Skip to content
1 of 8
Wireless Headphones with 20‑Hour Battery
Color
Style
SALE
$29.99 $89.99SAVE 67%
Like a symphony playing just for you.
  • Hybrid Active Noise Cancellation
    40 dB hybrid active noise cancellation with Transparency Mode.
  • Fatigue-Free Fit
    20mm memory foam and oblong earpads for all-day comfort.
  • Voice-Isolating Microphones
    Dedicated mics isolate your voice in a room full of chatter.
  • Wireless with 20-Hour Battery Life
    Listen for up to 20 hours per charge. 10 minutes on the charger gets you 4 more hours.
Headphones Weight and Materials
  • Weight: 9.9oz
  • Headband material: Multilayer composite of stainless steel, EVA foam, and plastic, covered in protein leather
  • Earcup cover material: ABS plastic and PC with special coating for touch gestures
  • Ear cushion material: Memory foam covered in protein leather
Bluetooth Specification
  • Bluetooth range: 33 ft (10 m)
  • Bluetooth version: Bluetooth 5.0
  • Bluetooth codec: SBC, AAC
  • Multiple device connection: Supports two device connections at the same time
Speaker
  • Driver dimensions: 40 mm dome type driver (copper wire voice coil)
  • Magnet material: Neodymium
  • Diaphragm: High transient dual TPU composite diaphragm
  • Frequency response over Bluetooth: 20 - 20,000 Hz (44.1 kHz sampling rate)
  • Frequency response over line-in: 20 - 38,000 Hz
  • Sensitivity: 113 dB/mW @1 kHz
  • Total harmonic distortion: <0.5% 1 mW/1kHz
  • Impedance: 32 Ω
Battery
  • Charging method: USB Type-C
  • Battery life: Up to 20 hours of music or call with high noise cancellation
  • Charging time: Around 2 hours
  • 10-Minute quick charge: Up to 4-hour playback time
  • Charging temperature: 41 - 95 ºF (5 - 35 ℃)
  • Battery type: Lithium-ion rechargeable battery
  • Battery capacity: 1,000 mAh DC 3.7V
Microphones
6 total microphones
  • 4 microphones for active noise cancellation
  • 2 microphones for voice pickup
  • Voice microphones
  • Sensitivity: -32 dB at 1kHz
  • Directivity: Omnidirectional
  • SNR: 74
  • Frequency response: 50 - 10,000 Hz
  • Impedance: 2.2 kΩ
Control Input
  • Power/Bluetooth button
  • Single press to turn on and off
  • Press and hold to enter pairing mode
  • Noise cancellation button
  • Single press to switch between noise cancellation modes
  • Volume +/- buttons
  • Single press to adjust volume
  • Play/Pause button
  • Music playback: single press to play/pause, double-press to skip forward, triple-press to skip backward
  • Call: single press to start/end the call, press and hold to reject a call
  • Voice assistant: press and hold to activate voice assistant
  • Touchpad
  • Double-tap to activate the voice assistant, or mute and unmute in calls
  • Cover to enable Quick Conversation mode
Environment
  • Operating environment: 31 - 104ºF (0 - 40℃), humidity < 95%
  • Storage and transporting environment: -4 - 140ºF (-20 - 60℃), humidity < 95%
No Travel Case
  • Wyze Headphones x1
  • Soft Carrying Pouch x1
  • USB Type-C Cable x1
  • Audio Cable x1
  • Quick Start Guide x1
With Travel Case
  • Hard Case x1
  • Audio Cable x1
Up to 20 hours of music playback and call time.
Yes, all you need is a Bluetooth connection to use the headphones. If you want to use more advanced features, like touch controls and the equalizer, you will need the Wyze app.
Yes! Wyze Headphones are wireless and connect via Bluetooth, but can also be used with the included 3.5mm headphone jack.
Download the Wyze app, and click the plus sign + > Add Device > Wyze Headphones. Follow the setup instructions.
Yes, they include a cloth carrying pouch.
Yes, you can control the bass, mids, highs, and more using the equalizer in the Wyze app.
Hybrid active noise canceling through 2 feedback microphones and 2 feed-forward microphones, with a 40dB noise reduction depth.
Yes, you can switch between High ANC, Low ANC, and Transparency mode in the Wyze app and on the headphones.
Wyze Headphones produce stereo sound.
A DC 1000mAh lithium ion battery.
Yes, Wyze Headphones can connect to Bluetooth-capable devices like gaming consoles and computers.
See how real people react to Wyze Headphones
Person standing on train platform wearing wyze headphones
You’ll think the rest of the world is standing still.
40dB Quick On/Off Hybrid Active Noise Cancellation (ANC).
Equipped with four noise-cancelling microphones and an ultra-fast processor, outside noise is reduced to a whisper so you can stay focused while the world buzzes around you.
White Wyze Noise-Cancelling Headphones
For when you want to break the silence.
Transparency Mode
Outside sounds are amplified through your headphones with just a touch so you can listen for your coffee order while enjoying music.
Wear Detection
Audio automatically pauses when your headphones are removed and resumes when they’re put back on saving your spot in the song and battery.
Quick Conversations
Gently touching your right earcup pauses audio and enables Transparency Mode allowing you to join a conversation at a moment’s notice without taking your headphones off.
Your own private symphony.
World-class engineering and proprietary AI meets precision-tuned premium hardware. Prepare for an audio experience normally reserved for the “top shelf” brands.
Person wearing wyze headphones and dancing in front of colorful mural
Wyze headphones showing internal components
Dual TPU Composite Diaphragm Drivers.
Deep bass, stable mids, and crisp highs brought to you by dual 40mm drivers and a range of frequencies up to 38kHz transport you to the front row of your favorite concert.
In short, these headphones mean business.
Person checking wyze headphone settings in the wyze app on their phone
Customize the perfect listening experience in the Wyze app.
Create and save your own adjustments and custom preferences or choose from premade selections optimized for music, movies, gaming, and more.
Person relaxing in bed with a book while wearing wyze headphones
So comfy you'll forget you're wearing them.
Responsive memory foam and elongated earpads delicately embrace the ear for a superior, fatigue-free fit.
Wyze headphones with alexa built in tag
Intuitive touch and tap.
Use the controls located on your headphones to answer calls, adjust volume, activate your voice assistant, or pause/play/skip tracks.
Person wearing wyze headphones and laughing
Person wearing noise canceling headphones with kids in the background.
Person wearing white wyze headphones checking their phone
Dual voice-isolating microphones. Dedicated microphones isolate your voice from surrounding chatter so your voice is crystal clear on calls.
With Bluetooth 5.0 and two connected devices at once. Roam around your home or office with fully wireless headphones that can connect to two devices at once. Jump from music on your laptop to incoming calls on your phone without resetting your Bluetooth connection.
Access music, weather, and more with voice assistants
Use Amazon Alexa built-in or your device’s native voice assistant (Siri, Google Assistant, Bixby).Leave your phone in your pocket and ask Alexa or your phone’s native voice assistant to access information, set reminders, play music, and more all with your voice.
Person wearing wyze headphones and touching the side in order to ask Alexa built-in a question
