1 of 6
Wyze Bulb White
Wyze Bulb White
A smart, tunable LED light bulb with 90+ CRI.
Most 5 Star Reviews
Highly Rated Online
Size
$39.98 $47.98
Use a 5-digit ZIP code.
Wyze Bulb White is probably brighter than you, but has handy dimmable controls, in case you find that intimidating.
  • A single light bulb shining in a black background.
    Temperature and Brightness Control
    Dim, brighten, or change the color temperature.
    90+ CRI
    Accurate colors with 90+ CRI.
  • A black screen with a white sun icon.
    Sun Match
    Automatically adjust the color to match the time of day.
  • A black background with a lightning bolt icon.
    Lightning Fast Setup
    Pair up dozens of bulbs simultaneously.
Wyze Bulb White Spec
Dimensions & Weight
  • 4.6 in x 2.4 in x 2.4 in
  • .31 lbs
Lumens
  • 30-800
Color Temperature
  • 2700k - 6500k
Color Rendering Index
  • 90+
Beam Angle
  • 230°
Power
  • 9.5 watts
Working Voltage
  • AC 120V~60 Hz
Bulb Shape
  • A19
Base Type
  • E26
Life Expectancy
  • 25,000 Hours
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4GHz, Bluetooth
Weather & Temperature
  • Suitable for damp locations
  • Not for use in totally enclosed luminaires
  • Operating temp: -4°F - 104°F
Operating Humidity
  • 0-85%
Regulatory and Compliance
  • CUL
  • UL
  • FCC
  • IC
  • CA Title 20
  • Prop 65
Wyze Bulb White 2 Pack
  • Wyze Bulb White x 2
  • Quick Start Guide x 1
Wyze Bulb White 4 Pack
  • Wyze Bulb White x 4
Wyze Bulb White 6 Pack
  • Wyze Bulb White x 6
Wyze Bulb White is the second generation of our original Wyze Bulb. We’ve made it faster and easier to set up bulbs, even allow you to set up multiple bulbs at the same time. We’ve also made it possible for Wyze Bulb White to get more dim than the original Wyze Bulb, increased the life expectancy, increased CRI, and made other minor improvements.
Wyze Bulb White should only be dimmed from the Wyze app or via a voice assistant. We do not recommend installing Wyze Bulbs on a dimmer switch, but if you must, make sure the switch is at full power.
Wyze Bulb White is rated for use in damp locations, but shouldn’t be directly exposed to the elements or used in a fully enclosed luminary.
Nope! Just a 2.4GHz WiFi connection.
Stay in sync with Sun Match.
The light in your home can influence your internal clock, mood, and productivity. Sun Match automatically adjusts the color temperature through the day. Enjoy brilliant, cool light in the afternoon and soft, warm light in the mornings and evenings.
A woman looking at herself in the mirror.
See truer, more brilliant colors.
With a Color Rendering Index (CRI) of 90+, Wyze Bulb White produces higher-quality light that makes colors look more accurate and vivid.
Easy as 1,2,3.
Set up dozens of bulbs simultaneously in the Wyze app with Bluetooth. No hub required.
A woman is laying in bed with a white pillow and a lamp behind her.
wyze bulb white google speaker
A white bulb with accordion shape.
WyzeBulbWhiteAccordion3: A white bulb in a glass hanging light fixture.
Smart controls you would expect.
Wake up or fall asleep to custom lighting routines that gradually brighten or darken with time. It’s like having your own personal sunrise and sunset.
Your voice is now your light switch. Command your lights by asking Alexa or Google Assistant to turn them on/off, adjust brightness, or change color.
Make it look like someone's home whenever you are away. Just enable Vacation Mode in the Wyze app and our bulb does the rest.
Group all your Wyze lighting products together to conveniently control all the lights in your room at the same time. Once you've dialed in your perfect scene, save it in the Wyze app for quick access in the future.
