1 of 17
Wyze Scale Ultra BodyScan
Professional-grade precision, right at home.
Highly Recommended
By Trusted Reviewers
Color
$119.98
Use a 5-digit ZIP code.
  • Smart 8-Electrode Body Fat Scale
  • 13 Body Composition Metrics with BMI
  • 4.3" Color Display
  • Muscle Mass & Heart Rate
  • Wi-Fi/Bluetooth®
  • Baby/Pet Mode
  • Professional-Grade Precision at Home
    Built-in handle and electrodes to measure your arms, legs, and torso individually.
  • Huge Full Color Customizable Display
    Cutting-edge screen displays your health data in vivid color, no app needed.
  • 13 Essential Body Composition Metrics
    Measure your weight, body fat percentage, heart rate, BMI, and so much more.
  • Detailed Advanced Reports
    Get a detailed breakdown of your body composition, and track progress trends over time.
Wyze Scale Ultra BodyScan Specs
Color & Materials
  • Color: Black or White
  • Materials: Plastic, Silicone, ITO Coated Glass
  • Weight: 5.95 lbs / 2.7 kg
  • Dimensions: 13.39 in x 15.43 in x 2.13 in / 340 mm x 392 mm x 54 mm
Power
  • Battery-Powered: 4 x 1.5V AAA Batteries (Included)
Display
  • Display Units: lb/kg
  • 4.3" TFT (Thin-Film Transfer) LCD Screen (see more health insights on the scale)
Weight Range
  • 11 - 400 lbs / 5 - 180 kg
Available Measurements
  • Displayed On Scale: Weight, Body Fat Percentage, Lean Body Mass, BMI, Muscle Mass, Muscle Mass Percentage, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage.
  • Displayed In-App: Weight, Heart Rate, Body Fat Percentage, Lean Body Mass, BMI, Muscle Mass, Muscle Mass Percentage, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage.
Weather
  • Operating Temperature: 41°F-104°F (5°C-40°C)
  • Operating Humidity: 20 - 85% RH
  • Storage Temperature: -4°F-131°F (-20°C-55°C)
  • Storage Humidity: 90% RH
Connectivity & Compatibility
  • Connectivity: Wi-Fi and Bluetooth 5.0®
  • Phone Compatibility: Android 10.0+, iOS 16.0+
  • Supported Fitness Apps: Apple Health / Google Health / Health Connect
Warranty
  • 1 year warranty
  • Wyze Scale Ultra BodyScan x 1
  • 1.5V AAA Batteries x 4
  • Quick Start Guide x 1
No, Wi-Fi connecting to the scale is optional. Your measurements will display on the screen, even without Wi-Fi.
Both scales measure 13 body composition metrics, and connect via Bluetooth. However, With a handle and 8 electrodes across hands and feet, Wyze Scale Ultra BodyScan measures body impedance in your arms, legs, and torso individually, for results that are more accurate and personalized than standard foot-only scales. Wyze Scale Ultra BodyScan has a huge customizable 4.3-inch TFT screen on its surface. And now with a Wi-Fi connection, you can check your data from anywhere with the Wyze app.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale Ultra BodyScan in every bathroom, and in your home gym, too.
Anyone can use Wyze Scale Ultra BodyScan to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 10 and 100 years old. Children under 10 and seniors over 100 will not be able to access the body composition features. For users between 10-17, body composition data is only for reference.
Wyze Scale Ultra BodyScan has a weight range of 11-400 lbs (5-180 kg).
Yes, but it will only measure your weight. To take your other body composition measurements (ex. Body Fat %, Water %) you will need to hold the handle and step on the scale with both feet while barefoot.
No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements.
Only step on Wyze Scale Ultra BodyScan with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Yes, the Wyze app provides a quick and convenient way to measure your heart rate from anywhere in under 10 seconds.
Consult your physician first. By default, Wyze Scale Ultra BodyScan sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate. Set the scale to Pregnancy/Weight-Only Mode to only measure your weight.
Home-use smart scales are designed for reference. Wyze Scale Ultra BodyScan uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available. While a good estimate, the data calculated by your Wyze Scale Ultra BodyScan may vary from those given by professional-grade medical instruments or methods.
Open the battery compartment, then set the scale down. Tap to activate the scale, then press and hold the UNIT button above the batteries. The TFT display will show “Clear” when the scale is reset.
On the back of Wyze Scale Ultra BodyScan, locate the arrow over the battery compartment. With two thumbs, press downward on the center of the compartment cover.
We did it again. Scale Ultra leveled up with BodyScan precision.
4.3 inches of full-color data with BodyScan precision technology.
A best-in-class full-color customizable screen presents robust health data in vivid color without opening the app. Customize to view what’s most important to you.
Ultra-detailed data reporting with in-depth body segment data.
View segmental data for your arms, legs, and torso all in one easy-to-read report.
BodyScan Handle for Professional-Grade Precision
Receive deeper insights into your health with an extendable handle and 8 smart electrodes across both hands and feet. These work together to measure your arms, legs, and torso individually.
