1 of 9
Wyze Scale X
Wyze Scale X
Bluetooth Smart Scale with Extended Battery
Scale X Butterfly style HSA/FSA eligibility coming soon.
Most 5 Star Reviews
Highly Rated Online
Color
Style
$32.98 $38.98
Use a 5-digit ZIP code.
A black background with a white icon.
Syncs with Popular Health Apps
App logo
Watch Live in the
Wyze App
A black background with no visible text or objects.
13 Essential Body
Composition Metrics
Wyze Scale X measure 13 body composition metrics and share the scale with up to 8 users. Use baby, pet, luggage, and pregnancy mode to go beyond yourself. Wyze Scale X has a premium design with full-surface glass sensors and up to 22 months of battery life. Oh, and it syncs with popular fitness apps so you can keep all your metrics where YOU want them.
  • A streamlined heart rate monitor icon.
    13 Body Composition Measurements
  • A black background with no visible content.
    Baby, Pet, Luggage, Pregnancy Modes
  • Charging battery icon.
    Up to 22 Months of Battery Life
  • A square heart icon with the number 48 in the corner.
Wyze Scale X Specs
Color & Materials
  • Color: Black or White
  • Weight sensors: 4 independent leg sensors
  • Surface: ITO coated glass
Weight
  • 3.96 lbs (1.80 kg)
Dimensions
  • 11.8 in x 11.8 in x 1.18 in
Power
  • Battery-Powered: 4 x 1.5V AAA Batteries (included)
Measurement
  • Display Units: lb/kg
  • Weight Measurement Range: 11-400 lbs / 5-180 kg
Available Measurements
  • On Scale: Weight, Body Fat Percentage
  • In-App: Weight, Body Fat Percentage, Heart Rate, Lean Body Mass, BMI, Muscle Mass, Muscle Mass %, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage.
Weather & Temperature
  • Operating Temperature: 41°F-104°F (5°C-40°C)
  • RH Storage Temperature: -4°F-131°F (-20°C-55°C)
  • Storage Humidity: 90% RH
  • Waterproof Rating: IPX3
Connectivity & Compatibility
  • OS Compatibility: Android 7.0+ and iOS 12.0+
  • Bluetooth Version: BLE 5.0
  • Supported Fitness Apps: Apple Health / Google Health / Health Connect
Warranty
  • 1-year
  • 1x Wyze Scale X
  • 4x 1.5V AAA Batteries
  • 1x Quick Start Guide
Wyze Scale X is a smooth update to our original Wyze Scale, and includes Baby/Pet Mode, updated heart rate monitoring technology, longer battery life, and a fresh new look in black and white.
10-100 years old. Anyone can use Wyze Scale X to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access body composition features.
Wyze Scale X has a weight range of 11-400 lbs (5-180 kg).
Make sure your personal information (ex. Body Type, Athlete Mode, etc.) settings are correct. To do this, open the Wyze app and tap on your scale then Settings > Users > (your Nickname).
Yes, but if you step on the scale with socks and/or shoes on, Wyze Scale X will only be able to measure your weight. To take your other body composition measurements (ex. Body Fat %, Water %) you will need to step on the scale with both feet while barefoot.
Not wet, but damp is fine. Wet feet may affect accuracy and make the scale slippery and not safe to use. If wet, wipe down the scale and your feet before stepping on.
Yes, BIA may affect your pacemaker. The smart body analyzer in Wyze Scale X circulates a small electric current through your body to calculate your body composition measurements, like Body Fat %. Though the current is weak, it can affect your pacemaker. However, your Wyze Scale X can be used even if you wear a pacemaker or are pregnant. If you turn on the Only Measure Weight setting, the current will be disabled and the scale will not affect your pacemaker. Set the scale to only measure your weight. Unlike other smart scales, Wyze Scale X has a unique feature that lets you disable the BIA measurement entirely to only measure weight. With this option turned on, the scale will not affect your pacemaker. To enable the Pregnancy/Weight-Only Mode: Open the Wyze app and tap Wyze Scale X. Tap on the gear to open Scale Settings. Tap Users, then select your email address to open the Account Info screen. Tap the slider next to Pregnancy/Weight-Only Mode, then Yes to confirm.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale X in every bathroom, and in your home gym, too.
Home-use smart scales are designed for reference. Wyze Scale X uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available. While a good estimate, the data calculated by your Wyze Scale X may vary from those given by professional-grade medical instruments or methods.
On the back of your scale, find the UNIT button under the battery cover. Press and hold this button for 3s until the LED display shows "Clr".
No, only use the scale on a hard, flat surface like tile or hardwood flooring before use. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Consult your physician first. By default, Wyze Scale X sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy/Weight-Only Mode to only measure your weight, and disable the BIA measurement entirely.
Based on our testing, Wyze Scale X has a Bluetooth® range up to 32 feet (10 meters) when clear of physical obstacles or the other wireless devices.
Yes, open the Wyze app and connect to your scale. When you replace the batteries, the time on the scale resets. Connecting to it in the app will sync up the time.
No, as each user can only access their measurements within their own Wyze account. However, while you are not able to share your data within the Wyze app, we do support exporting your data via email. This will allow you to export your data into a spreadsheet to share with your healthcare professional, fitness coach, etc.
Yes, even if you have other family members on your Wyze account, your scale measurements will only be sent to your user profile in the app. Wyze Scale X is able to differentiate up to 8 user’s measurements as long as their weight difference is greater than 13.2 lb with the app closed, or greater than 6.6 lb with the app open.
No, the app does not have to be open. Step on the scale with the app closed, and the scale will store your data until you connect to it with your phone. Once connected via Bluetooth®, the scale will sync and upload your measurements to the app.
