1 of 13
Wyze Air Purifier
Wyze Air Purifier
HEPA 4‑Stage Air Cleaner
Highly Recommended
By Trusted Reviewers
Pre-installed filter
Add a Wyze Air Filter Subscription
$169.99
Wyze Air Purifier clears the air, friends! And what happens when the air hasn’t been cleared? Misunderstandings, that’s what. Grudges. First thing you know, someone wants a divorce. Now it’s six years later, you're living in a motel, and your kids have blocked you on Instagram. Buy a Wyze Air Purifier and save your marriage. Premium filters and 350 CADR at 21 whisper-quiet decibels. Plus smart controls, AQ alerts, and laser particle detection. A luxury air purifier without a luxury price tag.
  • Wind flow icon.
    Powerful Purification
    Capable of cleaning a 500 ft² room over three times in an hour (350 m³/h CADR).
  • A black background with a leaf icon.
    Three Filter Options
    All True HEPA with granulated carbon for 99.97% elimination of a wide range of pollutants.
  • A quiet icon on a black screen.
    Whisper Quiet
    Sleep beside it on low (21 decibels) and speak beside it on high (54 decibels).
  • A black background with a white laser icon.
    Laser Particle Sensor
    Precision sensor measures air quality down to 0.3 microns and adjusts automatically.
Wyze Air Purifier Details
Color & Material
  • Color: Gray
  • Plastic
Dimensions
  • 9.5 in x 9.4 in x 18.5 in / 243 mm x 240 mm x 472 mm
Weight
  • With Allergen Filter: 8.75 lb / 3.97 kg
  • With Wildfire Filter: 9.32 lb / 4.23 kg
  • With Formaldehyde Filter: 9 lb / 4.08 kg
Operating Specs
  • Operating Temperature: 14°F - 104°F / -10°C - 40°C
  • Operating Humidity: < 85%
  • Environment: Indoor use only
Noise Level/Flow Rate:
  • Level 1: <20.8 dBA, 51 m3/h
  • Level 2: <24.6 dBA, 152 m3/h
  • Level 3: <44.5 dBA, 310 m3/h
  • Level 4: <52.1 dBA, 399 m3/h
Particulate Matter CADR
  • Allergen: 350 m3/h / 206 CFM
  • Wildfire: 342 m3/h / 201 CFM
  • Formaldehyde: 317 m3/h / 186 CFM
Additional details
  • Wildfire Filter H2S Removal Efficiency: 98.9%
  • Formaldehyde TVOC Removal Efficiency: 97.3%
  • Effective Area: 450-550 ft2
  • Rated Power: 120V/60 Hz, 3.5 to 45W
  • Model Number: WSAPUR
A black and grey air purifier with a green filter.
  • x1 - Wyze Air Purifier
  • x1 - Filter (Pre-installed, remove packaging before use)
  • x1 - Quick Start Guide
  • x1 - QuickGuide for First Use
The power supply of Wyze Air Purifier is AC 120V / 60 Hz. In other areas outside of the US and Canada, a voltage converter may be needed. Some app features such as outdoor air quality monitoring may not be available outside of the US and Canada.
Because air pollution is a pervasive and continuous problem, it's best to leave your air purifier on all day. Air pollutants like pollen, traffic gas, and smoke, can transfer to your home from outside while others like cooking, cleaning, and furniture off-gas throughout the day are generated inside. Wyze Air Purifier is designed to run around the clock and keep the pollution level low 24/7. If you run Wyze Air Purifier at the max fan speed, 24 hours a day, for an entire month, the energy cost is only around $3.50.
We recommend running your Wyze Air Purifier continuously to circulate the air and reduce the air pollution level. In a home with an HVAC system circulating air, the air coming out of your vents will be significantly dirtier than the air in the room with the air purifier—especially considering most homes rarely have their air ducts cleaned. Wyze Air Purifier is energy efficient and quiet when the pollution level is low, so you can keep your air clean 24/7.
Wyze Air Purifier is CARB certified, which means it does not exceed ozone emission limits. Our units do not use any ionization-based components which could generate harmful byproducts.
Wyze Air Purifier (regardless of the filter equipped) is designed to remove both particulate and gaseous pollutants commonly found at home, including dust, pollen, mold, pet allergens, viruses & bacteria, volatile organic compounds (VOCs), odors, and tobacco smoke.
