Ir directamente al contenido
1 de 6
(Refurbished) Wyze Plug
Smart In‑Wall Outlet
$21.98 $29.98
Agotado
Wyze Refurbished logo
This is a Wyze refurbished product. What does that mean? It's a like new Wyze product, fully tested and guaranteed to work — now at an even better price. Final sale, but a wyze decision.
Start living in the future. Make your normal ol' devices smart!
Ver todos los detalles
Control from anywhere.
Wyze Plug gives you a simple way to turn on/off any outlet remotely. Easily control, lamps, fans, and other devices from the palm of your hand. No hub required.
Espresso machine connected to a Wyze Plug that is plugged into an outlet
Desk fan attached to a Wyze Plug that is plugged into wall outlet
Keep the lights off when you're at work
Save energy with scheduling.
It's time to the hassle out energy savings.
Create schedules for your devices to turn on/off automatically at certain times of day or when you leave the house.
Plug settings in wyze app
Control with a powerful free Wyze app
Quick controls in the Wyze app.
Check to see if you left your Wyze Plug on and tap to turn it off remotely, right from the Wyze app.
Easily view daily and weekly run times and group multiple plugs together, controlling them all with one tap.
Air purifier plugged into Wyze plug
Use voice commands
Works with Alexa and Google.
Got your hands full? Command your devices using just your voice with Amazon Alexa and Google Assistant.
Outside picture of a house with a few windows lit by indoor lighting
Make it look like you're home
Vacation Mode.
When enabled, Wyze Plug can turn your stuff on and off at random making it look like you're home, so people think twice about coming over uninvited.
An ecosystem that works together.
Your individual Wyze devices are awesome. As a team, the possibilities are endless. A light switch that unlocks the door. A lock that flips on the lights and cranks the AC. All of our smart devices can talk, what they say is up to you.
Image wall room with Wyze Cam v3, Wyze Thermostat, Wyze Switch, Wyze Video Doorbell, Wyze Floodlight and Wyze Lock
Image wall room with Wyze switch, Wyze Video Doorbell, Wyze Floodlight and Wyze Lock
ß
