wyze Lock Bolt v2, the faster and sharper it gets. It also captures microscopic details like pores, creases, and scars on your fingerprint, building your unique "biometric vault."
No, installing your Wyze Lock Bolt v2 is the same as any other smart lock, with a standard deadbolt and latch assembly.
Door type: Standard single-cylinder deadbolt on wooden exterior doors. Not for glass or sliding doors. Does not support Mortise or multi-point locks.
Door thickness: 1-3/8" to 2-11/64" (35–55 mm).
Cross-bore (main hole) diameter: 2-1/8" (54 mm) or 1-1/2" (38 mm).
Edge/latch hole (face-bore) diameter: 1" (25 mm); latch-hole depth must be 1".
Backset: 2-3/8" (60 mm) or 2-3/4" (70 mm) (deadbolt is adjustable).
Clearance from other hardware: At least 2-9/16" (65mm) between the deadbolt center and the adjacent handle/doorknob.
Latch plate shape: Rectangular faceplate.
Wyze Lock Bolt v2 has a battery life of up to 8 months when you average 10 unlock/lock events per day.
Wyze Lock Bolt v2 includes an auto-lock timer. After you set a timer and unlock the door, the lock begins counting down. When the countdown reaches zero, the bolt extends and the door locks automatically. The lock does not detect whether the door is closed, so please ensure the door is fully shut before the time is up.
With Wyze Lock Bolt v2, you can unlock the door using 5 different methods: Fingerprint recognition, with a PIN code using the touchscreen, Wyze app, Alexa & Google Assistant, or by using an included physical key.
Wyze Lock Bolt v2 comes with eight AA batteries in the box. These batteries keep the connection to Wi-Fi rock-solid and give you the full feature set you love from your lock—no compromises.
Use brand new 1.5 V AA batteries, not rechargeable versions, when replacing the batteries. Start by removing the four batteries from the outer layer. Then gently pull the ribbon to lift the remaining 4 batteries out of the compartment. Next, carefully insert the inner layer of new batteries over the ribbon, then finish with the outer layer. For the best battery life and performance, don’t mix battery types or old and new batteries.
Wyze Lock Bolt v2 is compatible with Wyze Battery Video Doorbell, Wyze Video Doorbell v2, Wyze Video Doorbell Pro, and Wyze Duo Cam Doorbell. This lets you lock and unlock the door from your doorbell’s live stream.
Touch once. You’re in.
Wyze Lock Bolt v2 uses a biometric fingerprint scanner to unlock your door in as little as 0.5 seconds, storing your fingerprint data locally on the lock—not in the cloud—so you can ditch keys without sacrificing security when you’re carrying groceries, kids, or luggage.
A person is pressing a button on a Wyze Lock Bolt v2.
Front door control, even when you’re not home.
With built-in Wi-Fi, you can lock or unlock the door, check status, and view activity from the Wyze app—no matter where you are.
A person holding a smartphone with a lock screen on it.
Wyze Lock Bolt v2 Shopify 04
Faster, more reliable unlocks over time.
Traditional locks learn your fingerprint once—and any change means the dreaded “try again.”
Wyze Lock Bolt v2 uses an AI self-learning fingerprint scanner that updates your profile with every touch, adjusting for pressure, angle, and tiny skin changes.
This means fewer failed scans, faster unlocks, and more reliable entry when your hands are cold, sweaty, or your kid taps it at a weird angle.
Protects your code, even with eyes watching.
If someone’s nearby while you’re entering your code, just add random digits before or after your real PIN.
Wyze Lock Bolt v2 ignores the decoys and still unlocks—keeping shoulder-surfers confused and you secure, like when a delivery driver or contractor is standing right beside you.
A keypad that looks better and works smarter.
  • Wyze Lock Bolt v2 Shopify 05 8ace4148 210d 4ac5 8165 69a41fdc0b26
     Durable, Anti-Glare Tempered Glass
    Unlike plastic keypads that peel, fade, and crack, Wyze Lock Bolt v2 uses high-grade tempered glass that resists scratches, smudges, and glare, keeping numbers easy to read and your entryway looking sharp—even after rainy commutes, muddy hands, and daily use by the whole family.
