1 of 9
Wyze Home Monitoring Core Starter Kit
No contracts. No hassle. Just safe.
Bundle
$111.98 $155.98
Low stock: 19 left
Use a 5-digit ZIP code.
The Security System That Makes SimpliSafe Look Expensive
Wyze Home Monitoring gives you pro‑grade protection without the pro‑grade price. No contracts. No gotchas. Just smarter gear and a bill that doesn’t sting.
A white and grey calculator with a number pad and buttons.
Wyze Home Monitoring Core Starter Kit: Keep your home safe with this smart system that includes a camera, motion sensor.
What's in the box?
  • Wyze Sense Hub with battery backup and a built‑in siren
  • Wyze Sense Keypad
  • 2× Entry Sensors
  • 1× Motion Sensor
  • 3 months of professional monitoring included
A white coffee maker with a blue lid.
Wyze Sense Hub
If someone attempts to break in, your Base Station instantly alerts our professional monitoring team and blasts an 88dB siren to scare them off.
A person is pressing a button on a wall.
Wyze Keypad
Wire-free convenience means you can put it anywhere. For maximum protection, place it by your front door.
A person is holding a white device with a black button.
Wyze Entry Sensor
We use entry sensors to watch over the front and back doors, plus the two big ground-floor windows that are easiest to reach.
A man is pointing at a white switch on the wall.
Wyze Motion Sensor
Full-room coverage from a single sensor. Ideal for a hallway or main living space. Designed to work seamlessly around pets.
  • Wyze Sense Entry Sensor v2 -- Door and Window Sensor with Long Battery Life - Detects when things open/close - Use with.
    (2x) Entry Sensor
    Place it up and forget about it. Now you'll get notified on your phone (and through our Sense Hub) when a door is opened.
  • A person is holding a motion sensor.
    Motion Sensor
    Get an idea when someone is moving around your house without accessing a single camera feed.
  • A person holding a cell phone with a picture of a house on it.
    Insights from your phone
    Add a Home Monitoring subscription for 24/7 agent monitoring, emergency dispatch, and potential homeowner's insurance discounts.
1 of 3
A smartphone app screen with a timer showing 16 seconds remaining.
Why Wyze wins
  • Pay less. Protect more. Wyze Home Monitoring is a fraction of what the big names charge for monitoring, and our equipment costs don’t require a payment plan.
  • Smarter from day one. Add ultra‑sharp Wyze Cams (2.5K/4K options), local recording, AI alerts, and automations that work with your whole home.
  • No contracts. Cancel anytime. Keep your hardware.
  • Install in minutes. Peel‑and‑stick sensors, app‑guided setup, and optional professional install if you want it.
Man looking at his phone while standing in a doorway.
Professional Monitoring
  • 24/7 professional monitoring through Noonlight: if an alarm triggers, they’ll try to reach you within ~30 seconds, and dispatch emergency services if you can’t respond.
  • A full system of sensors—door/window entry sensors, motion sensors, leak sensors, climate sensors—with a central hub that ties it all together.
  • Built-in 88 dB siren on the Wyze Sense Hub to deter intruders.
  • Environmental monitoring: leaks, temperature, humidity so you get alerts when there’s a problem beyond just break-ins.
  • Arm/disarm control via a keypad or directly from the Wyze app.
  • Custom alert-triggers: you can choose what your “security cameras” (designated cameras) respond to (motion, person, CO/smoke-alarm audio, etc.) and how notifications are delivered.
Add more to your starter bundle.
You know your home best, build the system that's right for you.
Wyze Sense Entry Sensor - Home Monitoring
$49.98
0
Wyze Sense Motion Sensor - Refurbished
$24.98
0
Wyze Sense Keypad: A remote control for home security.
Wyze Sense Keypad
$39.98
0
Wyze Sense Climate Sensor - Monitor your home's climate with these easy-to-use sensors.
$44.98
0
Wyze Sense Leak Sensor & Probe: A leak detection system that helps identify and locate water leaks in your home.
$15.98
0
Wyze Security Yard Sign: Protect your home with Wyze's video recording in progress.
$16.99
0
Total: $0.00
0 items selected
FREE shipping on orders $0+
