Skip to content
1 of 7
Wyze Handheld Vacuum
The perfect spot cleaning companion from car to home.
$54.99
A powerful and compact cordless vacuum with a full accessory kit for spot cleaning anywhere from your car to your home. Whether it’s spills, pet hair, or just dust bunnies - there’s an attachment for that.
Engineered for extreme portability.
Wyze Handheld Vacuum was designed to be luxuriously convenient to use for any task. At just 1.23lbs and under 3" thick, it's 50% lighter and 65% more compact than leading handheld vacuums.
Vacuum in Tesla Car
Vacuum in Tesla Car
Vacuum picking up dog food
Double the suction of other handheld vacs.
Most handheld vacuums (8kPa) can handle dust and small debris. Wyze Handheld Vacuum (16.8kPa) takes portable cleaning to a new level by pulling up even the deepest dirt, crumbs, and pet hair.
Vacuum charging with USB-C port in Tesla Model 3
USB-C charging.
Charge your vacuum where you charge all your devices with the integrated USB-C port. View your battery life in bright LEDs with up to 30 minutes of run-time.
Easy empty into trash can with a button
True HEPA allergen filtration.
To empty, just press a single button located near the nossle. Inside are the dustbin, stainless steel filter, and true HEPA filter which traps 95% of allergens. Each part is easily removable and washable.
Wyze Hand Vac sitting upright in back seat of Tesla model 3
Turbo / Eco Mode
Whether you're spot cleaning or rage cleaning, Wyze Handheld Vacuum has a mode for that. Even at its loudest setting, it's still 20% quieter than most handheld vacuums.