  • A man is holding a smartphone and looking at a door lock.
    Numbered Keypad with Access Codes
    Tap the illuminated glass keypad to create and store up to 50 unique access codes for family, friends, and trusted visitors—or set one-time guest codes that automatically expire on the schedule you choose, perfect for cleaners, Airbnb guests, or a neighbor feeding the cat while you’re away.
Your door locks itself so you don’t have to.
Set a custom auto-lock timer in the Wyze app and Wyze Lock Bolt v2 will lock the door for you after that time passes, so “Did I lock the door?” is no longer a question.
Wyze Lock Bolt v2 Shopify 07 26194ce2 6c7b 44f5 9b19 35e05278e156.
A person is unlocking a door with a Wyze Lock.
Smart lock convenience, classic key backup.
Wyze Lock Bolt v2 is designed to be totally keyless for everyday use, but it still includes a hidden traditional keyway and backup keys for peace of mind.
A black box with 8 AA batteries included.
Months of power, zero daily worry.
With up to 8 months of battery life from the included AA batteries, Wyze Lock Bolt v2 is built for the long haul. You’ll get low-battery alerts well before they run out, so you’re never surprised at the door.
A black device with a green USB-C port.
Emergency power so you’re never locked out.
If the batteries ever fully die while you’re outside, simply connect a USB-C power bank to the emergency port, power the lock for a moment, and enter your code to get in—no lockouts, no locksmiths, ever!
A Wyze Lock Bolt v2 is shown with a sunny day outside.
IP53 weather-resistant & BHMA2 certified.
Backed by the Builders Hardware Manufacturers Association, this lock has been tested, slammed, twisted, and splashed thousands of times to make sure it can handle real life. It meets rigorous standards for security, durability, and performance. It’s not just smart, it’s strong.
BHMA Logo
Wyze Lock Bolt v2 Shopify 12
Works with Wyze video doorbells.
Lock and unlock directly from the live view of your Wyze video doorbell without switching between screens to open the door for family and friends.
Sounds the alarm on suspicious activity.
If someone repeatedly enters the wrong code or tries to force the bolt, Wyze Lock Bolt v2 detects the tampering, sounds a built-in alarm, and can alert you in the Wyze app so you know something’s up right away.
A man is trying to open a door with a smart lock.
A smartphone screen displaying a lock screen with a green circle and the words "Front Door" written in white.
A smartphone screen displaying a fingerprint scanner.
A smartphone screen with a message to create an access code.
A smartphone screen displaying a list of users, including a "Dave You" entry.
The Wyze app is your command center.
*Bluetooth connection required for app features.
See who stopped by in the Wyze app. You can even view how it was unlocked, the exact time, and if there were any failed passcode attempts.
Create and store up to 50 access codes for family and guests, without manually programming each one into the lock. You can also store up to 50 total fingerprints for frequent users.
Create one-time guest passcodes that expire on a schedule.
Worried about giving out access codes to your home? Use auto-expiring codes so you never have to worry about temporary guests entering without permission. Set the day/time the code expires and never think about it again.
Top-notch security features, standard.
  • A cloud icon with a blue background and a blue line through it.
    Local Storage
    Wyze Lock Bolt v2 stores all personal data locally. No cloud required.
  • A blue and white icon of a lock with a keyhole.
    Hardware Encryption
    Built into Wyze Lock Bolt v2. Encrypted so no one (including Wyze) can figure out your code and fingerprint data.
  • A lock icon on a cell phone.
    Two-Factor Authentication
    Used within the Wyze app, so only those authorized are able to use Wyze Lock Bolt v2.
1 of 3
Can't decide? See which smart lock is best for you.
The Entry Point Security Kit Pro includes a keypad, a doorbell, a motion sensor, and a camera.
Wyze Palm Lock
from $99.98 $129.98
Wyze Lock Bolt: Unlock your door in less than a second with the touch of a finger or a tap in the app.