Track 13 Essential Health Metrics
Keep track of important health metrics like weight, body fat, muscle mass and more. We haven't figured out how to measure the joy you'll feel when you achieve your dream bod, but we're working on it.
Wi-Fi and Bluetooth® Connection
When connected to Wi-Fi your data automatically syncs, so your phone doesn't have to loiter around while you're on the scale.
Baby, Pet & Luggage Mode
We get it. Math is hard. Weigh your baby, pet, luggage, or your kid’s absurdly heavy backpack with smart baby/pet mode and let us do the calculations for you.
Two Colorways to Fit Any Room
Wyze Scale Ultra BodyScan comes in two color options to match whatever vibe you've got going on in your porcelain palace.
Unlimited Sharing & Smart User Recognition
Share it with the whole family. Wyze Scale Ultra BodyScan automatically recognizes and syncs data for up to 8 unique users. Take one-off measurements for an unlimited number of guests. Stay motivated by sharing data and trends with an unlimited number of people.
Works with the brands you love.
No need to ditch your existing fitness tracker. Wyze Scale Ultra BodyScan connects seamlessly to your health apps for smooth syncing and complete control over your wellness journey.
  • A red heart on a black background.
    Apple Health
  • A blue circle with a white dot in the center.
    Fitbit
  • A blue heart with a blue circle in the middle.
    Health Connect
Anti-Slip Floor Contacts
Sturdy construction and grippy silicone floor contacts enable safe and accurate measurements, every time.
ITO Coated Glass
Step anywhere on the scale. An ITO conductive glass gives highly accurate body composition measurements.
Long-Lasting Battery Life
They say nothing lasts forever. Except maybe the embarrassment you feel when the server tells you to have a nice meal, and you say, "You too!" Like, why would you say that? Anyways, enjoy up to 8 months of battery life with this scale.
Compare Scales
Compare Scales
Wyze Scale Ultra measures 13 body composition metrics and displays your weight, BMI, and body fat percentage.
Wyze Scale Ultra
from $49.98
Wyze Scale X is a Bluetooth smart scale that measures 13 body composition metrics and allows up to 8 users.
Wyze Scale X
from $38.98
Wyze Scale S - A digital scale with a green background and the Wyze logo.
Wyze Scale S
from $29.98
BodyScan Handle For Professional Results
# of Electrodes for More Accuracy
TFT Screen
Wi-Fi Connection
Heart Rate
In App
In App
In App
In App
Trend View
On Screen/In App
On Screen/In App
In App
In App
Weight Range
11-400 lbs
11-400 lbs
11-400 lbs
11-400 lbs
Battery Life (Up To)
8 Months
9 Months
22 Months
18 Months
ITO Conductive Glass
Power Source
4 AAA Batteries
4 AAA Batteries
4 AAA Batteries
3 AAA Batteries
Automatic Bluetooth Connection
Baby/Pet/Luggage Mode
Color
Black/White
Black/White
Black/White
Black/White
Dimensions
15.43 x 13.39 x 2.13 in
11.8 in x 11.8 in x 1.18 in
11 in x 11 in x 1 in
Only Weight Mode
Athlete Mode
Apple Health / Fitbit / Health Connect
Weight
5.95 lb
3.96 lb
3.96 lb
3.32 lb
View
View
View
View
Support Articles
To set up your Wyze Scale Ultra BodyScan:
Before starting, insert the batteries into your Wyze Scale Ultra BodyScan. Then place it on a hard, flat surface and enable Bluetooth on your phone.
  2. On the Add menu, tap Device.Step on the scale to activate it. Make sure your device's BluetoothⓇ is enabled. Your weight will display on your device and Wyze Scale Ultra BodyScan.
  3. Tap Lifestyle > Wyze Scale Ultra BodyScan.Your phone will search for your scale, pair with it, and connect to it.
  4. Name your device or choose a pre-selected name, then tap Save.You can add this device to your Favorites by leaving the box checked.
  5. Add your details (Year of Birth, Height, etc.).You must be between 10 and 100 years old to get Body Composition data.
  6. Tap Next. Your phone or tablet will pair with your scale again.
  7. A Setup Wi-Fi popup will appear. Tap Yes.Or tap No to skip. You can set this up later in your scale’s settings.
  8. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.Tap the icon in the password field to display the password to ensure it was entered correctly.
  9. Once Wi-Fi has successfully connected tap Ok and you’re all set!
New to Wyze? Before starting, download the Wyze app and enable Bluetooth.
Download the Quick Start Guide for Wyze Scale Ultra BodyScan in this article.
Below is the Quick Start Guide for Wyze Scale Ultra BodyScan, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Scale Ultra including:
  • What's in the box for Wyze Scale Ultra BodyScan.
  • How to set up Wyze Scale Ultra BodyScan.
  • Notes on how to use and where to place your Wyze Scale Ultra BodyScan.
  • How to read the TFT display.
  • How to replace the batteries.
