1 of 5
(Refurbished) Wyze Sense Climate Sensor
Temperature & Humidity Sensor
Size
$29.98 $44.98
12-month extended warranty
Get a 12-month extended warranty when you buy refurbished products on wyze.com. Also get special bundles, unique promos, + rewards with each order
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
Wyze Climate Sensor is designed to be used with Wyze Sense v2 from Wyze Home Monitoring.
Place Wyze Climate Sensor in any room to track temperature and humidity throughout the spaces in your home with the Wyze app. With a 500 ft range, easily position it in distant rooms, basements, or attics. It's unobtrusive with a sleek, white design to blend into any environment. Set it on any surface or use the peel-and-stick adhesive backing for walls.
Wyze Climate Sensor Details
  • Color: White
  • Finish: Matte
  • Dimensions (HxWxD): 1.4in x 1.4in x 0.5in
  • Battery: CR2032 Battery
  • Battery Life: 1.5 years based on normal usage
Additional Details
  • Mounting Method: Adhesive Back, Optional Screws
  • Communication Method: 915MHz RF
  • Range: 500 ft
  • Weather Resistance: Indoor-Use Only
  • Operation Temperature: 32°F—104°F (0°C—40°C)
  • Operation Humidity: ≤ 85% at 86°F (30°C)
  • Requires Wyze Sense Hub to work
  • Wyze Climate Sensor x3
  • CR2032 Battery x3
  • Quick Start Guide x1
No, these sensors are not standalone products and must be paired with a Wyze Sense Hub to function. Need a Wyze Sense Hub? Check out the Wyze Home Monitoring Core Starter Kit.
No, but the leak and climate sensors will not work without the Wyze Sense Hub (available with a subscription to Wyze Home Monitoring). If you have a hub but no active subscription, you will still be able to use your leak and climate sensors.
No, these sensors are incompatible with Wyze Sense v1. They must be paired with a Wyze Sense Hub, found in the Wyze Home Monitoring Core Starter Kit.
The range is up to 500 feet in ideal conditions. Please keep in mind that walls and other interference between the sensors and hub may decrease this range.
Yes, but the accuracy of the sensors will be decreased and it is not recommended.
No, these sensors are for indoor-use only.
No, not right now. In the future, Wyze Thermostat will be able to run your HVAC system based on temperature data collected by the sensor. That feature is in development.
You'll be able to set notifications for temperatures between 32-104º F (0-40º C) and humidity from 0% to 85%.
The climate sensors take CR2032 batteries.