Wyze Lock Bolt
from $74.98 $79.98
Price
$79.98
$129.98
$79.98
App Control
Wi-Fi
Wi-Fi
Bluetooth
Auto-Lock
Timer
Gyroscope
Timer
Power
8 AA Batteries
Removable Battery Pack
4 AA Batteries
Battery Life
Up To 8 Months
Up To 6 Months
Up To 12 Months
Deadbolt Replacement
Emergency Power
Biometrics
Fingerprint
Palm Recognition
Fingerprint
Guest Access
Smart Home Support
Wyze Automations, Google Home, Amazon Alexa
Notifications
Physical Key
Weather Resistance
IP53
IP53
IP53
Color
Black
Black
Black, Satin
ANSI/BHMA
BHMA 2
BHMA 3
BHMA 3
Wyze Doorbell Support
Wyze Video Doorbell v2, Wyze Video Doorbell Pro, Wyze Duo Cam Doorbell, Wyze Battery Video Doorbell
Wyze Video Doorbell Pro (Unlock Only)
View
View
View
Replaces your existing deadbolt. Installs in just 20 minutes.
Wyze Lock Bolt v2 is compatible with almost all exterior doors and replaces your existing deadbolt lock in about 20 minutes. Feel free to watch our installation video below to see how easy the process is.
Support Articles
Installing your Wyze Lock Bolt v2 on a compatible door is easy. You remove your existing lock, put your new lock in place, then set it up in the Wyze app. Follow along in the video below:
You've completed the Wyze Lock Bolt v2 Setup Guide. It's now time to calibrate your lock!
To calibrate your Wyze Lock Bolt v2.
  1. Open the Wyze app and tap on your Wyze Lock Bolt v2.
  2. Tap the Settings gear, then Calibration.Follow along in the Wyze app to calibrate your Wyze Lock Bolt v2.
  3. Close your door and manually lock the deadbolt.
    Check the box next to I have turned the thumb latch.
  4. The Wyze app will display "Calibrating your device..." and the lock will calibrate automatically.
  5. Done with calibration!
Additional Notes
  • Calibrating your Wyze Lock Bolt v2 is a common troubleshooting step when other features like Auto-Lock and door ajar alarms aren't working properly.
Before you setup your Wyze Lock Bolt v2:
  1. Make sure you are connected to data or Wi-Fi (this is only for the initial pairing with the Wyze app).
  2. Enable BluetoothⓇ on your mobile device.If you’re on an iOS device, check that your Location Permissions are also enabled.If you’re on a device using Android 12+, check that your Nearby permissions are also enabled. Make sure that you are in BluetoothⓇ range for connection (16 feet or less).
To set up your Wyze Lock Bolt v2:
  2. On the Add menu, tap Device > Home > Wyze Lock Bolt v2.
  3. If you’ve already installed your Wyze Lock Bolt v2 on your door, tap Skip to skip installation. If not, tap Next to install your device.
  4. Tap Next to continue pairing to the Wyze app.
  5. Press and hold the RESET button on the lock for 8 seconds. The status light will pulse red, then turn solid green. This may take up to 30 seconds.
  6. In the Wyze app, check the box next to "It played a beeping tone" then tap Next.
  7. If BluetoothⓇ hasn't already been enabled, you'll be prompted to allow BluetoothⓇ and Location access. Tap Next.If BluetoothⓇ and location access have already been enabled, it will skip automatically.
  8. The app will automatically search and connect to your Wyze Lock Bolt v2.
  9. If you have a Wi-Fi network that you'd like to connect to, tap Yes.If you want to connect to a different network, tap No, I Will Connect Manually.
  10. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.Tap the icon next to the text field to double-check your password.
  11. Your device will finish pairing automatically. Once complete, it's time to calibrate your lock.
  12. Follow along in the app to calibrate your Wyze Lock Bolt v2. Close and manually lock the door. Turn the thumb latch towards the door opening to extend the deadbolt. In the app, check the box next to "I have turned the thumb latch" then tap Next. The device will now calibrate.
  13. Next, follow the in-app steps to create your Access Code and add your fingerprint.
  14. You're all set! Tap Done.
FREE shipping on orders $0+