Yes, if you’ve taken your measurements with the Wyze app closed, the scale will store your data until you connect to it with your phone. Even if someone else steps on it and connects to it first, your measurements will not be shared and will only go to your user profile.
Two Patterns. Same Accuracy.
Choose either the modern square sensor pattern or our new Butterfly design.
  • Wyze Scale X Main 2026 01
  • A blue and black scale with the number 1360 on it.
A phone screen displaying a weight trend line.
Goal-oriented home screen.
Immediately see your goal and trend line when you open the Wyze Scale X app.
View your monthly trends, heart-rate, body fat, and muscle mass without tapping any further.
A phone screen displaying a muscle mass page in the Wyze app.
Helpful insights into each measurement.
Wyze Scale X gives detailed explanations about each measurement so you can understand more about your health and make informed decisions.
A black and white image of a scale with the text "Luxurious ITO glass electrodes give accurate measurements.
Full-glass surface electrodes.
An ITO coating of the tempered glass used on Wyze Scale X gives highly accurate body composition measurements.
Designed for every space.
Wyze Scale X comes in two neutral color options to compliment the design of wherever you decide to place it.
  • A woman is kneeling on a white marble floor, holding a black scale.
  • Man exercising in background, White scale x on floor in front of him.
Baby, Pet, Luggage, and Pregnancy Modes.
Step on the scale with your 4-legged friend, 4-wheeler travel bag, or all 4 kids and let Wyze Scale X do the math for you. Pregnancy Mode turns off all electrical currents used to measure body composition as an added safety measure.
A man holding a child on a scale in a bathroom.
A man holding a baby in a bathroom.
Motivation with the brands you love.
Wyze Scale X syncs with popular health apps so you can track everything in one place and take full control over your health journey.
  • A square with a heart in the center.
    Apple Health
  • A heart shaped logo for a company.
    Google Health
  • A blue heart with a Google Fit logo in the center.
    Health Connect
A man and a woman are standing in front of a scale.
Share with family and friends.
Share access to Wyze Scale X with up to 8 family members and friends. For privacy, each user sees only their own personal insights and measurements.
A person holding a smartphone with a Wyze app open to a scale data page.
Syncs automatically.
Don't have your phone on you? No problem.
Wyze Scale X keeps track of all your measurements locally and then automatically syncs with Bluetooth whenever you open the Wyze app.
A person is putting a scale into a drawer.
Thin and light for easy storing.
Scale X is built from premium materials making it both thin and light so you can effortlessly store it away when you're not using it.
A person holding a phone with a heart rate app open.
Measure heart rate in the Wyze app.
The Wyze app provides a quick and convenient way to measure your heart rate from anywhere. Simply follow the steps and get your heart rate anywhere in under 10 seconds.
A woman is stepping on a scale that measures her weight.
Instant step to wake.
No more annoying “tap and wait” before stepping on. Wyze Scale X immediately starts measuring as soon as you step on. See your weight and body fat percentage on the bright LED display.
Compare Scales
Compare Scales
A smart scale that measures body composition with 13 body composition metrics.
Wyze Scale Ultra BodyScan
from $95.98 $119.98
Wyze Scale Ultra measures 13 body composition metrics and displays your weight, BMI, and body fat percentage.
Wyze Scale Ultra
from $41.98 $49.98
Wyze Scale X is a Bluetooth smart scale that measures 13 body composition metrics and allows up to 8 users.
Wyze Scale X
from $32.98 $38.98
Wyze Scale S: A digital scale with a green background and the Wyze logo.
Wyze Scale S
from $19.98 $29.98
BodyScan Handle For Professional Results
# of Electrodes for More Accuracy
TFT Screen
Customizable Display
Wi-Fi Connection
Heart Rate
In App
In App
In App
In App
Trend View
On Screen/In App
On Screen/In App
In App
In App
Weight Range
11-400 lbs
11-400 lbs
11-400 lbs
11-400 lbs
Battery Life (Up To)
8 Months
9 Months
22 Months
18 Months
ITO Conductive Glass
Power Source
4 AAA Batteries
4 AAA Batteries
4 AAA Batteries
3 AAA Batteries
Automatic Bluetooth Connection
Baby/Pet/Luggage Mode
Color
Black/White
Black/White
Black/White
Black/White
Dimensions
15.43 x 13.39 x 2.13 in
11 in x 11 in x 1 in
Only Weight Mode
Athlete Mode
Weight
5.95 lb
3.96 lb
3.96 lb
3.32 lb
View
View
View
View
Support Articles
To set up your Wyze Scale X:
Before starting, place your Wyze Scale X on a hard, flat surface and enable Bluetooth on your phone.
  3. Tap Lifestyle > Wyze Scale Series > Wyze Scale X.
    Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.
  5. Add your details (Year of Birth, Height, etc.). You must be between 10 and 100 years old to see Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. Step on the scale with bare feet. Your weight will display, then your body fat percentage.
  8. You're all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
Problem
You are unable to set up your Wyze Scale X. The setup process fails in the Wyze app.
Troubleshooting
  • Confirm the Wyze app is up to date.
  • Check that location permissions are enabled for the Wyze app.
  • Force close the Wyze app.
  • Make sure BluetoothⓇ permissions are turned on and are enabled for the Wyze app. Toggle Bluetooth off, then back on.
  • Power cycle the scale by removing and reinstalling the batteries.
  • Power cycle your phone by turning it off, then turning it back on.
  • Factory reset the scale. Send a log from the Wyze app. On the back of the scale, find the UNIT button under the battery cover. To factory reset the scale, press and hold it for 3 seconds until the LED display shows "Clr". Set up the scale as new.
FREE shipping on orders $0+
