1 of 6
Wyze Window Bird Cam Perch
$14.98
Use a 5-digit ZIP code.
30-day returns
Give birds more room to perch and more ways to feed with Wyze Window Bird Cam Perch. Designed to attach to the Window Bird Cam seed tray, it provides a sturdy place for visitors to rest and snack right outside your window. Add fruit, suet, or jelly with the included feeding attachments to attract a wider variety of birds. Window Bird Cam and feeder sold separately.
$14.98
More room to perch.
More ways to feed.
Includes a bird perch, fruit fork, suet ball feeder, jelly cup, and screw assembly.
← Explore Window Bird Cam
Key features
  • A place to land
  • Fruit, suet & jelly
  • Made for Window Bird Cam
  • Easy M5 screw assembly
Tech specs
Design & fit
Product & finish
  • Green & white
  • Plastic / metal
Compatibility & assembly
  • Wyze Window Bird Cam seed tray
  • M5 threaded mount points; screw assembly
Dimensions & weight
Perch
  • 8.2 × 5.02 × 1.94 in
  • 0.22 lbs
Package
  • 8.74 × 5.14 × 2.64 in
  • 0.44 lbs
Use & storage
Operating temperature
  • 14°F to 113°F (−10°C to 45°C)
Storage temperature
  • −40°F to 158°F (−40°C to 70°C)
What’s in the box
  • Bird Perch x1
  • Fruit Fork x1
  • Suet Ball Feeder x1
  • Jelly Cup x1
  • Screw Assembly x1
Made for your Wyze Window Bird Cam.
Integrates with the Wyze Window Bird Cam seed tray for a more flexible feeding station.
Window Bird Cam without the perch on the left, and with the perch and included feeding accessories on the right.
Window Bird CamWith the perch
A cardinal feeds from an apple while resting on the green perch.
More places to perch.
Provides a sturdy, comfortable perch for birds to rest and feed right outside your window.
A bluebird eats fruit beside the suet cage and jelly cup on the perch.
More ways
to feed.
Customize your setup by adding fruit, suet, and jelly to attract a wider variety of bird species.
The perch screw assembly attached to the Window Bird Cam feeder.
Easy Installation
Lock the perch to the seed tray with just two screws, slide in the feeding attachments, and you're ready for guests.
Questions about the perch?
How does the perch attach?
The perch and accessories attach using the included screw assembly. They screw into the standard M5 threaded mount points on the Wyze Window Bird Cam seed tray, so you can securely add the perch, fruit fork, suet ball feeder, or jelly cup without rattling or loosening.
What food can I use with the accessories?
Use the fruit fork for fresh fruit slices, such as oranges or apples, and the suet ball feeder for suet balls. The jelly cup can hold water, nectar, or sweet jelly to offer different feeding options.
Will it work with other bird feeders?
It is designed specifically for the Wyze Window Bird Cam feeder setup.
Is the perch included with Window Bird Cam?
No. Wyze Window Bird Cam Perch is a separate accessory bundle.
What does it add to the standard feeder?
It adds a place for birds to land and more ways to offer fruit, suet, and jelly—making your window-side feeding station more customizable for a wider variety of visitors.
Where will the perch be available?
The perch is planned for Wyze.com and Amazon.
Window Bird Cam beside a phone showing a live hummingbird visit.
New to Window Bird Cam?
Meet the camera
behind the close-ups.
Build your window-side bird-feeding setup around Wyze Window Bird Cam. Add the perch for more places to land, more ways to feed, and more visitors to watch up close in the Wyze app.
FREE shipping on orders $0+
