1 of 6
Wyze Switch
Wyze Switch
Smart In‑Wall Wi‑Fi Light Switch
Size
$41.98 $44.97
Turn normal lights into smart lights and control them from anywhere. Multi-tap to control other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
  • A black screen with a white light bulb icon.
    Works with Regular Bulbs & Wyze Bulbs
  • A hand holding a phone.
    Controls Other Wyze Devices
  • A black background with a white microphone icon.
    Works with Alexa and Google Assistant
  • A black background with a white icon of a switch.
    Set Timers, Schedules, & Automations
Yes, this switch does require neutral wiring, which is common in homes built after 1980. If you do not have a neutral wire, your wiring is not compatible with Wyze Switch.
About 20 minutes, following the step by step installation process in the Wyze app.
No, this is a single pole switch only. It cannot be used as a multi-way switch.
The response when you press the switch is instant, similar to the response time of a regular switch when smart controls are disabled. With smart controls enabled, there’s a delay of .3s with a single-press.
No, Wyze Switch only comes in white at this time.
Yes, Wyze Switch can be used to interact with the entire Wyze ecosystem of smart products. You can even setup triggers and actions using Rules.
Yes, the switch works with Alexa and Google Assistant.
Yes, Wyze Switch can interact with smart devices outside the Wyze ecosystem by integrating it with IFTTT.
No, Wyze Switch is not a dimmer switch.
Yes, Wyze Switch can be used for multi-gang setup, but be aware of the maximum loads per switch: 1 gang= 600W, 2 gang= 500W, 3 gang = 500W.
All your lights just got smarter.
Upgrade to smart lighting in any room with Wyze Switch, a smart, WiFi light switch. Control your lights from anywhere with the Wyze app and create automations that bring light to your life.
A person holding a phone with a blue screen.
Take control of your smart home ecosystem.
Wyze Switch integrates seamlessly with your Wyze ecosystem with four custom actions. Personalize each action to fit your life: Single-press to turn on the lights, double-press to lock the doors, triple-press to turn on the robot vacuum, and press-and-hold to spray unwanted guests with Wyze Sprinkler Controller.
A woman sleeping in a bed with a white comforter.
A large house with a pool in the backyard.
A wall-mounted switch for a bedroom light.
Smart controls you would expect.
Create powerful automations in the Wyze app or set a timer to have your lights turn on or off.
Make it look like someone's home whenever you are away. Just enable Vacation Mode in the Wyze app and our switch does the rest.
If there is a power loss, Wyze Switch will automatically reconnect to Wi-Fi and return to its previous state, once power is restored.
It’s easy to install Wyze Light Switch.
Support Articles
Check for these two things:
Additional Note:
For more details about Wyze Switch compatibility, check out: Is my wiring compatible with Wyze Switch?
Wyze Switch is a smart switch that you can control manually with the button itself, or using the Wyze app. We recommend setting it up in the Wyze app to get access to smart features like automations!
Before your switch can be set up in the Wyze app, it must be installed and connected to power. We recommend following along in the app and referencing our Wyze Switch Installation Guide before proceeding.
To set up your Wyze Switch:
  3. Tap Power & Lighting > Wyze Switch.
  4. Read the High-Voltage Wiring warning. Tap Next.
  5. Confirm that you are replacing a single pole switch with neutral wiring. Tap Next.
  6. Follow along in the app to install Wyze Switch if you haven't already. If already installed, tap Skip Installation Guide.
  7. If prompted to give BluetoothⓇ and location permissions, please enable those in your phone's settings.
  8. In the Wyze app, select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
  9. The app will search for your Wyze Switch. It should connect automatically.
  10. Name the device in the Wyze app. Tap Finish.
  11. You’re all set. Enjoy your new Wyze device!
Download the Quick Start Guide for Wyze Switch in this article.
Below is the Quick Start Guide for Wyze Switch, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Switch including:
  • What's in the box for Wyze Switch.
  • How to set up your Wyze Switch.
  • How to use your Wyze Switch
  • How to read the status lights on your Wyze Switch.
FREE shipping on orders $0+
