Skip to content
1 of 23
Entry Point Security Kit Pro
Pro-Level Access Control and Entryway Monitoring
What's in this bundle
Want continuous local recording?
SALE
$299 $355SAVE 15%
Protect every major entry to your home with the Entry Point Security Kit Pro. This powerful four-device bundle combines advanced access control, dual-lens doorway monitoring, and high-resolution video coverage for a smarter, more secure home.
Wyze Palm Lock gives you fast, touchless palm-scan entry with adaptive recognition and built-in security features like anti-spoofing and auto-lock.
Wyze Duo Cam Battery Doorbell provides two camera views at once—wide and zoomed—so you can clearly see visitors, deliveries, and motion activity with flexible, wire-free installation.
Wyze Bulb Cam adds discreet overhead monitoring with 2K video and smart ambient lighting, fitting seamlessly into any standard light socket.
Wyze Cam v4 completes the system with 2.5K QHD video, Color Night Vision, Wi-Fi 6 reliability, and a spotlight for clear visibility day or night.
Together, these devices deliver pro-level entryway awareness, smarter access, and reliable protection where it matters most.
  • Wyze Palm Lock WPLCK1 - Wyze Labs, Inc.
    Wyze Palm Lock
    Wyze Palm Lock offers fast, touchless entry using secure palm recognition, with backup keypad access, auto-lock options, and detailed activity logs—delivering convenient, key-free security for your front door.
  • Wyze Duo Cam Battery Doorbell - Wyze Labs, Inc.
    Wyze Duo Cam Battery Doorbell delivers dual-lens coverage with a wide view and a zoomed-in close-up, plus wire-free installation, crisp video, motion alerts, and two-way audio for smarter front-door awareness.
  • Wyze Bulb Cam PO - WYZEC - BC - Wyze Labs, Inc.
    Wyze Bulb Cam
    Wyze Bulb Cam seamlessly combines a smart bulb with a hidden 2K security camera, offering discreet overhead monitoring, color night vision, and flexible lighting control—all powered from a standard light socket.
  • Wyze Cam v4
    Wyze Cam v4
    Wyze Cam v4 delivers sharp 2.5K QHD video, Color Night Vision, Wi-Fi 6 reliability, and a built-in spotlight—providing clear, dependable indoor or outdoor monitoring any time of day.
The key is the palm of your hand.
Highly secure, contactless biometric tech identifies you based on the unique pattern of veins beneath the surface of your palm. Just hover your palm near the reader, and voilà, the door unlocks. It’s like a secret handshake with your front door.
Unlocks for all types of hands.
Young, weathered, wet, or dirty, palm vein recognition is more accurate than fingerprints because it looks beneath the skin, so surface conditions don’t get in the way.
Peace of mind with auto lock.
A built-in gyroscope detects the angle and movement of the door in real time. Once it senses the door has closed then it automatically locks, preventing false or jammed locks.
Effortless, battery-powered, dual cam porch protection.
Two Cameras. Two Views. Double the Porch Protection.
Some is good. More is better. And Wyze Duo Cam Doorbell with TWO cameras and full porch coverage is the punch that'll send porch pirates packing!
Duo Cam Doorbell + Extra Battery SVB - DB - DUO - BL - WBAT2 - Wyze Labs, Inc.
2K Video Resolution with Color Night Vision
Capture all porch arrivals and departures in greater detail. Our award-winning starlight sensor amplifies low light for vivid color images even at night.
Wyze Bulb Cam
2K Camera Built into a Smart Bulb
Wide 160° View Sees More Space
Installation as easy as...
Brilliant setups
Versatile Wyze Camera Socket shown in three lighting setups.
Wyze Cam v4
2.5K Camera with Night Vision & Spotlight
ip65 weather resistance
Place it anywhere.
Enhanced two-way talk
Clearer conversation.
Integrated Spotlight + Siren
More safety at night.
Record every second
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
