1 of 23
Entry Point Security Kit Pro
Pro-Level Access Control and Entryway Monitoring
Best Value
The Most for Your Money
Add ons
    $299 $355
    Use a 5-digit ZIP code.
    CNV at 2.5K
    2.5K QHD Color Night Vision
    Two Way Audio device.
    2 Way Audio
    Spotlight Siren logo.
    Integrated Spotlight & Siren
    App logo
    Watch Live in the
    Wyze App
    Protect every major entry to your home with the Entry Point Security Kit Pro. This powerful four-device bundle combines advanced access control, dual-lens doorway monitoring, and high-resolution video coverage for a smarter, more secure home.
    Wyze Palm Lock gives you fast, touchless palm-scan entry with adaptive recognition and built-in security features like anti-spoofing and auto-lock.
    Wyze Duo Cam Battery Doorbell provides two camera views at once—wide and zoomed—so you can clearly see visitors, deliveries, and motion activity with flexible, wire-free installation.
    Wyze Bulb Cam adds discreet overhead monitoring with 2K video and smart ambient lighting, fitting seamlessly into any standard light socket.
    Wyze Cam v4 completes the system with 2.5K QHD video, Color Night Vision, Wi-Fi 6 reliability, and a spotlight for clear visibility day or night.
    Together, these devices deliver pro-level entryway awareness, smarter access, and reliable protection where it matters most.
    • The Entry Point Security Kit Pro includes a keypad, a doorbell, a motion sensor, and a camera.
      Wyze Palm Lock
      Wyze Palm Lock offers fast, touchless entry using secure palm recognition, with backup keypad access, auto-lock options, and detailed activity logs—delivering convenient, key-free security for your front door.
    • A black and blue security device.
      Wyze Duo Cam Battery Doorbell delivers dual-lens coverage with a wide view and a zoomed-in close-up, plus wire-free installation, crisp video, motion alerts, and two-way audio for smarter front-door awareness.
    • Wyze Bulb Cam: A smart LED light bulb with a built-in security camera that provides 24/7 protection.
      Wyze Bulb Cam
      Wyze Bulb Cam seamlessly combines a smart bulb with a hidden 2K security camera, offering discreet overhead monitoring, color night vision, and flexible lighting control—all powered from a standard light socket.
    • Wyze Cam v4
      Wyze Cam v4 delivers sharp 2.5K QHD video, Color Night Vision, Wi-Fi 6 reliability, and a built-in spotlight—providing clear, dependable indoor or outdoor monitoring any time of day.
    The key is the palm of your hand.
    Highly secure, contactless biometric tech identifies you based on the unique pattern of veins beneath the surface of your palm. Just hover your palm near the reader, and voilà, the door unlocks. It’s like a secret handshake with your front door.
    Unlocks for all types of hands.
    Young, weathered, wet, or dirty, palm vein recognition is more accurate than fingerprints because it looks beneath the skin, so surface conditions don’t get in the way.
    A boy is holding up his hand with a thumbs up.
    A man holding up a sign that says "5".
    Peace of mind with auto lock.
    A built-in gyroscope detects the angle and movement of the door in real time. Once it senses the door has closed then it automatically locks, preventing false or jammed locks.
    A smart lock that can be controlled via a smartphone app.
    Effortless, battery-powered, dual cam porch protection.
    Two Cameras. Two Views. Double the Porch Protection.
    Some is good. More is better. And Wyze Duo Cam Doorbell with TWO cameras and full porch coverage is the punch that'll send porch pirates packing!
    Wyze Duo Cam Doorbell with Dual Cameras for 24/7 Monitoring.
    2K Video Resolution with Color Night Vision
    Capture all porch arrivals and departures in greater detail. Our award-winning starlight sensor amplifies low light for vivid color images even at night.
    Wyze Bulb Cam
    2K Camera Built into a Smart Bulb
    Wide 160° View Sees More Space
    A person riding a skateboard in a driveway.
    Installation as easy as...
    Brilliant setups
    Wyze Bulb Cam Shopify
    Wyze Cam v4
    2.5K Camera with Night Vision & Spotlight
    Wyze Cam v4 Main 06.
    ip65 weather resistance
    Place it anywhere.
    Enhanced two-way talk
    Clearer conversation.
    Integrated Spotlight + Siren
    More safety at night.
    A Wyze Cam v4 microSD card.
    Record every second
    Record 24/7 locally with a microSD card up to 256 GB (sold separately). Add AI alerts and cloud backup with Cam Plus.
    FREE shipping on orders $0+
