Wyze Cam USB Extension Cable - 20ft
Extend your reach with ease
$7.99
Use a 5-digit ZIP code.
Say goodbye to short cables and enjoy the freedom of a 20ft cable. This 20ft USB extension cable works with Wyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3/v4, Wyze Cam OG Standard, Wyze Cam OG Telephoto and Window Cam
  • 20ft Cable Length
    20ft Cable Length
  • Compatible with many Wyze Cams
  • Easy to install
    Easy to install
  • A black background with a white icon of a weather forecast.
    IP67 Weather Rating
Wyze 20ft USB Extension Cable Specs
Color & Materials
  • Color: White
Dimensions & Weight
  • Product dimension: OD Φ3.8mm
  • Product length: 6m (20ft)
  • Product weight: 205g (0.45lbs)
Power
  • Output power: 5V 2A
Additional Details
  • Cable wire: AWG 18#
  • Charge or sync: charge only
  • Connector to Camera: USB Type A Male to Female
Weather & Temperature
  • Weather Rating: IP67
  • Operating temp: -30°C to 50°C / -22°F to 122°F
  • Type-A USB extension cable x 1
List of compatible devices:
  • Wyze Cam v2
  • Wyze Cam v3
  • Wyze Cam v3 Pro
  • Wyze Cam v4
  • Wyze Cam Pan v2
  • Wyze Cam Pan v3
  • Wyze Cam OG
  • Wyze Cam OG Telephoto
Please note, Wyze Cam Outdoor and Wyze Doorbell products are not compatible with this extension cable. In addition, non-camera products are also not compatible with this cable, as it does not support data transmission.
No, it does not.
It is compatible with any 5V/2A Wyze-branded power adapters.
FREE shipping on orders $0+
