1 of 6
Pan v3 + Lamp Socket v2 Bundle
Make your exterior lighting smart while powering a Pan v3.
$58.96 $61.96
Use a 5-digit ZIP code.
Make your exterior lighting even smarter with this power duo. With our latest lamp socket, you can now power Pan v3 without the need for an outlet.
  • A black camera with a white lens.
    Conveniently Power Wyze Cams
    No creative extension cord weaving required. Compatible with Cam v3/v3 Pro/Cam v4/OG/Pan v3/Pan v4.
    Motion-Activated Lights
    Converts standard bulbs into motion-activated security lights.
    Linkability, without limits
    Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting.
    Dusk to Dawn Scheduling
    Automatically turn your lights on at sunset and off at sunrise.
Wyze Lamp Socket v2 Specs
  • Color: White
  • Materials: Polycarbonate, Plastic
  • Dimensions: 56.5mm x 56.5mm x 65mm
  • Weight: 80 g
  • Socket Connector Type: E26
Power
  • Lamp Socket Input/Output 120V~, 60Hz
  • Max Lamp Power 20W
Compatibility
  • Phone: Android 7.0+, iOS 12.0+
  • Camera: Wyze Cam v3/v3 Pro/v4, Cam OG, and Cam Pan v3.
Connectivity
  • 802.11 b/g/n, 2.4GHz, Bluetooth
Operating temperature
  • -4°F ~ 120°F (-20°C, ~ 50°C)
Weather Resistance
  • Not weatherproof or waterproof. Suitable for damp locations.
Certifications
  • FCC, IC UL496, CA65, TSCA, RoHS
Languages
  • English
Warranty
  • 1-Year
Wyze Cam Pan v3
Note: Due to thermal limitations, incandescent bulbs cannot by used with this lamp socket. We recommend using a CFL or LED bulb under 20W, like Wyze Bulb White.
Pan v3
  • 1x Wyze Cam Pan v3
  • 1x 6' micro USB Cable
  • 1x Power Adapter
  • 1x Mounting Kit (Please note: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Learn more here.)
  • 1x Quick Start Guide
Lamp Socket v3
  • 1x Lamp Socket v2 unit
  • 1x Sticker
Flexible power for your Wyze Cams, now including Pan v4.
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3/v3 Pro/v4, Wyze Cam OG, Wyze Cam Pan v3, and Wyze Cam Pan v4. No long, ugly wires. No hassle.
A white light bulb with a camera attached to it.
A person holding a light bulb in their hand.
Upgrade to smart lighting in seconds.
Wyze Lamp Socket v2 and compatible Wyze Cams work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! Control your lights from anywhere in the Wyze app.
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever your compatible Wyze Cam detects motion. Now your old light fixture is a cutting-edge model of sleek security sophistication!
A smart home security camera and light bulb in a fixture on a wall.
Easily link multiple sockets for greater coverage and control.
Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting. Then schedule and control your smart setup from anywhere using the Wyze app.
A Wyze Lamp Socket v2 is hanging on the side of a garage.
Dusk to Dawn automation.
A tiny light bulb in a black and white frame.
As easy as screwing in a lightbulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket v2 falls in the latter category.
This video is for our Lamp Socket v1, but the installation process is still just as easy.
Support Articles
Before you begin setup:
  2. Connect your device to a 2.4 GHz Wi-Fi network and enable Bluetooth.
  3. Unpack your Wyze Lamp Socket v2, removing all plastic and packing materials.
  5. Wyze Lamp Socket v2 does not link with Wyze Lamp Socket v1. See Additional Notes.
To set up Wyze Lamp Socket v2 + power existing Wyze Cam
You have a compatible Wyze Cam already set up. Follow these steps to power your camera via the lamp socket, then set up and pair the lamp socket.
  3. Tap Cameras > Others > Wyze Cam Lamp Socket v2.
  4. Tap Next.
  5. Shut off power to the lamp socket at your light switch or circuit breaker, then tap Next in the app.If you're not sure how to do this, tap Show me how.
  6. Unscrew your bulb from the socket, then tap Next.
  7. If already plugged into power, unplug your camera from its current power source. Tap Next.
  8. Plug the USB end from your Wyze Cam into the USB port on your Wyze Lamp Socket. Tap Next.
  9. Install your lamp socket by screwing it in, then tap Next in the app.
  10. Tap Yes, Power a Wyze Cam.Wyze Lamp Socket v2 works with Wyze Cam v3, v3 Pro, v4, OG, Wyze Duo Cam Pan, and Wyze Cam Pan v3/v4.
  11. Tap Yes, the Camera is Set Up.
  12. Success! Your lamps socket and camera have been installed.
  13. If you want to install another lamp socket, tap Yes, Install Another.Repeat the steps to install another Wyze Lamp Socket v2.
