1 of 7
Wyze Scale S
Wyze Scale S
Super smart. Tracks 11 body metrics.
Color
Limited 1 per eligible Lilly Health member.
  • Tracks 11 metrics
    Monitor everything from weight, body fat %, to BMI and heart rate.
  • Multiple modes
    Access unique modes such as Pregnancy, Baby, Pet and Athlete
  • Syncs with fitness apps
    Apple Health and Google Fit
  • Huge 3.5" Display
    Easily readable when you need it
Wyze Scale S Specs
Color & Materials
  • Color: Black or White
  • Body: Strong plastic base + anti-slip silicone feet
  • Surface: Tempered glass + stainless steel electrodes
Weight
  • 3.32 lbs (1.66 kg)
Dimensions
  • 278 mm x 278 mm x 26 mm (11 in x 11 in x 1 in)
Power
  • Battery-Powered: 3 x 1.5V AAA Batteries (Pre-Installed)
Measurements
  • Display Units: lb/kg
  • Weight Measurement Range: 11-400 lbs/ 5-180 kg
Available Measurements
  • On Scale: Weight, Body Fat Percentage
  • In-App: Weight, Body Fat Percentage, Lean Body Mass, BMI, Muscle Weight, Visceral Fat, Basal Metabolic Rate, Bone Mass, Metabolic Age, Protein, Body Water Percentage
Weather & Temperature
  • Operating Temperature: 41°F - 104°F (5°C - 40°C)
  • Operating Humidity: 20 - 85% RH
  • Storage Temperature: -4°F - 131°F (-20°C - 55°C)
  • Storage Humidity: 90% RH
Connectivity & Compatibility
  • OS Compatibility: Android 7.0+ and iOS 12.0+
  • Bluetooth Version: BLE 5.0
  • Supported Fitness Apps: Apple Health, Google Fit, Fitbit
Language
  • English
Warranty
  • 1-Year
  • Wyze Scale S x1
  • 1.5V AAA Batteries x3
  • Quick Start Guide x1
  1. Scale S has added a baby/pet mode and a smart greeting mode that can say "HELLO" in the scale's LED display.
  2. The heart rate is measured by standing on the scale with bare feet for the original Scale. In Scale S, we change the way to measure the heartbeat by covering the finger on the phone's camera. Both can provide accurate results compared to other oximeters, bands, apple watches, etc.
  3. While the original Scale uses ITO glasses to measure the body resistance, Scale S has four metal electrodes to measure it. Both measurements are accurate. But the ITO covered glass design makes the original Scale looks more premium. (Lead to the price difference)
  4. Scale S offers a similarly slim, lightweight design compared to Wyze Scale. (Also, it leads to the price difference. Help us save shipping costs to lower the listed price.)
14-100 years old. Anyone can use Wyze Scale S to take their weight measurement, no matter their age. Body composition (Body Fat %, Water %, etc.) is only available for people between the ages of 14 and 100 years old. Children under 14 and seniors over 100 will not be able to access the body composition features.
Wyze Scale S has a weight range of 11-400 lbs (5-180 kg).
Check if all of the personal information i.e., Body Type, Year of Birth, Height, Athlete Mode are correct. In the Wyze app, tap on your scale device then Settings > Users > (your Nickname).
When you replace the batteries, the time on the scale will reset. Connect to your scale in the Wyze app to sync up the time.
Yes, but it will only measure your weight. If you step on the scale with socks and/or shoes on, Wyze Scale/Scale S will only be able to measure your weight. To take your other body composition measurements (ex. body fat %, water %) you will need to step on the scale with both feet while barefoot.
As many as you want! There is no limit to how many Wyze scales you can add to one Wyze account. Put a Wyze Scale S in every bathroom, and in your home gym, too.
No, only use the scale on a hard, flat surface. Carpets and rugs can affect the calibration of your scale, giving you inaccurate measurements. Place your Wyze Scale S on a hard, flat surface like tile or hardwood flooring before use.
Not wet, but damp is fine. Wet feet may affect accuracy. They also can make the scale slippery and not safe to use. Only step on Wyze Scale S with dry or slightly damp feet, and only when the surface of the glass is not wet. If wet, wipe down the scale and your feet before stepping on.
Consult your physician first. By default, Wyze Scale S sends a weak (and safe) electric current through the body for Bioelectrical Impedance Analysis (BIA). There are no known risks with using BIA while pregnant, but body composition results may not be accurate.
Set the scale to Pregnancy/Weight-Only Mode to only measure your weight. Unlike other smart scales, Wyze Scale S has a unique feature that lets you disable the BIA measurement entirely to only measure weight.
Samsung health integration is on our roadmap. Samsung has closed their website for partnership registration since Sep 2020, but we are on their waitlist to get in. Once they have re-opened the gate, we will enter.
Home-use smart scales are designed for reference. Wyze Scale S uses bioelectric impedance analysis (BIA) to estimate body composition, particularly body fat. BIA is a popular method to estimate body fat percentage, but there are many other methods available.
While a good estimate, the data calculated by your Wyze Scale S may vary from those given by professional-grade medical instruments or methods.
Tap on the surface of the scale to activate it, find the UNIT/RESET button on the back of the scale. Press and hold the button for 3 seconds. The LED display will show “CLr” when the scale is reset.
On the back of Wyze Scale S, locate the bumpy area over the battery compartment. With two thumbs, press downward on the center of the compartment cover, away from the UNIT/RESET button.
Based on Wyze’s reliability tests Bluetooth range, Scale S can maintain a steady BLE connection with the app in a range of 32 ft/ 10 m without the impact of physical obstacles or the other wireless devices.
Ultra-Precise Measurements
Industry-leading accelerometers, G-sensors, and an advanced bioelectric impedance chip all contribute to making highly accurate smart measurements with Wyze Scale S.
A white Wyze scale with a close up of the buttons.
A woman holding a white and black scale.
11 Unique Insights into Your Health
Health is measured by more than just weight. That's why Wyze Scale S also measures muscle mass, body fat, and even bone mass to give you a more complete picture of your health.
Body Metrics 11 Metrics
Huge, Bright, LED Display.
Easily readable when you need it, completely invisible when you don't. Wyze Scale S sets the bar high with a luxurious, digital LED display.
A digital scale displaying the number 1368.
Apple Health
Apple Health
Man holding a large dog while standing on a black Wyze Scale S.
A woman standing on a Wyze Scale while checking her stats on the Wyze app on her phone.
Man looking at his phone with exercise equipment in the background.
A man holding a smartphone in front of a bicycle.
More features to love.
Our body scale connects with popular fitness apps so you can track your progress where you track everything else.
Track the weight of your fur baby or tiny human over time in the Wyze app. No math required
Watch your data trends anywhere and anytime. Achieve your goals and see yourself succeed.
With up to 18 months of battery life, you'll be able to see your New's Year's resolution through to completion and kick-start another one without worrying about changing batteries.
