Skip to content
Wyze Home Monitoring
Superior performance. No contracts. Cheaper than Netflix.
  • 24/7 Professional Monitoring
    Our dedicated, real-life-human agents at Noonlight are there 24 hours a day to get you the emergency help you need.
  • Deep Integration with Wyze Cameras
    Optimized viewing experience for monitoring. Security Cameras empowered Threat Alerts to help you guard threats out of your doors. And more to come.
  • Easy Installation
    Enjoy the easiest installation of any professional home monitoring system with easy, step-by-step instructions.
  • "Wyze makes smart home security more affordable."
  • "Clearly, this brand has something different to bring to the table."
1 of 2
Meet our monitoring system.
Each sensor, hub, and keypad has been designed to fit wherever you need them. From corner mounts, to skinny probes, we've thought it through so you don't have to.
1) Wyze Sense Hub, 2) Wyze Sense Motion Sensor, 3) Wyze Sense Keypad, 4) Wyze Sense Entry Sensor, 5) Wyze Sense Climate Sensor, 6) Wyze Sense Leak Sensor, 7) Wyze Leak Sensor Probe
  • Peel. Stick. Done.
    Our entire security system can be installed without ever picking up a tool. Every sensor, including our backlit keypad, can be installed by just peeling and sticking it exactly where you need it. Screws are also included for secure installation on any surface.
  • Expandable. Adaptable.
    Install up to 100 sensors and easily remove them if you move. Wyze Home Monitoring is fully adaptable to your life and expandable if your needs change.
Remotely arm/disarm
Control your monitoring system right from your phone—no matter where you are. Arm and disarm your system and check on each sensor's status from the Wyze app.
View camera live feeds
Quickly view all your cameras' live feeds in one place and scroll through motion-activated event recordings. Say "hello!" with two-way audio and customize how you want to be notified when motion or sound is detected.
Detect leaks and frozen pipes
Just like if a security sensor is tripped, you'll get a text and call from Noonlight if a leak is detected in your home so you can act quickly to mitigate the damage.
*Wyze Sense Leak and Climate Sensors required
Customize monitoring rules
Create arming/disarming schedules to automate your home security. Never wonder if you forgot to disarm your system again.
Share access with family and friends
Parents coming to watch the kids and need access to the Wyze Cam above the crib? No problem. Quickly share and revoke access to all your Wyze devices at any time.
24/7 professional monitoring empowered by Noonlight.
A simple, 3 step process is employed to make sure false alarms are minimized, but that helps arrives ASAP in an emergency.
Your home automation hub.
A motion sensor that turns on the lights. An entry sensor that cranks the A/C and turns on the lamp. Your individual Wyze devices are awesome, but with Wyze Home Monitoring sensors, the possibilities are endless.
  • Apartments and Condos
  • 1-2 Bedroom Homes
  • 3+ Bedroom Home
1 of 3
Peace of mind is a click away
Wyze Home Monitoring Service
You only need one subscription plan to cover a single household.
Secure and protect your home with 24/7 professional monitoring.
Plan
$9.99
  • “Excellent service, fast response time, exceptional monitoring quickness, very fast cost-efficient equipment.”
    — Bakersfield, CA
  • “Wyze services and products have always proven 100% time and times again.”
    — Las Vegas, NV
  • “I absolutely LOVE every product I own. I tell sooooo many people all about it, all the time. I am a single mom and every item is so reasonably priced, I just love it all!”
    — Elgin, IL
1 of 3
ß
