Skip to content
1 of 9
Wyze Cam OG Telephoto
Back to the basics, with a huge leap forward. Capture the little things with 3x zoom.
1080p HD
Color Night Vision
IP65 Weather Resistant
24/7 Local Recording
Pack
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
$39.98
The 2023 generation of Wyze Cam has arrived. Now with quicker live-streaming, 3X faster notifications, improved 2-way audio, and a 3x telephoto lens. Indoor/outdoor*.
  • Owl in front of color wheel icon
    1080p HD Color Night Vision
  • Rain cloud with the sun behind it
    IP65 Indoor/Outdoor Security
  • A black image of a telescope.
    3x Telephoto Camera Lens
  • MicroSD card with arrows that represent continuous recording
    24/7 Recording to Wyze microSD Card
Wyze Cam OG Telephoto Specs
Color & Materials
  • Color: White
  • Finish: Matte
  • Image Sensor: CMOS-Starlight Sensor (1920 x 1080)
Dimensions
  • 1.89in x 1.89in x 1.89in (48mm x 48mm x 48mm)
Weight
  • 4.1 oz (116 g)
Power
  • Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
Telephoto Field-of-View
  • 27°(DFOV), 23.6°(HFOV), 13.6°(VFOV)
Video
  • Video FPS: Daytime - 20 FPS Nighttime - 10 FPS
  • Video Encoding: H.264
Additional Details
  • Power Cable Length: 6 ft (1.8 m)
  • Ports: 1 micro USB
  • Mounting Method: Stand, wall mount (M4 screw), or ceiling mount (M4 screw)
  • Night Vision: 4 IR LEDs (850nm)
  • Digital Zoom: 8x
  • Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
  • Local Storage: Supports up to 256 GB microSD in exFAT format
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4 GHz Wi-Fi
Weather & Temperature
  • Weather Resistance: Indoor and Outdoor (IP65)
  • Operating: -4°F - 131°F (-20°C - 55°C)
  • Storage: -40°F - 158°F (-40°C - 70°C)
Language
  • English
Warranty
  • 1-Year
View our Wyze Cam Comparison Chart
  • Indoor Power Adapter
  • USB Cable
  • Wall Anchors
  • Wall Plate
  • Mounting Screws (M4)
  • Quick Start Guide
Wyze Cam OG Stack Kit
  • Stack Mount
  • Dual Micro USB Power Cable (6ft)
  • 5v/1.5A Indoor Power Adapter
  • Quick Start Guide
There are two key differences: The telephoto camera has a 3x telephoto lens, while the standard OG camera has an integrated spotlight. Both are great cameras with all of the features you know and love. Use Wyze Cam OG to monitor your home with a wide angle lens. Use Wyze Cam OG Telephoto to clearly monitor points-of-interest that are further away.
Yes, both cameras can be used as standalone cams. But we like using them both together - you get the OG’s integrated spotlight, Wyze Cam OG Telephoto’s closer details, and the ability to view the livestream of both cameras at the same time.
No, Wyze Cam OG is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam OG is IP65-rated and can be used both indoors and outdoors.
You can stack 2 total cameras together, in any combo! That could be a Wyze Cam OG and a Wyze Cam OG Telephoto, or two Wyze Cam OG cams, or two Wyze Cam OG Telephoto cams.
1920 x 1080p Full HD.
Day: 20 frames per second (fps); Night: 15 fps.
No, Wyze Cam OG Telephoto only supports 2.4 GHz networks.
Wyze Cam OG Telephoto is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Yes, Wyze Cam OG Telephoto is compatible with Wyze Web View.
Yes, the telephoto cam can be used as a standalone camera, without a Wyze Cam OG. But we like using them both together - you get the OG’s integrated spotlight, Telephoto’s 3x closer details, and the ability to view the livestream of both cameras at the same time.
Yes, Wyze Cam OG Telephoto is IP65-rated and can be used both indoors and outdoors, rain or shine.
Only Wyze Cam OG and Wyze Cam OG Telephoto have Picture-in-Picture functionality.
Yes. You can use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto 3x cameras at the same time. It is not limited to only Wyze Cam OG + Wyze Cam OG Telephoto viewing.
No, neither camera is compatible with Cam Plus Lite. Cam Plus Lite only supports cameras released during or before April 2022.
No, only Wyze Cam OG has a spotlight.
No. The Wyze Cam OG Stack Kit is a useful way to mount any two Wyze Cam OG or Wyze Cam OG Telephoto cameras on top of each other and use a single outlet to power them both. The Picture-in-Picture feature is a software feature and does not require the physical stack kit to work.
The Wyze Stack Kit includes a USB Cable Splitter, a Power Brick, and Stack Mount that allows you to power and stack-ably mount two Wyze Cam OGs or Wyze Cam OG Telephoto Cameras on top of each other.
Yes. Both cameras take all Wyze microSD cards up to and including 256GB microSD cards.
The ultimate indoor/outdoor security cam featuring 3x Telephoto lens.
Two white cameras on a table.
Independently amazing.
Upside down or right side up each camera operates on its own to cover every angle of any space.
You: "Looks like rain. Need a jacket?" Wyze Cam OG Telephoto: "That's a beta move, bro." IP65 weather resistance means it can stand up to the harshest weather.
Water drops falling onto a security camera.
Emphasize and bring faraway subjects closer. Deter potential bad guys with a 3x telephoto lens and a 90-decibel user-activated siren.
Smartphone camera with Wyze app notification on it.
3x faster motion notifications.
Wyze Cam OG Telephoto standing up on a desktop with text bubbles nearby. Text and icon overlay that represent 2-way audio.
Upgraded two-way audio.
Person holding a smartphone with a live video stream of their dog.
  • Smartphone with livestream video open on the screen. White text overlay of local microSD card storage features: timeline, calendar view, continuous recording, and timelapse..
    Supports all Wyze microSD cards, up to and including 256GB.
  • Smartphone with detected events on the screen. White text overlay of Cam Plus features: Unlimited cloud storage, smarter notifications, and advanced detection of people, packages, vehicles, and pets.
Cam OG's live view inside the Wyze app.
A smartphone displaying a live view of a home.
Cam OG's playback timeline with labelled events inside the Wyze app.
Cam OG's detection zone settings inside the Wyze app.
Cam OG's smoke and carbon alarm settings inside the Wyze app.
A smartphone screen with a setting for alarm sounds.
A brand new app experience.
Unlike a stray Lego brick at 1 am, we've put all the handy tools exactly where you'd want them–from spotlight and siren controls to the new simplified event review.
Enjoy a new, easy-to-scan Recent Events section to quickly navigate footage.
Tell Wyze Cam OG exactly where you want it to watch. Get notifications only for detections within your customized zone.
  • 3D render of Wyze Cam OG security camera against a white background.
    Wyze Cam OG
    • 120° Field of View
    • Built-In Spotlight with Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    • Works with Wyze Cam OG Stack Kit
  • 3D render of Wyze Cam OG Telephoto security camera against a white background.
    • 3x Telephoto Camera (27° Field of View)
    • Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    Learn More
