1 of 12
our newest outdoor cam
Wyze Battery Cam
Wyze Battery Cam
No outlets? No problem.
WyzeOutdoor cams are recommended by
CNETThe VergeWirecutterUSA TodayPCMag
Quantity
Solar Panel
13M+ Households Trust
$59.98
Use a 5-digit ZIP code.
The Essential Outdoor Cam.
  • Color Night Vision
  • IP65 Weather Resistant
  • 2K HD Video
  • Integrated Spotlight & Siren
  • 2 Way Audio
  • Outdoor/Indoor.
    Wire-Free. No Hub.
  • Person Detection
  • Easy Install
    Place it anywhere
  • Local Recording to MicroSD Card
  • Warranty
  • Backyard Fence
    No outlets. No extension cords. No trudging through the backyard to replace dead batteries.
  • On a Tree
    Don't have a fence? A tree works just fine. It won't feel any pain we promise.
  • Shed or Garage
    Keep an eye on detached garages, sheds, and outbuildings, even where there’s no outlet.
1 of 3
It feels so good to
Never Wonder.
Don't take our word for it
13,000,000+
families trust
Here's what they had to say about our last Battery Cam
    Easy install
    Up in 1 minute
    Install guide
    What you need
    • Phone with Wyze App
    • Drill/screwdriver to mount
    • WiFi Connection
    • Your beautiful self
    1. Charge: Indoors, 4–6 hours until the charging light turns blue.
    2. Pair: Hold SETUP until the voice prompt, then add the camera in the app.
    3. Mount: Install 7–10 feet high, angle 30° downward and tighten.
    Built for any weather
    Set it. Then genuinely forget it.
    With IP65 weather resistance and solar charging, you can forget about it completely. Its feelings will be fine.
    -4° to 122° degrees Fahrenheit
    So fast you’ll think it’s wired. It’s not.
    Load your cameras instantly
    2.4 GHz Wi-Fi with Wi-Fi 4/5/6 support.
    2K clear resolution
    Other cameras miss stuff.
    This one doesn’t.
    Mystery blobs had a good run.
    Night as bright as day
    with Color Night Vision
    Color Night Vision
    Starlight Sensor makes you feel like a damn owl.
    It’s incredible at night. So incredible, in fact, that one time at 2:00 AM a car accident was caught on Wyze Cam. A celebrity was involved. A nearby neighbor submitted the footage to investigators as evidence for the trial. Then the judge threw out the evidence because the camera could see so well in the dark and was so superior to the human eye that it was misleading to a jury as to what was realistically visible when the person caused the accident. Anyway, are you still reading this? Nobody ever really scrolls this far down the page, so we don’t really put a lot of time into the marketing stuff down here. You must really want this camera if you’re researching this deep, Just buy it already. Or keep reading cause there actually are a lot more cool features to tell you about.
    Supports microSD
    Local recording makes subscriptions your choice
    Rolling local storage saves months of motion events on a microSD card, sold separately. Cloud storage options + AI features are available with a paid plan.
    Spotlight and siren send intruders scrambling.
    A 105 dB siren and 100-lumen spotlight can fire the moment activity is detected.
    Two-way audio for deep talks.
    A camera or a walkie-talkie?
    Call the kids, tell the delivery guy where to leave it, or just say “10-4.” You know you’ve always wanted to do that.
    The best of the rest.
    • Timelapse mode
    • Alexa and Google integrations
    • Device sharing
    • Detection zones
    • Fire alarm detection
    • Honestly so much more, just buy it we are exhausted from writing about all of these features there are too many.
    Frequently Asked Questions
    • Up to 4 months on a single charge!
    • Check out our Wyze Solar Cam, it's the battery cam... with a solar panel, and for only 10 bucks more! Set it and forget it with maintenance-free solar charging, directly from the sun to your Wyze cam
    • Yes! The Wyze Solar Cam comes with an adjustable and detachable panel, so you can set it and forget it. No need to charge the battery, the sun handles that.
    • Local recording to a microSD card up to 256GB, exFAT or FAT32, sold separately. For 24/7 continuous local recording the camera needs to stay on constant plug-in power. Cloud storage options are available too with Cam Plus, Cam Unlimited, and Cam Unlimited Pro.
    • 2.4GHz. It supports Wi-Fi 6 (4 & 5 also supported) for a stronger connection and smoother livestreaming if you've got a Wi-Fi 6 router. Setup runs over Bluetooth in the Wyze app.
    • IP65 weather resistant and rated from -4°F to 122°F. White or black, 1-year warranty.
    FREE shipping on orders $0+
