1 of 4
The perfect angle for every porch layout.
Top Accessory
Commonly Bundled Item
Style
$8.99
Low stock: 37 left
Use a 5-digit ZIP code.
Free Shipping & 30-day hassle-free returns.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
The only acceptable wedge that should come between you and Doorbell v2! Perfect for angled door frames and porches with stairs, this accessory allows you to easily adjust the viewing angle for maximum coverage. Goodbye to blind spots, hello to a superior home security experience.
  • Compatible with Doorbell v2
    This wedge kit is only compatible with Doorbell v2.
  • Stackable, so it's flexible
    Use one wedge piece or use them all. Get the perfect angle for your porch.
  • Weather resistant, heavy duty plastic
    We designed this to last outside just like your Doorbell v2.
  • Quick installation
    The hardest part will be figuring out angle that makes you happy.
Color: Black
Material: Plastic
Compatible with: Doorbell v2 only
Product warranty: 1 year
  • 7.5° Vertical Bracket ×2
  • Horizontal 15° Bracket ×1
  • Short Screws x6
  • Quick Start Guide ×1
A black object with a silver edge is hanging on a wall.
Wedges for the perfect angle
Not all porches are made the same. Some have steps, while others have slanted sidings. Wedge Kit was designed to give every Doorbell v2 owner the perfect view so they don't miss a thing.
A black device attached to a wall.
Thick heavy duty plastic
We don't cut corners on our cameras, and the same is true of our accessories. We used thick, weather-resistant plastic on this kit, so you can have it last for years.
Designed to work with Wyze Doorbell v2
Crystal-clear video, color night vision, and two-way audio, plus an extra layer of security with voice deterrents.
