1 of 18
(Refurbished) Wyze Battery Video Doorbell
Effortless, battery-powered porch protection.
Style
$39.98 $65.98
Use a 5-digit ZIP code.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Head to Toe View
Six Month Battery Life
Install graphic
Easy Install
Place it anywhere
1080p HD logo
1536x1536 HD+
Video Resolution
12-month extended warranty
Get a 12-month extended warranty when you buy refurbished products on wyze.com. Also get special bundles, unique promos, + rewards with each order
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
  •  Head-to-Toe Viewing
  • 1536 x 1536 HD+ Resolution
  • Wire-Free or Wired
  • Up to 6-Month Battery Life
  • AI-Powered Person & Package Detection
  • Easy Install in Minutes
  • A black background with a white logo.
    Head-To-Toe View Angle
    Wide 150° x 150° view angle sees visitors and packages tucked right against your door.
    1536 x 1536 HD+ Video Resolution
    Records and streams crystal clear video with a 1:1 aspect ratio.
    Get up to 6 months of battery life, or hardwire for continuous power.​
  • A black background with a white logo and text.
    Place it anywhere (mounting hardware included). A corner plate is also included for optimal viewing angles.
Wyze Battery Video Doorbell Specs
Colors & Materials
  • Model: MR_BVD
  • Finish: Gloss
  • Color: Black
Dimensions
  • 5.71 in x 1.85 in x 1.14 in (145 mm x 47 mm x 29 mm)
Weight
  • 7.58 oz (215 g)
Camera and Microphone
  • Field of View: 150° x 150°
  • Resolution: 1536 x 1536
  • IR Lights: 850nm
  • Siren: 90dB
Power
  • Power Source: Rechargeable 6400 mAH battery or 5V/2A DC/12-24V, 50/60HZ AC Wired
  • Battery Life: Up to 6 months with normal use
  • Charging Port: USB-C port (USB-C cable included)
Local Storage
  • MicroSD Card: Up to 256 GB
Weather & Operating Temps
  • Weather Resistance: IP65
Operating Temperature
  • -4°F - 122°F (-20°C - 50°C)
Storage Temperature
  • -4°F - 140°F (-20°C - 60°C)
Certifications
  • FCC, IC, UL, DOE, CEC, NRcan, CA65, TSCA
Connectivity & Compatibility
  • Communication Method: Bluetooth® 5.0, 2.4 GHz Wi-Fi, Wi-Fi 6
  • Compatibility: Wyze app 3.7+, Android 10.0+ or iOS 16.0+
Warranty
  • 1-Year
  • 1x Wyze Battery Video Doorbell
  • 1x Corner Back Plate
  • 1x Flat Back Plate
  • 3x Wire Nuts
  • 1x Jump Wire
  • 3x Long Screws
  • 1x USB-C Charging Cable
  • 2x Extension Wires
  • 3x Expansion Tubes
  • 1x Doorbell Detaching Pin
  • 3x Quick Start Guide
Mounting the doorbell on a wooden door frame with the included mounting kit should take under 1 minute.
No technician is required for installation, even if you choose the hardwired option to use your existing doorbell wiring.
Anywhere near your front door is a great choice since no wires are needed when you go fully wire-free. We recommend mounting your doorbell 4 feet up from the ground for the best motion detection and usability.
Yes, our wire-free doorbell is powered by a built-in battery pack. The battery life is 3-6 months with normal use.
Yes, and you can receive notifications whenever motion is detected (using the body heat infrared sensor and edge algorithm.). With a subscription to Cam Plus, you’ll be able to configure alerts to detect people, pets, packages, and more.
Yes, and you’ll receive a up to 30-day free trial of Cam Plus after activating your doorbell. With an annual or monthly subscription to Cam Plus, Wyze Battery Video Doorbell will have the latest AI features, including Person Detection, Package Detection, Vehicle Detection and Pet Detection. Also, Cam Plus enables the doorbell to record full-length event videos.
Yes, compatible wiring will allow the doorbell to charge while it’s mounted. Having constant external power will allow your doorbell to record an additional 3-6 seconds of pre-roll video before an event, allowing you to get more context for a video clip.
Yes, the doorbell is compatible with Wyze Wi-Fi Chime (not included). Or you can use the Wyze chime controller(not included) to hard wire with your house mechanical chime.
Yes, Wyze Battery Video Doorbell is IP65-rated as weather resistant for outdoor installation. This means that it is "dust-tight" and protected against water sprays from any angle.
