1 of 8
Wyze Cam Floodlight v1
Potent outdoor security solution - PCMAG
Check out the newer model:
  • 2K HD Resolution & Color Night Vision.
  • 160° View + 270° PIR Motion Detection.
  • 2800 Super-Bright LEDs.
  • 2 Bright Spotlight Design.
  • 24/7 Recording with MicroSD Card.
  • Two-way talk + loud siren.
Get Floodlight v2
Low stock: 16 left
The floodlight that makes you feel seen. And filmed. And recorded. You and any other poor sap who happens to stroll in front of its 270 degrees of customizable motion detection and 2600 lumens of baddie-banishing light. Two-way audio. Color night vision. Extra USB port. And enough light to give your trespassers tans while it discourages them. Okay, fine, not really. But seriously, let's blind someone! If they wanted their retinas, they wouldn't have wandered into your yard.
  • 2000 Lumens
    Super-Bright 2600 Lumen LEDs
  • A black background with no visible content.
    270° Motion Detection
  • Color night vision camera.
    1080p Full HD & Color Night Vision
  • An extra USB port on a computer.
    Connect a Second Wyze Cam v3
Wyze Cam Floodlight Details
Color & Materials
  • Color: White
  • Wyze Cam v3: Body (Polycarbonate), Lens (Glass + Plastic)
  • Floodlight: Body (Polycarbonate, Glass + Plastic)
  • Weight: 2.76 lbs (Assembled)
USB Ports
  • 1 port for Wyze Cam v3
  • 1 port for an additional Wyze Cam v3
Camera Details
  • Resolution: 1920 X 1080 (1080p)
  • Field of View: 121° lens
  • Night Vision
  • Starlight Sensor Color Night Vision
  • IR night vision
  • Audio - Speaker: 90 db
  • Microphone: Built-in, digital
  • Siren: 105 db at 4'
Sensor
  • 270º PIR Motion Sensor
Light
  • LED: 2600 lumen
  • Dimmable: Yes
  • Controls: Schedule, Motion Trigger
Dimensions
  • 9.5 in x 7.0 in x 7.7 in (Length x Depth x Width)
Power
  • Hardwired 110V~120V
  • Uses about 46W of power
Connectivity
  • 2.4GHz WiFi
Storage
  • Local Storage (microSD card required)
  • Cloud
Compatibility
  • Phone: Android 9.0+ and iOS 15.0+
  • Camera: Wyze Cam v3
Supported Services
  • Cam Plus, Wyze Home Monitoring
Weather Resistance
  • IP65-Rated
Certifications
  • FCC, UL, CE, IC
Warranty
  • 1-Year
Wyze Cam Floodlight (assembled) x1
Quick Start Guide x1
Mounting Accessory Kit x1
  • Bracket Screws (#6, #8, and #10) x2
  • Ground Screw x1
  • Floodlight Screw x1
  • Rubber Stopper x1
  • Mounting Bracket x1
  • Wire Nuts x2
  • Hook x
Yes, it comes with a Wyze Cam v3. It also has an additional USB port that can connect to an additional Wyze Cam to provide wider visual coverage.
Yes, it can be mounted on a wall or under an overhang. Both mounting kits are included.
Yes, you can adjust the camera angle. You can also use the extra USB port so you can add another camera for more coverage.
By default, Wyze Cam Floodlight will automatically turn on when motion is detected. While viewing the live stream, turn off night vision. Only a little light is needed for a clear image and a street light or night light outside would work. If you need more light, you can manually turn on the floodlight in the Wyze app for better illumination.
It's a special CMOS sensor that is very sensitive to light. This allows Wyze Cam v3 to create an astonishingly clear image - even in extremely dark conditions.
1080p FHD (1920x1080 Full HD).
No, Wyze Cam Floodlight must be hard-wired either in place of an older floodlight or using a junction box. Please contact a licensed electrician for help if you do not have one set up yet.
Yes, the LED lights are dimmable.
No, the color is not customizable. It is 5000k white LED.
Yes, it is IP65 rated.
Yes, you can schedule the floodlight to turn on/off via Rules in the Wyze app.
With normal use, the lights can be used for about 50,000 hours.
No, the floodlight kit is sold as a full package with an attached Wyze Cam v3.
No, Wyze Cam Floodlight does not support 5GHz WiFi. It only supports 2.4GHz networks.
The main camera that comes pre-assembled controls the floodlight. This includes turning it on or off manually or using automatic features like motion detection or schedules. If you add another camera using the second USB port, it works as a normal Wyze Cam v3 without controlling the floodlight.
Wyze Cam Floodlight surpasses its direct competitor — and it’s also almost $100 less."
- The Verge
Your (yard’s) future’s so bright, you gotta wear shades!
2 super-bright, adjustable LED lights with a combined 2600 lumens of baddie-deterring power for you, and a handy dimming option for your long-suffering neighbor.
A green light is shining on a white wall.
Customized detection of more than just motion.
3 PIR sensors provide 270° of customizable detection. Turn them on and off individually, plus adjust range and sensitivity up to 30 feet. Throw in sound detection and advanced AI* and not even an invisibility cloak is getting past this thing.
* Cam Plus required for advanced AI features
A person holding a smartphone with a live view of a Wyze camera.
From detection to inspection.
Know what your detector detected! Wyze Cam Floodlight doesn't just detect and deter motion, its built-in, award-winning Wyze Cam v3 also identifies motion and records it in 1080p Full HD with our can't-believe-it's-not-daytime Starlight Sensor Color Night Vision.