  14. If you're done, tap No, Finish Installation.
  15. Turn power to the lamp socket on at the switch or circuit breaker. Tap Next.
  16. Now it's time to pair your lamp socket to its Wyze Cam vie Bluetooth. Tap Next.
  17. Select your compatible Wyze Cam from the list, then tap Next.
  18. Your lamp socket is now connected to your Wyze Cam. Tap No, Finish.
To set up Wyze Lamp Socket v2 to an existing Wyze Cam
You have a compatible Wyze Cam already set up. Follow these steps to set up and pair the lamp socket, without powering a Wyze Cam.
  3. Tap Others > Wyze Cam Lamp Socket.
  4. Tap Next.
  7. Install your lamp socket by screwing it in, then tap Next in the app.
  8. Tap No, Skip and Continue.Wyze Lamp Socket v2 works with Wyze Cam v3, v3 Pro, v4, OG, Wyze Duo Cam Pan and Wyze Cam Pan v3/v4.
  9. Tap Yes, the Camera is Set Up.
  10. Success! Your lamps socket and camera have been installed.
  11. If you want to install another lamp socket, tap Yes, Install Another.Repeat the steps to install another Wyze Lamp Socket v2.
  12. If you're done, tap No, Finish Installation.
  13. Turn power to the lamp socket on at the switch or circuit breaker. Tap Next.
  14. Now it's time to pair your lamp socket to its Wyze Cam vie Bluetooth. Tap Next.
  15. Select your compatible Wyze Cam from the list, then tap Next.
  16. Your lamp socket is now paired to your Wyze Cam. Tap No, Finish.
Additional Notes:
  • Wyze Lamp Socket v2 is only compatible with Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam OG, Wyze Duo Cam Pan, and Wyze Cam Pan v3/v4.
  • Wyze Lamp Socket v2 can technically work with Wyze Lamp Socket v1, but only connected to the same the same compatible Wyze Cam v3 or Wyze Cam v4. They cannot be linked to each other, but they can both be paired to and controlled by the same Wyze Cam v3 or Wyze Cam v4.
Download the Quick Start Guide for Wyze Lamp Socket v2 in this article.
Below is the Quick Start Guide for Wyze Lamp Socket v2, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Lamp Socket v2, including:
  • What's in the box for Wyze Lamp Socket with a Wyze Cam.
  • A diagram of Wyze Cam v3 and Wyze Lamp Socket v2.
  • How to set up Wyze Lamp Socket with a Wyze Cam.
  • How to install Wyze Lamp Socket with a Wyze Cam.
  • How to read the status lights on the lamp socket.
Problem
You are unable to get Wyze Lamp Socket v2 to set up and/or connect to Wi-Fi.
Troubleshooting
  1. Confirm that the Wyze app is up to date.In your Wyze app, navigate to the Account tab > tap About.Your current app version will be listed beneath the Wyze logo.Compare your app version to the latest app version listed on our Release Notes & Firmware page.If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Check that the firmware for the attached Wyze Cam is up to date.You can check this by going to the Account tab > Firmware Update.If there is an update available for the camera, please move forward with updating it.
  3. Ensure that BluetoothⓇ is enabled for the Wyze app in your phone/tablet settings.Toggle BluetoothⓇ off/on.
  4. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.Make sure that it is set to Always or While Using the App.For iOS users, make sure that Precise Location is turned on.
  5. Check the status light on the lamp socket to make sure that it is flashing red before beginning the setup process.If there is no status light, refer to My Wyze Lamp Socket v2 is not turning on.If the status light is something other than flashing red, factory reset Wyze Lamp Socket v2 and begin again.
  6. Make sure that you have properly completed the steps listed in our Wyze Lamp Socket v2 Setup Guide.
  7. Verify that you’re trying to connect the attached camera to a 2.4 GHz Wi-Fi network.Wyze Lamp Socket v2 is not compatible with 5 GHz Wi-Fi networks.
  8. Check that you have at least one compatible Wyze Cam that is set up and functional under your Wyze account.Wyze Lamp Socket v2 cannot be paired with shared devices.
  9. If stuck at the “adding device” page: Manually change the phone/tablet’s time zone to a US city time zone. Note: Be sure the city is in the same time zone as you are! Continue with the setup process, then change the time zone back to the correct one.
  10. Try moving the device to a different socket, closer to the Wi-Fi router.
  11. Reboot the Wi-Fi router.
  12. Power cycle Wyze Lamp Socket v2.Manually turn off the socket via the light switch for 10 seconds, then turn it back on.Note: This will power cycle both Wyze Lamp Socket v2 and any attached Wyze Cam.
  13. Factory reset Wyze Lamp Socket v2.Turn the light switch associated with the lamp socket off and on quickly 3 times.Wait for the status to start flashing red, then set up Wyze Lamp Socket v2 as new.