Yes, you can adjust the volume or change ringtone in the Wyze app, in your Chime settings.
A battery-powered doorbell built to see the full picture.
Experience effortless front porch protection, no matter where you live. Easily install it wired or wire-free and view it all from anywhere in crystal-clear HD+ resolution.
Wyze Battery Video Doorbell Shopify 01
Wyze Battery Video Doorbell + Palm Lock - Head-to-Toe Viewing 1536 x 1536 HD+ Resolution Wire-Free or Wired Up to 6-Month.
A man is walking down a sidewalk with a frisbee.
Wide head-to-toe view angle.
See more of what matters. With a 150° horizontal and 150° vertical field of view, Wyze Doorbell captures everything from a visitor’s smile to a package tucked against your door.
Keep an eye on kids coming home from school, delivery drop-offs, or unexpected guests, all without blind spots. Even if someone stands close to the camera, you’ll still see the full picture — from head to toe, porch to street.
A person is holding a Wyze Battery Video Doorbell.
Wire-free or wired.
Go up to 6 months on a single charge, or hook it up to your existing doorbell wiring for nonstop power. Recharging is easy, just plug into the USB-C port on the back.
A black device with a blue light on it.
Flexible chime options.
Never miss a ring. Connect to your home’s existing chime, or pair with a Wyze Universal Wi-Fi Chime (sold separately) to hear alerts anywhere in your home, even through your Wyze Cams.
Pick from 20 chime sounds and 8 volume levels to match your style (or have a little fun and set it to a dog bark to surprise uninvited guests).
Easy to install for homes and apartments.
Mount anywhere with the included hardware and corner plate for the perfect view. Ideal for renters or homeowners who want simple, secure installation without hassle.
A person is opening a door lock.
A person holding a box with a Wyze Battery Video Doorbell.
When motion is detected, Wyze Battery Video Doorbell can automatically play a “You are currently being recorded” message, letting visitors know they’re on camera.
That simple phrase can make a big difference. Studies have shown that visible or audible signs of surveillance reduce break-ins by up to 60%, and most burglars admit they’ll avoid homes with cameras or alarms altogether.
A Battery Video Doorbell with a Palm Lock.
With two-way audio, you can greet guests, give delivery instructions, or let friends know you’ll be right there, all through the Wyze app.
In a rush? Use Quick Responses to instantly play preset messages like “Please leave the package at the door” or “Be there shortly.” Perfect for when your hands are full, your baby’s napping, or you just don’t feel like yelling through the door.
Battery Video Doorbell with Palm Lock, providing a secure front porch without a cord in sight.
IP65 weather resistance.
No need to worry about water damage, foggy lenses, or failed recordings of those cheaper doorbells. Get reliable protection and peace of mind, no matter what the forecast says.
A Wyze Battery Video Doorbell is shown on a white wall.
Unlock from anywhere.
Pair with Wyze Lock and Wyze Palm Lock.
See who’s at the door and let them in, all from the same screen. When paired with Wyze Palm Lock, you can unlock your door remotely right from the Wyze app or your doorbell’s live view.
*Not compatible with Wyze Lock Bolt.
Shop now
A man is standing outside a door, holding a video doorbell.
A man is holding a box in front of a door.
A Battery Video Doorbell with a Palm Lock, designed to secure your front porch without a cord in sight.
Wyze Battery Video Doorbell + Palm Lock - 1536 x 1536 HD+ Resolution, Wire-Free or Wired.
More to love
Don’t miss a thing with local recording (continuous wired power required) with a microSD card up to 256GB (sold separately).
Watch and learn. Customize your doorbell.
Watch our unboxing below. Learn how to pair your doorbell, customize notifications, add a Chime, and more.
Compare Doorbells
Compare Doorbells
Wyze Video Doorbell Pro: A battery-powered HD smart doorbell with 30 second install.
from $99.98 $173.98
Resolution
1563 x 1563 (HD+)
Front: 2048 x 1536 (2K) / Bottom: 1920 x 1080
1440 x 1440
2048 x 1536 (2K)
Field-of-View
H: 150°, V: 150°
Front H: 132°, V: 100° / Bottom H: 121°, V: 60°
H: 150°, V: 150°
H: 135°, V: 103°
Chime
Existing + Auxiliary
Existing
Auxiliary
Existing
Power Option
Battery + Wired
Battery + Wired
Battery + Wired
Wired Only
3P Integration
Amazon Alexa, Google Home
Storage
Local & Cloud
Local & Cloud
Cloud Only
Local & Cloud
View
View
View
View