Wyze Air Purifier comes with one of three interchangeable options. Wyze Air Purifier with Allergen Filter is considered to be sufficient to handle common pollutants found in most homes. The Wildfire Filter is particularly effective against smoke generated from wildfire, industrial processes, and traffics. The Formaldehyde Filter is designed to be extra efficient for the removal of chemical gas such as VOCs, and even formaldehyde, thanks to its manganese catalyst material. VOCs are commonly found in household products, e.g., cleaning agents, paints, varnishes, furniture, and wax, and generated in activities such as cleanings, applying cosmetics, and smoking. The formaldehyde filter is recommended for homes with smokers, new constructions or remodeling, or new products such as new furniture.
It’s tempting to think we are safe from the dangers of air pollution when in the sanctity of our own homes. However, indoor air is on average 4x to 5x more polluted than outdoor air, according to the US EPA. Outdoor air will travel inside at certain times, and local allergens and auto emissions will also make their way into your home and become trapped due to poor ventilation. We recommend using air purifiers for short-term and long-term health benefits, regardless of your home's distance from outdoor pollution sources.
Once you subscribe to our Wyze Air Purifier filters on Wyze.com, Wyze will ship one filter of your choice to you, at the frequency of your choosing, with a 12% discount. You will only be charged at the moment of shipment.
The filter life and performance could vary depending on usage and your home environment. In general, we recommend replacing your air purifier filter at least every 6 months to maintain the best performance.  Your Wyze App will let you know when it is time to replace the filter.
If you only have one air purifier, the ideal place to put the air purifier is the room in your home where you spend the most time out of each day. For most people, this will either be your bedroom or living room. Try to keep your unit at least 1 foot away from walls or furniture and avoid blockage of air entrance and exit vents. This will allow air to circulate properly and the air purifier to operate more efficiently.
Wyze Air Purifier is effective in rooms up to 550 sq. ft (42 m2). For slightly larger rooms, you can run the unit at a higher fan speed for longer periods of time to achieve the same cleaning performance.
Meet Wyze Air Purifier!
Picking the perfect purifier isn't complicated. Find out what makes Wyze Air Purifier a luxury air purifier without the luxury price tag.
A Wyze air purifier with a 350 CADR.
Powerful air-scrubbing technology.
Wyze Air Purifier cycles a whopping 12,000 cubic feet of air every hour (350 m³/h CADR)!
Translation: it’s like dumping two swimming pools full of clean, pristine air into your house every sixty minutes.
A person is pointing at a button on a device.
Cleans your air on auto-pilot.
Auto Mode so effective, you might never touch Wyze Air Purifier again until it’s time to change the filter.
Plus, control the fan speed, dim the display, and a handy child lock—you know, in case your toddler has other ideas.
Wyze Air Purifier is also fully compatible with Google Home and Alexa.
A black air purifier with a digital display showing the current time and air quality.
We’d say “purrs like a kitten,” but it’s actually 4 decibels quieter.
Operates between 21 and 54 decibels without sacrificing power.
For reference's sake, a purring kitten is 25 decibels and light rainfall is 50. So somewhere between kitty cuddles and a misty morning.
Premium custom filters for premium custom cleans.
Allergens in spring? Wildfires in summer? New construction? Pets? Viruses and bacteria?
Cleaning needs change. Wyze Air Purifier can change with them thanks to three custom filters, all true HEPA, packed with granulated carbon and other catalyst materials.
Air purifier hepa filters sm.
Three filters with different options for allergen, formaldehyde, and wildfire.
A smartphone screen displaying a message about the air quality in the room.
A smartphone screen displaying a message about the air quality in a room.
A smartphone screen displaying a graph of outdoor pollutants.
A smartphone screen with a manual page open.
Smart controls and automation.
One of the handiest app interfaces we've ever designed, and fully compatible with Alexa and Google Home.
The solid circle reports the indoor air quality straight from Wyze Air Purifier's laser particle sensor.
The outer halo reports the outdoor air quality with hyper-local accuracy.
Instant, actionable insights for your health plus quick device controls, right at your fingertips.
The Air Quality History screen goes deep, with a detailed view of what's outside and inside.
Track individual pollutants to better understand what you may be reacting to on a given day.
Having a party and want to run Wyze Air Purifier on high for two hours before guests arrive?
Putting the baby down for a nap and want to keep Wyze Air Purifier on low?
Easily control Wyze Air Purifier from anywhere through the app, with customized manual controls.
A smartphone displaying the air quality in a room.
Air quality accuracy down to 0.3 microns.
Most purifiers use outdated infrared sensors that only detect large particles once every few minutes.