The Dusk-to-Dawn Automation!
Henceforth, the correct answer to, “Did you remember the lights?” is, “Why would I need to?” Wyze Cam Floodlight knows when the sun is down and when it’s up. Just hook it up and never think about your light switch again.
A WyzeCam Floodlight mounted to a brick house.
Double the cameras for double the coverage with an extra USB power port.
What’s better than one Wyze Cam v3? Two. The answer is two. Double your camera coverage and look both ways with an extra port for a second Wyze Cam v3 (sold separately).
A WyzeCam Floodlight with a spotlight on in rainy weather.
Shrug off dust, rain, and snow with IP65 weather resistance.
Built for a beating! Wyze Cam Floodlight keeps doing its job in brutal conditions from dust clouds to downpours.
A white camera with a black circle in the middle.
Floodlight rules in app
Can help you?
Can help you?
Plus, all the usual benefits of a Wyze Cam v3 (or two).
Deter bad guys with more than just bright lights.
Wyze Cam Floodlight is fully integrated into your smart home ecosystem. Use a variety of automations and advanced settings from Vacation Mode to Rules to make it fit your needs.
Don’t just imply intruders are unwelcome with your bright floodlights. Make it explicit with two-way audio! Or strike up a conversation! There are stranger ways to make new friends.
Watch the installation video.
The Home Depot logo is orange and white.
Proudly launching and developed in partnership with The Home Depot.
Compare Floodlights
Compare Floodlights
Wyze Cam Floodlight Pro is a 2.5K QHD camera with a 180 wide-angle lens and 3000-lumen light.
from $124.98 $149.98
Wyze Cam Floodlight v1 - A powerful outdoor security solution with a built-in floodlight for increased visibility and.
from $79.99 $93.99
Camera Resolution
2.5K
2K
1080p
Field-of-View
180°
160°
130°
Lumens
3000 lm
2800 lm
2600 lm
Floodlight Heads
Color Temperature
5000K
5000K
5000K
Wi-Fi Connectivity
2.4/5 GHz Dual-Band
2.4 GHz
2.4 GHz
Vision AI Light Control
With Cam Plus Subscription
Motion Detection
Vision AI
PIR
PIR
Sirens
105dB
105dB
105dB
Ambient Light Mode
Motion Warning
Device Setup Mode
Bluetooth®
Wi-Fi
QR Code
IR Lights
12 x 850nm
6 x 850nm
4 x 850nm, 4 x 940 nm
MicroSD Card Compatibility
Up to 256 GB
Up to 256 GB
Up to 256 GB
Power Supply
Hardwired 110-120V
Hardwired 110-120V
Hardwired 110-120V
Smart Integrations
Amazon Alexa, Google Assistant, IFTTT
Certifications
FCC, UL, CE, IC, IP65
View
View
View
Support Articles
Download the Quick Start Guide for Wyze Cam Floodlight in this article.
Below is the Quick Start Guide for Wyze Cam Floodlight v1, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Cam Floodlight, including:
  • How to set up the floodlight.
  • Where to install the floodlight.
  • How to do an overhang mount.
  • How to do a wall mount.
Installing your Wyze Cam Floodlight is as simple as replacing your existing floodlight by connecting it to a junction box. As long as you have a junction box and neutral wiring, and self-installation is legal in your area, this process should take about 30 minutes.
-> You must have an existing junction box and a neutral wire to use Wyze Cam Floodlight.
-> At the electrical panel, shut off power to your junction box before proceeding.
Before you begin installation:
Check your local laws and building codes before doing any performing any electrical work. Your may live in an area that requires a permit and professional installation.
What’s in the box?
  • 1x Wyze Cam Floodlight (Assembled)
  • 1x Mounting Accessory Kit 6x Bracket Screws 2x #62x #82x #10 1x Ground Wire Screw1x Floodlight Screw1x Rubber Stopper1x Mounting Bracket2x Wire Nuts1x Hook
  • 1x Quick Start Guide
Required tools:
  • Phillips Screwdriver
  • Ladder
To install your Wyze Cam Floodlight:
  1. In the Wyze app, tap the +plus sign then Device > Cameras > Floodlight Camera > Wyze Cam Floodlight.
  2. Read the High Voltage warning before tapping Got it!
  3. Select your mounting location, Wall Mount or Ceiling Mount.
  4. Are you replacing an existing floodlight? If yes, tap I'm replacing an existing floodlight. At your electrical panel, turn off power to your floodlight. Tap Next.Carefully remove your existing floodlight. Tap Next. If no, I don't have a floodlight to replace. Do you have an existing junction box? If yes, tap Next. Check that your junction box is at least 10 feet off the ground. Tap Next. If no, your wiring is not compatible with Wyze Cam Floodlight. Stop the installation process and contact a licensed electrician for assistance. Tap Check Your WiFi Signal Strength in the Wyze app. If your signal is Out of Range or Poor Connection, contact your ISP for options.Tap Continue Setup. Tap Start Installation.
Continue below, following along in the Wyze app to wire your floodlight.
  1. For the device you'd like to install first, tap Wyze Cam Floodlight.
  2. IMPORTANT: At your electrical panel, shut off power to your floodlight. Tap Next.
  3. Confirm that you have the required tools and the In the Box items. Tap Next.
  4. Follow along in the Wyze app, and use the installation video below for reference.
