1 of 4
Get notified of leaks.
Style
Add ons
$15.98
Use a 5-digit ZIP code.
Get notified of leaks. Use with Wyze Sense v2 or Wyze Home Monitoring.
No, these sensors are not standalone product and must be paired with a Wyze Sense Hub to function. Need a Wyze Sense Hub? Check out the Wyze Home Monitoring Core Starter Kit.
No, but the leak and climate sensors will not work without the Wyze Sense Hub (available with a subscription to Wyze Home Monitoring). If you have a hub but no active subscription, you will still be able to use your leak and climate sensors.
Yes, all Wyze Leak Sensors can work without the Wyze Leak Sensor Probe. Wyze Leak Sensor Probe will not be able to operate without a Wyze Leak Sensor.
32-104 F (0 to 40 C)
≤ 85% at 86°F (30°C)
The range is up to 500 feet in ideal conditions. Please keep in mind that walls and other interference between the sensors and hub may decrease this range.
No, these sensors are incompatible with Wyze Sense v1. They must be paired with a Wyze Sense Hub, found in the Wyze Home Monitoring Core Starter Kit.
Yes, the Wyze app is able to differentiate between the leak sensor and leak sensor probe. You can turn off this feature if you prefer.
Yes, but the accuracy of the sensors will be decreased and it is not recommended.
No, these sensors are for indoor-use only.
You'll be able to set notifications for temperatures between 32-104º F (0-40º C) and humidity from 0% to 85%.
FREE shipping on orders $0+