Wyze Air Purifier's laser particle sensor checks ultra-fine particles in the air 100 times a second, nearly approaching the compulsive regularity of a teenager with a phone.
A woman is laying on a couch with a baby, and the phone screen shows air quality.
Actionable insights, personalized to you.
Don't waste your time with air quality generalizations you could find on any weather website.
The Wyze app's hyper-local measurement literally knows the air quality difference between your yard and your neighbor's, and displays it based on your personal air-quality needs.
Easy moves and maintenance.
Handy handle for carrying from room-to-room, and filter replacement so quick and painless, you’ll wonder if you skipped a step.
  • A person is holding a black device with a handle on the back.
    Convenient handle
  • A man holding a speaker with a red lid.
    Simple filter changes
1 of 2
Support Articles
Setting up your Wyze Air Purifier is as simple as removing all of the packaging, plugging it in, and connecting it to the Wyze app. But we've added a little more detail in this guide.
Before setting up Wyze Air Purifier:
  1. Remove the air purifier from the packaging.
  2. Turn the air purifier over to locate the orange filter cover. Rotate and remove the cover.
  3. Take out the pre-installed filter and remove the plastic packaging. You must remove all packaging and wrapping before proceeding.
  4. Re-install the now plastic-free filter into the air purifier.
  5. Put the filter cover back in place and rotate to close.
  6. Plug the air purifier into a power outlet. The device should make a beep sound and both the screen and indicator lights should light up for about 2 seconds.The On/Off indicator should stay half-lit to indicate that the air purifier is powered and that the device is in standby mode.
  7. Press the On/Off button to get the air purifier ready for a network connection. The device should make a beep sound and the Wi-Fi icon on the air purifier’s screen should flash.
Tip: If the Wi-Fi icon is not flashing, reset the air purifier Wi-Fi by pressing and holding the Auto and Speed button simultaneously for at least 3 seconds.
To set up your Wyze Air Purifier:
  3. Tap Home > Wyze Air Purifier.
  4. Tap Begin Preparation.
  5. Have you done the steps above, under "Before setting up"? If you have not, tap Begin and follow along in the Wyze app. If you have, tap Already Installed and continue below.
  6. The Wyze app should immediately begin searching for the air purifier. On the “Select the number shown on your Air Purifier” page, select your device.
  7. Wait for the app to pair with the purifier.
  8. Select your 2.4 GHz Wi-Fi network.
  9. Enter the password for your 2.4 GHz Wi-Fi network.
  10. Wait for the air purifier to finish connecting. Not connecting? Check out: Wyze Air Purifier Setup Troubleshooting
  11. Name your air purifier.
  12. You’re all set. Go on, enjoy the fresh air!
Download the Quick Start Guide for Wyze Air Purifier here.
This guide is a short user manual with the basics about the air purifier, including:
  • How to prep the purifier before setup.
  • How to set up Wyze Air Purifier.
  • Where to place the purifier.
  • How to read the Display Screen.
  • How to use the touch buttons.
  • Basic troubleshooting.
Problem:
Your Wyze Air Purifier does not complete setup or gets stuck at the “Select your network” step in the Wyze app.
Troubleshooting Tips:
  1. Confirm your Wyze app is up to date. Go to the Account tab > tap About. The app version will be listed beneath the Wyze Logo. You can compare your app version to the most up-to-date version listed on our Release Notes and Firmware Page.
  2. Make sure that you’re following the steps provided in the Wyze Air Purifier Setup Guide.
  3. Take the filter out of the air purifier and check that the plastic has been removed from the filter.
  4. Make sure that the filter lid at the bottom of the air purifier is locked properly. Try unlocking and locking the filter lid to confirm this.
  5. Try moving your phone closer to the air purifier then press Try Again.
  6. Check that the Wi-Fi icon is flashing. If it is not flashing, press and hold the Auto Mode and Fan Speed buttons on your air purifier simultaneously for at least 3 seconds until the indicator lights flash.
  7. Check sure that your air purifier is turned on. The display should be on and show the current AQI.
  8. Check that your device is connected to a 2.4GHz Wi-Fi network.
  9. Toggle your device’s Bluetooth off and then back on.
  10. Check that location permissions are enabled for your device. You can check this by going into your device’s settings.
  11. Factory reset the air purifier. Press and hold the power button for 10 seconds.
  12. Perform a Wi-Fi reset. Press and hold the Auto Mode and Fan Speed button until the Wi-Fi icon starts to flash.Set up the air purifier as new.
FREE shipping on orders $0+
$280.00 $235.99
