1 of 7
Wyze Night Light
Wyze Night Light
Illuminate the night with soft, motion-activated light.
Top Accessory
Commonly Bundled Item
Size
$24.99
⚠️ Final sale. Item not eligible for exchange or return.
Modern logo
Easy Peasy Install
48x48 grid.
Motion-Activated Lights
Link logo
Linkability Without Limits
Assign all lamp sockets to group controlled lighting
Battery-powered or Hardwired
  • Convenient Linkability
    Link up to 10 units for a directional lighting experience.
  • Battery Powered
    USB-C charging. Lasts up to 3-months.
  • Motion Detection
    Built-in motion and light sensors.
  • Easy Installation
    Peel-and-stick mounting. You're free of the power outlet!
Lumens
  • 4.5 lumens
Color Temperature
  • 2500K
Weight
  • 1.8oz (50g)
Dimension
  • 3.14” x 2.04” x 0.55” (80*52*14mm)
RF Connection
  • 2.4GHz Range: 100ft (30m)
Battery Capacity
  • 300mAH Lithium Polymer
Battery Life
  • 128 days (Solo use)
  • 85 days (Linked)
  • 11 hours for normal mode (Calculated by 10 times light per day)
Charging Method
  • USB Type-C
Operating Temperature
  • 41°F - 104°F (5-40°C)
Certifications
FCC, SGS, IC, DOE/CEC, NRCan
  • Wyze Night Light x 3
  • Wall Mount Plate x 3
  • Easy Pull Tape x 3
  • Quick Start Guide x 1
No
No, it is not a connected device.
On: The light will always be on.
Off: The light will be turned off and the paired network will be reset.
Auto: Light will automatically turn on and both the dusk-to-dawn sensor and motion sensors are on.
Group use: To pair Wyze Night Lights together, switch all devices to Auto. You can pair up to 10. In the first 30 seconds, the device enter pairing mode and blink. After 30 seconds, the night lights should be paired and blinking will stop.
Individual use: Switch the device to Auto and wait for 30 seconds to end pairing mode.
100 feet (30 meters)
110°, ~20 feet (6 meters)
6.5lux
128 days (Solo) 85 days (Linked) 11 hours for normal mode (Calculated by 10 times light per day)
USB-C
We know our customers might purchase more than one pack of Wyze Night Lights so we have decided to not include the cable and charger to reduce unnecessary waste. USB-C is becoming one of the most common charging solutions and we decided to use it to reduce the chance of our customers not already having a cable available.
1.5 – 2 Hours
Yes
No
1 Year Standard Warranty
Soft, Soothing Light
Sleek design illuminates surrounding surfaces with 2500K of indirect, warm light.
A night light is mounted on the wall next to a crib.
A set of stairs with lights on the side.
Better Together
Easily link up to 10 Wyze Night Lights to create a directional lighting experience.
A night light on the side of a bed.
Lights up only when you need it
Built-in motion and light sensors activate a soft glow.
Support Articles
Download the Quick Start Guide for Wyze Night Light in this article.
Below is the Quick Start Guide for Wyze Night Light, a short manual for how to get started.
This guide is a short user manual with the basics about Wyze Night Light including:
  • What's in the box for Wyze Night Light.
  • How to install your Wyze Night Light.
  • The modes on your Wyze Night Light.
  • How to read the status lights on your Wyze Night Light.
Want to line a hallway with night lights? Link them all together so that when one is triggered by motion or low ambient light, they all turn on.
To link multiple Wyze Night Lights together:
  1. On the side of each night light, toggle the switch to AUTO. They must be charged and light up before linking.You can link up to 10 night lights.
  2. Within ~30 seconds, all night lights will enter pairing mode and start blinking.
  3. After 30 seconds, the night lights will stop blinking. All linked!
Additional Notes:
  • Wyze Night Light 2021 version cannot be linked with Wyze Night Light 2022 or 2023 versions.
  • You can find your Wyze Night Light's version on the back of the night light.
FREE shipping on orders $0+
